kjadams2
Everything posted by kjadams2
My mechanic told me that it would cost $175.00 labor to replace the front rotors because they need pulled ( not sure what that means ) vs. the rear ( cost $60 ) because they don't need pulled. Sorry I'm such a novice regarding these things, but is the process the same to remove the front and back rotors? Should it cost that much more to pull the front vs. the rear? I'd appreciate any help. Thanks Kevin
I have a 99 OBW automatic. We have only 57k miles on our car. I was towing a boat (1200lbs.) and noticed white smoke coming from the right side engine compartment. Pulled over and found small amount of fluid on the ground and on passenger side of tranny. All fluid levels check okay and it wasn't overheating. I was able to drive it home without problem. AFter two days in the garage -- no leaks found on garage floor. Dealer cleaned engine and added dye to engine and tranny and said to return in 300- 400 miles. Dealer said it was tranny fluid that had leaked and after I told him my leak occurred when towing he said that if the tranny gets hot an escape valve lets the fluid out to avoid damage? Is this bullsh## or what? Never heard of such a claim! Anyway, presently no charge for this service and no receipt for present service. This dealer (Bowser, PA)has been nothing but stand-up until this point. Comments??????
I have the 2.5 liter engine but, how do I determine if I have a phase I or II engine in my car? Based upon some responses here, the phase II motor is much better. I presently have an oil leak(not sure from where), need service and I'm concerning it's gonna be expensive. Only 57K on my car. My service manual states that the Time belt should be changed every 100k -- is this an indication of which motor I have? Also, I'd appreciate common oil leak causes and costs?? Thanks
