daddycool100
Everything posted by daddycool100
car would not run when you accelerate coughing and sputtering..replaced fuel filter..02 front bank( check eng came on ran codes )..new plugs and air filter..did pressure test and psi was 0 also bypassed fuel filter and cranked and fuel just dribbled out..best guess was fuel pump..the only electrical i messed with was the 6 pin plug to pull fuel pump..
Update: replaced worn out plugs , air filter , same results..Did a fuel pressure test and what do you know it was just a trickel coming out of fuel line after bypass fuel filter and crank key. I think we found the problem as she needed a tune up anyway.Thanks everyone for your help..Also found out there was a filter behind the glove box as i was wondering why the air and heat did not blow like my outback..Blew out filter and increased volume out of vents by 1/3. JK North Idaho USA
I have a 03 forester XS 140,000 has been very hot here. was running good down freeway at 70 then i hit passing gear and car started to lose power. Got off freeway and it went down hill from there to a complete stop. I did nurse it home ran like crap 0-10 mph spuutering all the way. I put a new fuel filter on car and took on freeway. going 70 mph i hit the gas and again losing power and surging. I am going to check fuel pressure.. Any ideas from anyone would be great..I guess i will have to ride my Harley to work.
