SubaruFred
Everything posted by SubaruFred
When I replaced the duty C I looked at the clutch assembly and it showed some grooving and wear but I didn't have the time, parts or desire to do anything about it. It still locks up solidly when engaged and slips freely when not. I suppose it's possible that momentarily sticking clutches could be causing the TCU to determine that the duty C is bad but the bigger problem IMO is that once the TCU makes thie determination it will not send power to the duty c until the ign is turned off and back on. This makes a moment of TB turn into full blown TB for the rest of the trip or until the ign is cycled off and on. I tired very quickly of cycling the ign while driving or pulling over frequently to cycle the ign. It was especially bad at night since the headlights go out with the ign off. Hence the duty C switch. I know that the correct way to fix this would be to rebuild the MPT clutch assembly and possibly the TCU if the rebuilt MPT didn't fix the issue but the car has 179k on it, rusted rear 1/4 panels and I don't plan on keeping it forever. It's true that running in forced FWD mode probably changes the handling characteristics a little but I think it's less than the 205/75/14 A/T tires and 3" suspension lift have done. So while this manual duty C switch may not be the correct way to fix TB, it is cheap, easy and works great. If the clutches ever do stick in the basket grooves, I can't tell. To me it feels like any other FWD car until I switch into AWD mode. My only concern is possibly shortening the life of the duty C but if it fails, I'll either replace it or just pull the drive shaft.
Could that transistor work fine sometimes but fail intermittently? Sometimes everything worked fine, no TB at all and no TCU codes and then randomly (more often in cold weather) I'd suddenly get full TB and a bad duty C code. Resetting the TCU with an ign off/on cycle always fixed the TB for seconds, minutes or sometimes hours. I had thought that the root cause was the TCU incorrectly reading a bad duty C but maybe it was the TCU itself causing the duty C to fail and then compounding the problem by not even trying to send voltage to it. IMO the default mode should have been 90/10 rather than 50/50.
Just an update to close the thread out. Although my TB symptoms and TCU codes all pointed to a bad duty C, the duty C was fine. Presumably the TCU is bad, specifically the part that controls the duty C. I cut the duty C control wire (+V) to the TCU and wired it to a 2-pole LED switch I installed in the dash. For +12V power I tapped into the main ign-on switched feed wire on the steering column. Now when the switch is on the duty C receives +12V and remains in FWD mode without the slight trace of TB. Flip the switch off and I have 50/50 torque split for snow and off-road use. It's been a few weeks and a few thousand miles now and I'm very happy with this solution. Thanks to whoever came up with this idea originally, to those who suggested it to me and those who provided me with the TCU pinout, etc. It works like a charm.
John, you make some very valid points but I already had the switch, wire and connectors in hand so this mod only took under 2 hours total. I've already spent over 2 hours searching for a replacement TCU and still haven't found one. Do you know where I can find a known-good TCU for a 1993 Legacy AWD non-turbo? Maybe I can leave the switch in for 10 years? We don't really know how long the duty C will last at 100% duty cycle. My original lasted 175,000 miles and 18 years running at 90% duty, 95% of the time and was still good when I replaced it. If I can find a TCU for a good price I may try it but frankly this car will probably be sold or scrapped when the tires wear out in ~40,000 miles. It's rusted, the paint sucks, it's no classic and has very little re-sale value. Thanks again for what I consider to be very good advice, even if I don't take it. That's on me and I may or may not regret it. Only time will tell. P.S., I have a 12V PWM fan speed controller laying around. What if I wired that into the duty C circuit? Instead of a +12-14V switch I could manually control the duty C the same way the TCU does. I may try this. ~1 hour and free.
