mustangthegreat
Everything posted by mustangthegreat
  1. My local Subaru shop found a TSB on bad grounds for this problem for this model, it described cleaning all of the grounds and it appears to have worked. Before this they also replaced the speedometer. Car has a new life now.
  2. I have a 98 Outback Limited with a P1507 code, I just replaced the neutral switch as well as the IAC valve complete. Neither have fixed it. I still get the error code and then the limp mode runs on 2-3 cylinders. I cycle the ignition and it runs OK for anywhere from 30 to 3,000 miles. Prior to these recent repairs I have replaced the following in the last year: head gasket update intake gaskets exhaust flange gaskets outer valve cover gaskets inner valve cover gaskets valve cover bolt seals rear cam plugs cam seals exhaust flange nuts oil and filter (regularly) drain plug gasket coolant belts radiator crankcase breather update timing belt tensioner idlers water pump thermostat clutch fuel pump and sending unit alternator coil ECU speed sensor CV boot right passenger front under Cat cleaned connections on speedometer Car has 171k on it, doesn't smoke, consumes 1 qt oil every 2k, local ROOPair shop can't figure it out, please help! Edit/Delete Message
  3. :confused:I have a 98 Outback Limited I have the exact problems above, I just replaced the neutral switch as well as the IAC valve complete. Neither have fixed it. I still get the error code and then the limp mode runs on 2-3 cylinders. I cycle the ignition and it runs OK for anywhere from 30 to 3,000 miles. Prior to these recent repairs I have replaced the following in the last year: head gasket update intake gaskets exhaust flange gaskets outer valve cover gaskets inner valve cover gaskets valve cover bolt seals rear cam plugs cam seals exhaust flange nuts oil and filter (regularly) drain plug gasket coolant belts radiator crankcase breather update timing belt tensioner idlers water pump thermostat clutch fuel pump and sending unit alternator coil ECU speed sensor CV boot right passenger front under Cat cleaned connections on speedometer Car has 171k on it, doesn't smoke, consumes 1 qt oil every 2k, Please help!
