Zoltan
About Zoltan
- Birthday 05/01/1971
Location
Kelowna BC Canada
Occupation
Sales
Vehicles
90,91,92,93 Legacy
Recent Profile Visitors
Zoltan's Achievements
Advanced Member (3/11)
12
OK. So Have raised the tranny 3 inches up from the cross member. I think this will help. I am now waiting for a input shaft seal, as I just noticed mine is bit damaged. I may have done that while inserting and removing torque convertor 10 times. I will get seal in a day or two and thanks again for the advise.
On my 07 Outback, EJ25 NON turbo I had to remove the engine with the torque convertor as the motor was seized. I got a different motor finally, and am now trying to re install the torque convertor. I know the correct depth that it needs to go in but cant seem to achieve this. The torque convertor spins freely in both directions and still need to go in another 2 or 3 inches. I tried for an hour to spin and push. Some sites say it will go in three different stages. I also saw a video online and am now wondering if I need to take out the outer shaft from the tranny (seems to be about a foot long) and put in on torque convertor with its C clip and try this again. I am confused and very frustrated. Not sure what to do. Thanks in advance for any advise or links.
I have 06 Outback with an auto transmission and a NA EJ25 that has a connecting rod sticking our of the block next to the oil pressure gauge. Dont you love it when you can diagnos the problem 3 seconds after opening the hood! The motor only moved a few degrees so I was only able to get out one torque convertor bolt. I pulled the motor with the torque convertor as I could see no other way to get it out. Any ideas on how to get the torque convertor off the engine, now that its sitiing on my garage floor. Short Block is garbage. I will take off the heads and reuse them on a 2002 EJ25 I pulled from pick n pull. Does anyone happen to know if the 2002 torque convertor will work the 2006? I could go and pick it up as the pick and pull is close to me. Also I need to get the PCV valve conection off the Garbage block. Is this pressed in. With the dual outlets on this PCV connnection coming out of the block, I cant seem to figure out how to get it out as I cant get a wrench or socket on it. Thanks again for everyones input. ?
Motor swap
Zoltan replied to Zoltan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I cant use the heads from the pick and pull engine because they are from an 02 EJ25 and the the heads from the 06 Forester are different. -
Thanks everyone. I should have mentioned that the 08 has a hole in the block. Not sure if it was overheated, I bought it that way from a shop and not directly form the owner. So zero history on the car, so not sure if it was overheated or not. I will try to get in touch with the previous owner and see exactly what happened. THe car is a manual and it was driven by a young male so he may have just been really hard on it!
So im off to pick and pull to get an EJ25 SOHC from an 03 outback. I dont need the heads, as I will be using the heads from my 08 impreza. My question is do I need to keep track of the head bolts from the 03 or should I just use the ones from the 08? From the research I've done everyone seems to say no new heads bolts need to be purchased. Thanks in advance for everyones help.
Motor swap
Ok. thanks for all the help. I think due to the fact that the zero comp engine may have been overheated I will be going to get the one from pick and pull -
Motor swap
Ok. THahks guys. It would be nice to have someone to help me out., but I don't have anyone like that so I spend a lot of time researching and taking things slow. So I bought a 04 na Ej25 sohc Forester today as a parts car. I paid $280 and thats basically what the tires are worth. I bought it from someone who had it for a year and spent the whole time on vacation with it. From all the paperwork I got it seems it was driven about 20 000 miles. Car has 165 000 miles on it. It idles very rough so I did a compression test. 190 psi on 3 cylinders and zero on the last one. I did some research on this and my question is how can I tell if this problem is in the head or a problem with the rings or pistons etc. I dont need the heads. I will be using the heads from the 08 impreza. I went through the paperwork and a jiffy lube mentioned no oil on dipstick when the car was brought in, so I figure it was overheated. Should I just stay away from this engine? I did see a nice 03 Outback with similiar milage in the my pick n pull that was in a small fender bender and written off by our goverment insurance agency. Would love to hear everyones opinon on this. -
I just picked up a 08 Impreza sedan, 5 speed EJ25 Sohc, with a hole in the block. Looks like connecting rod did it. I noticed that this motor has a soleniod in the head. I think its for variable timing. Can I take a EJ25 SOHC short block from lets say 2000 to 2004 and use the 08 heads? I will take heads to a machine shop. I have never done a head gasket job but I did watch 4 good videos on it, and if I take my time I think I can do it. Thanks for everyones time and input. It is much apprecaited.
Ok I finally got it back together. But the transmisson seems to be sliipping, not sure if this is related. I will keep it as a winter beater and see how it goes. AT least I learned a lot and it gives me time to find a low mileage tranny. Body motor and interior are real nice. Thanks again for everyones help.
When you say "drum" do you mean the large round thing currently on my rear housing, or the large round thing currently on my tranny? I really did try hard to keep everything together, not sure how it cam off like this. Twice. I have the service manual. Confused the spoob out of me. I cant seem to make heads or tales of it.