Thanks guys. I agree that replacing the TCU would be the ideal solution, if that's all it takes. The thing that worries me is that my TCU does control the duty C correctly much of the time. It's only when the TCU decides the duty C has failed and stops sending it any current that my TB occurs and remains until I re-cycle the ign switch (and TCU). I also agree that theoretically it's not a great idea to run a intermittent duty solenoid at 100%. However I was looking more for real world success and failure data like below: Thanks again grossgary. 2 years is a long time and if my duty C lasts that long wired this way I'll be satisfied.
the FWD fuse is left in or the TCU is bypassed and the duty C is controlled by a manual switch? FWIW, I tried flushing the ATF, Trans-X and a new duty C but the only thing that fixed my TB was bypassing the TCU and hard-wiring the duty C to a switched +12V power source. The problem was that the TCU kept determining that the duty C was bad and defaulting to 50/50 torque split. This ensured that TB was always present since the TCU wouldn't send any voltage to the duty C. Sending +12V to the duty C via a switch has eliminated all TB and allows 50/50 AWD on-demand at the flick of a switch.
IIRC with the gear selector in D I measured ~4.5V, in 1st gear it was ~2.5V and with the throttle wide open I measured less than .05V. I forget the measured resistance but it was within spec too. I'm just speculating that since it presumably takes 8-14V to ensure a 90/10 split and less than .05V to ensure 50/50 that perhaps 4.5V is not enough to hold the solenoid closed for 90/10. I'm not very familiar with PWM circuitry but I'm speculating that something may have failed, causing the TCU to duty C output voltage signal to drop. Then again it could be something else entirely. All I know for certain at this point is that bypassing the TCU appears to have fixed all of my TB issues.
Update: 2 days and not the slightest hint of any torque bind, cold or hot. If I flip the switch to stop sending voltage to the duty C I get immediate and severe torque bind. Enough to cause the rear tires to chirp as they slip while turning and very noticeable. Worn or not the transfer clutches really lock up solid. I'm very inclined to blame the TCU for all of my TB problems. The TCU reported a failed duty C but when I replaced it, nothing changed. Byp*********ing the faulty TCU has made all the difference. I also noted that with the fwd fuse installed the duty C was getting 10V+ but without the fuse it only got 2.5-4.5V. I suspect that a problem within the TCU had reduced the voltage going to the duty C to a level insufficient to acheive a 90/10 split. Thanks again Grossgary and others!
Thanks, glad you like it. My car had leaking air shocks so I bought used Forester struts *********emblies and also new replacement Forester struts because the used ones had 100,000 miles on them. The fronts were a direct fit but the rear Forester top hats were not. I had to slot the top hat mounting holes in the strut towers and use 1/4" spacers from Paranoid Fabrications. If I had it to do over again I would have bought rear top hats for a 93 Lego and used them instead. If you already have springs on your Lego, you can easily swap your rear top hats onto the Forester struts. I'm not sure if the springs are interchangeable. You can also use struts from a 96-98 Outback to get the same lift.
Hi, I know it's been a while since you posted but do you know what year the Forester struts were from? With the 93 Lego top hats would there be any mods needed to them to fit? I have a 94 Legacy LS that had the airs taken out and rides like a pregnant sow. I'ld like to get an inch or two lift and firmer ride.
Thanks,
Craig
Not a problem, no one else drives the car and it will be left in 90/10 mode 95% of the time. The switch has a very visible LED to remind the driver that the proper fwd mode is selected. I probably didn't explain my TB symptoms accurately enough or with sufficient detail. In 70F+ weather TB occurs only randomly and can always be cured by cycling the ign off and on again to reset the TCU. In <50F weather TB occurs constantly until the ign is cycled off and on after the trans has warmed up. If the TCU is not reset the TB is just as severe when the trans is hot as it is when cold. It always takes a TCU reset to fix it. It doesn't lessen at all as the ATF gets warmer. 50/50 AWD works the same, hot or cold. Obviously something is causing the TCU to "fail" the duty C and it occurs more often in cold weather than hot but I can't say exactly what that is. It could well be a worn transfer clutch *********embly combined with higher ATF pressures when cold but the consistent "fix" is to simply reset the TCU. Rather than continue to turn my engine off and on again to reset the TCU, I felt that establishing manual control over the duty C would be preferable. I could have installed a switch on the TCU power circuit to reset it without turning the engine off but I wanted to try this method instead. Besides, I felt that the TCU did a lousy job of managing F/R torque split anyway. This way I have FWD normally with AWD on-demand, on-the-fly.
