jdmleggy97
2
jdmleggy97 last won the day on January 13 2020
jdmleggy97 had the most liked content!
About jdmleggy97
- Birthday 07/19/1986
Location
WA,NY,TN
Interests
na
Occupation
na
Ezboard Name
na
Vehicles
bunch-o-subaru's
Recent Profile Visitors
jdmleggy97's Achievements
Advanced Member (3/11)
39
XT6 Transmision onto 3.0R engine
jdmleggy97 replied to nazvwxt6's topic in Old Gen.: 80's GL/DL/XT/Loyales...
To be honest I rip second gear at the strip's, well I used too lol most guys that drag scoobs take it a little easy on the 1st to 2nd transition and the same with launches. It all just depends on how your driving and who's the driver, but I will say more often than not I've seen 2nd gear failures if your hooning like a turd. The vehicle was : 03 LGT 257/205 Hybrid VF43 ACT HD clutch (all normal mods, intake, exhaust, etc.) tuned by torqued performance (eric minehart) Not really sure how we all got sidetracked on the conversation haha, there's only one reason I would suggest a STI trans over a spec b unit.. the speed sensor on 4th Gen Legacy's isn't mechanical based. -
I have never killed third in a 5sp, but I cant say the same for second. With both 1st and 2nd being part of the main shaft I've killed 5 of them haha. I really think it is a flex and shock issue but if you treat them with a little care they will stay together. If you happen to shred third you can just replace that gear which is nice when compared to the entire main shaft as I mentioned for the lesser two gears. -
Yes and No. An STi unit might be a little easier all assuming, even though the Spec B units are geared better (6th gear only). I know it sounds crazy.. but trust me lol. -
87 XT door innards, window motor.
jdmleggy97 replied to SiriusBlack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is a XT and XT4/6 in the Oregon pick an pull just a heads up -
91 loyale rear differential support bushings?
jdmleggy97 replied to Zip Tie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
https://superpro.com.au/ -
Call out to XT6 owners! Wiring question
jdmleggy97 replied to jdmleggy97's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No it can’t unfortunately. It’s a straight line from the steering computer to ECU. I wish it ran to the test connector it would make life wayyyyyy easier! -
Yeah that’s what I’m assuming. What that signal is.. I.e. a ground signal, a positive voltage signal, or some kind of pulse...that I don’t know and need to find out. -
ER27 durability + performance build
jdmleggy97 replied to tjet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Permatex blue -
So I’m doing a swap on my XT6 and I’m digging into the diagrams I have.. It looks like pin#63 a Brown/Red wire goes to the cybrid steering computer. I’m trying to remove everything in this car that isn’t needed including the Factory ECU. What I’m asking, is anyone willing to put let’s say a volt meter on pin#63 while their vehicle is running/ not running and see what comes out of it. I’m assuming it’s a (ground)signal letting the cybrid computer know the engine is running. The car is very basic so I can’t really believe it’s more than that hahahha. I honestly should have tested this before I ditched the ER but it’s water under the bridge at this point. 88 XT6 EZ30R Swap
ER27 inherent issues & weak points
My Thoughts exactly...number 1 reason I’ve ditched all the ER stuff and just decided to AWD and EZ30R swap mine -
Did a 3 angle valve job, cleaned up the ports on the intake/exhaust, and milled down the heads a bit on my ER in high school. The power was nice! Lost a few upper RPM in the rev range but I can’t say at all that the engine didn’t wake up lol Didnt last very long though. I used the wrong silicone for the cam carriers/housings (I just didn’t know. I was a kid) and it broke down into chunks and clogged up the oil pickup. -
All XT6 Owners! (Feeler)Clear front markers
I’ll add it one we’re accepted by the admins. I don’t have a FB currently so the Mr’s signed up -
Hummn I’ll have to look into that. I don’t have a Facebook though
