CEL Code's 35, 11, 13, 24 Where to start?
Milesfox: that is great to know, thanks for that info! So I have read just about every purge control thread on here, seems like I can trick the ecu with a 33ohm 5w resistor. However I am uncertain how to go about this. Haven't work with resistors and solenoids.. Do you just connect the two connectors with the resistor?
Where is the Purge control solenoid located ?
Ps its a 1990 Loyale SPFI 5 speed MT
I have had my CEL going on and off for sometime now and it's time to get rid of it. Mostly because I have to bring it in for emmisions.. So the CEL seems to come on when the car warms up and then randomly goes off.. I finally figured out how to pull the codes (thanks for the write up) With nothing connected I get Code 35 with the White test connectors it get a 35 (Purge Control Solenoid or Circuit) 11 (Crank Angle Sensor or Circuit),13 (Crank Angle Sensor or Circuit) 24 (Air Control Valve or Circuit ) I have no idea where to start. Thanks in advance for your help / replies!
Knock sensor 101 and replacement
Bdubya replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThen what is this $80 part that come up when i search for a 1990 Subaru Loyale Knock Sensor? part #KS89 My CEL comes and off at what seems to be random times, my mechanice said it maybe my knock sensor.. I need to get my washington state emissions test,however, from what i understand it will be an automatic fail if the CEL is on.. (this is my first test in the state of Washington, NY does a safety check)
Bdubya replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes anyone have information on the KS89 Knock Sensor?! Of course I couldn't have the cheaper sensor! Its a 1990 Loyale Wagon (non-turbo). Thanks guys!
Fan Switch Access
Do you have to take apart the dash to do so? If so how do you take the dash out?
Fan Switch Access
Duh! Sorry about that, posted real quick while i was at work.. Anyway, It is a 1990 Loyale Wagon many thanks
Fan Switch Access
So my Ac/Heater Fan Only works on the first 3 settings, The Blower Motor and Resister was replaced when I bought the car.. I would like to swap out the switch myself however I can not seem to locate the the access point to get the switch out. Please help! Thanks!
90' Loyale Bumpers
Thanks Mr. Loyale for that awesome info, I would have never guest that was under the plugs. Are these the only bolts that hold up the bumper? It seems like there should be a bracket of some sort under the tail lights, there are 2 holes in the bumper... Ps it is a Wagon.. Thanks again!
90' Loyale Bumpers
Hello everyone! I am hoping someone can help, I have a 90' Subaru Loyale with a saggy rear bumper. I crawled around under the car to find how it was attached all I saw was screws that seem to just connect the bumper to the bumper cover. I searched Hi and low for a repair manual, only found for engin and electrical. Could someone please tell me how to detach / reinstall bumper? Many Thanks, Brian
Bdubya