I've seen photos of what you're talking about. Those grooves that wear into the clutch basket and hub and catch the clutch discs. That could possibly explain why the TCU reads a failed duty C and defaults to a 50/50 tq split. Re-building the clutch assy would likely fix all of my TB problems. However I have 2 problems doing this: 1) I don't have free access to a lift. I have to rent one at $30/hr. 2) Where can I possibly find a used clutch assy for a 93 Legacy that isn't as worn as mine? I suppose I could buy a used assy, re-condition it and then swap it in on the lift. I was hoping to try the manual duty C control as a short cut solution. Since the clutches only stick occasionally, I would still have some TB when they're stuck but at least the TB would be gone as soon as they become unstuck. As it is now, once the TCU decides the duty C is failed, it stops controlling it and causes constant TB until I reset the TCU with the ign switch. Thanks.
With or without the FWD fuse installed, the main problem appears to be the TCU determining that the duty C has failed at which point the TCU stops sending +12V to the duty C. This results in a 50/50 split and TB that lasts until the TCU is reset by one or more ign on/off cycles until the TCU accepts the duty C as good. As long as the duty C receives +12V, there is no TB. I've tested this many times and the results are always the same. My switch idea isn't to switch the FWD fuse circuit which would still rely on the TCU controlling the duty C but rather to cut the control wires to the duty C and replace them with a switch powered by an alternate ign-on +12V source. If this works I would have only 2 available torque split ratios (90/10 or 50/50). It's been done before but the cases I saw were later model 4EATs with different wiring harnesses. One guy went so far as to install a bank of resistors to simulate the duty C so the TCU wouldn't flash at startup. I plan to test this ASAP but the hold up is finding the correct wires to intercept. I have no schematics and haven't found any for a 93 Legacy.
Thanks! FWIW, my FWD dash light is always on when a fuse is installed in the fwd socket. TB or not has no affect on this. This makes me believe that the new duty C is okay. I'd like to try a new TCU next but I don't think a 96 TCU will work in my 93. I've seen TCU pinouts from 93 and 95 and they are completely different. AFAIK I need a TCU from a 92-94 Legacy 4EAT. Do you think that the duty C can withstand a constant +12V since it was designed to spend most of it's time in 90/10 FWD mode? Short of finding a new TCU, a manual duty C switch control may be my last resort.
That sounds plausible, thanks. However I'd like to note that whenever TB occurs the TCU stores the same code 24 for a bad duty C. Once the fault is stored the TCU defaults to a 50/50 torquie split by not sending any voltage to the duty C. The only way to fix the TB after it occurs is by re-cycling the igntion switch to reset the TCU. When the trans is still cold, this doesn't work but as soon as it warms up enough, it does work. Something is telling the TCU that the new duty C has failed when the trans is cold but okay when the trans is warm. It seems to me that the biggest issue is the TCU refusing to send voltage to the duty C. I don't know what is causing the TCU to determine that the duty C has failed. Perhaps gummed up clutches as you suggest. 1) The cold trans TB occurs with and without the FWD fuse installed. 2) On the next startup following TB the power light always flashes 16 times. The short term code is always 24 for the duty C. If there wasn't any TB on the previous ign-on cycle, the power light doesn't flash and no codes are stored. Considering that the front diff fluid may be 18 years old I'll just change it. It might not help but it couldn't hurt. I'm leaning back to the idea of manually controlling the duty C with a switch but I'm concerned that supplying constant +12V to it may overheat and damage it. I could also try a new TCU if I can find one. Thanks.
The quick history is that I own a 93 Legacy wagon with 177,000 miles. I drained and re-filled the ATF 3 times and replaced the duty C. All 4 tires are identical as well as pressures. The current problem is that I have very bad TB when the ambient temp is below 60F and the engine/trans are cold but almost none when ambient temp is above 70F or the engine/trans are warm. The question is why I have bad TB with a cold trans but none when the trans is warm? Electrical resistance issue or hydraulic pressure issue? Any ideas?
Thanks again to everyone for your help. I've been side-tracked recently by hurricanes, tropical storms, flooded basements, my other car and work but I did manage to read a little bit about duty solenoids. I was concerned that applying a constant +12v to an intermittent duty solenoid might damage it and it can. Apparently there is a good reason why Subaru recommends not driving around with the FWD fuse installed. It can overheat and damage the duty C solenoid. So much for my constant +12V on/off duty C switch idea! If I haven't fried my new duty C already with the FWD fuse, I think perhaps I should look for a replacement TCU or in the worst case, remove the drive shaft. FWIW, my TB is almost non-existent at ambient temps of 75F+ and almost constant at ambient temps of 60F-. I can't say whether this is an electrical resistance issue or a hydraulic pressure issue but I'm leaning toward the notion of excess hydraulic pressure from cold ATF overcoming the duty C.
I think you're probably right about the TCU going bad. I suppose a wiring short is possible but not very consistent with the symptoms. With the FWD fuse installed the FWD indicator stays lit all the time, even when TB is present. I can fix the TB 95% of the time by shutting the engine off and restarting. The TB behavior hasn't changed at all since replacing the old duty C which makes me think the old duty C was fine. So basically I have an intermittent duty C failure failure not caused by the C solenoid or wiring. Must be the TCU. However, rather than replace the TCU I think I may just install a switch to the duty C using an alternate ign-on +12V source. Cheap, easy, driver selectable 50/50 AWD and no searching for a replacement TCU. All I have to do is find the correct duty C wire, run some wire and install a switch. What do you think?
Thanks guys! Just a couple more questions: 1) Where can I find a replacement TCU that isn't almost 20 years old with a lot of miles on it already and doesn't cost a small fortune? 2) Any chance that my 93 TCU wiring is the same as a 95+? Even if a new TCU fixes the TB I still want to do the wiring mods so I can select between FWD and 50/50 AWD with a switch. I don't like how long the TCU takes to react when rear traction is needed nor do I care about having AWD during normal driving conditions.
Code 24 is for the duty C. I wish I knew how the TCU determines that the duty C is bad. I'm guessing that it might be blaming the duty C for mechanical issues. I rented a lift by the hour to change the duty C and didn't have time to address the grooves in the clutch basket and hub. I gambled that the grooves could be left alone. Anyway, since I really don't care about having full time AWD but want AWD on demand I'm thinking of removing duty C control from the TCU and using a simple switch to control it. As I understand things the TCU sends a varying voltage to the duty C to control the torque bias. What if I only send full voltage or no voltage to the duty C? It would either be open or closed. Much like installing the FWD fuse except that the torque bias would either be 90/10 or 50/50. I'd only use AWD off-road or in snow/sleet, etc. I'm assuming that the wiring is still good but if not, I'll have to address that whether I install a switch, fwd fuse or new TCU. I'm not very optimistic that a new TCU will solve this issue without addressing the 178k wear in the MPT clutch assy. Do you know what voltage is sent to the duty C to open it fully? 5v or 12v? I also need some guidance on the wiring. I'm sure this has been done before but it could take a lot of searching to find it. Thanks for your help.
Well, I'm glad I didn't pay dealer prices for my duty C and related parts since they made no difference. I still have the same intermittent TB I had before changing the duty C. When the TCU accepts the duty C as good, there is no TB at all. When the TCU decides that the duty C has failed, I have full TB until I shut the engine off and restart. This leads me to 2 options: 1) Try a new/used TCU 2) Install a duty C switch for manual AWD control I prefer option #2 at this point which leads me to ask if I can take manual control of the duty C? If so, how? If not, I guess a FWD fuse switch on the dash is the next best thing. I would prefer to re-wire the duty C so that it is in FWD mode normally and 50/50 split when selected. I know it's possible, just don't know how to wire it. Schematic links would be invaluable. BTW, I finally figured out how to read the TCU codes and the old ones are 23, 24 and 33. Engine speed sensor, duty C and vehicle speed sensor #2. The current code (when present) is 24 only. The wiring to the duty C looks fine but I didn't ohm test it when I had the trans apart.
