				Posts2450
				Days Won34
Everything posted by l75eya
	Ben sometimes will not start. Turn the key to start position and all that happens is some solenoid under the SPFI black thing clicks, and the check engine light will pulse. (constant on, dims, bright, dims, bright, rapidly). How can I jump the starter solenoid as a bypass for whenever this happens? Is there a way I can wire in a switch to do it? In theory, what I want is Say I'm in a scenario where the car won't start. It doesn't happen too often, but it happens often enough to be annoying. So say this happens. I want to be able to leave the car in park turn the ignition to ON get out, go under the hood and press a button or something that will jump the solenoid and start the car....
	  Bogging Down on Freeway Hillsl75eya replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales... Yes! That altima I mentioned earlier, that was my first car. It was pretty quick, and I used to *fly* around in it, being young and stupid. After that car I had a 93 Dodge Shadow (3 speed auto) and then a 1987 Honda Accord Hatchback ( I liked that car a lot) with a 4 speed auto. Those two cars were extremely slow, and they really did teach me patience. There's no point in rushing from light to light, stop sign to stop sign, and there's really no point in zig zagging through traffic at 100 mph. (unless I am in a hurry ) Moral of the story; my son/daughter is getting something slow for their first car. Something really slow. Anybody know of any good, reliable, capable in snow, extremely slow vehicles from the mid to late 80's? hahaha.
	Oh yes! Thank you, forgot about that. I will check that tomorrow. I know exactly what hose you're talking about.
	  Bogging Down on Freeway Hillsl75eya replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales... I once accidentally went from 3rd to 2nd while merging onto the highway. This was when I was first learning how to drive a standard transmission, naturally lol. It was a 93 Nissan Altima Special Edition (disc brakes all around, special seats, stiffer suspension). I went to shift it at almost red line from 3rd to 4th, but put it into 2nd and just popped the clutch.... I've never seen a tachometer needle peg like that before, nor have I ever heard an engine make a sound like that before....It was bad. But it took it! That thing was rock solid *sniff* kinda miss it.
	  Bogging Down on Freeway Hillsl75eya replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales... You know what I've noticed in underpowered cars like ours? Especially when I'm loaded down with a bit of weight, the road can look like it's flat, but it is still a hill and that little bit of incline is still causing the engine to struggle. I bet there's nothing wrong with your engine, it's just the way it is. Be a little more specific about its symptoms though, I mean, does it mis-fire, sputter, or have any other signals that there may be something amiss? Or is it just purring along and you're just not gaining any speed? If it's the latter, I really wouldn't sweat it. I had semi trucks passing me at 50 mph going over the mountains in wyoming when I drove across the country in my gl. And that was in 3rd gear. Floored. As a matter of fact, I drove through almost the entire state of Wyoming with the pedal to the floor... My car did not like that state...
	  Bogging Down on Freeway Hillsl75eya replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales... From what I gather, rugby, .....you really beat your ea to hell lol:brow:
	From what I've gathered on a couple of threads on here, the dual fan set up is for cars with A/C. Which I think most of us have. On these cars, the clutch fan is the main fan for the air conditioner. The electrical fan is the main fan to cool the coolant. Cars without a/c only have the electrical fan? I could be wrong. Either way, so far I haven't noticed any temp change on my dash gauge at all without the clutch fan. I have noticed I can hear the engine much better (sounds awesome) and it is more responsive. (Very slight change, but noticeable). -Loyale2.7 This 90* you mention Is it part of the upper pipe going into the water-pump? The only hoses I know of are the narrow trans lines, the hose going to the thermostat, and the hose going to the waterpump. Can't picture a 90* in there somewhere.. :-\
	  Bogging Down on Freeway Hillsl75eya replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales... Yeah, I really think you're just hoping for too much out of a 70 hp engine lol. Keep it in 3rd, floor it. If it accelerates up the hill (and if it does, it's going to do so very slowly) then you're basically gold. It's just a very underpowered engine. If you try to take on the hill in third gear and you're at 4k RPMs and you have the pedal to the floor and it *still* doesn't accelerate....then you may have an issue.
	Margaret Scratcher 1987 GL 4WD Hi/Lo, 5 Spd, carb. 42,000 miles when bought April 2011. Spark plugs (42,000), Driver & passenger side axles and bearings (44,000), waterpump (54,000). Currently has 58,000 miles. Still haven't changed the oil since I bought it. Not proud of this... Benjamin Hooptie 1993 Loyale. 3AT, 2WD, SPFI. 52,000 miles when bought in 2010. Currently has 80,000. Since bought has had; *new timing belts, cam seals (70,000), oil pump (78,000), hoses (80,000), tires (52,000), regular 3k mobil 1 oil changes + filter, new plugs, disty cap, rotor, and wires every 15k. Fuel filter (52,000).
	Got a chance to check him out today, finally. Pulled out the alternator, threw the AC bracket aside. He seems to be leaking from that pipe that comes out of the top of the waterpump. Just going to replace the whole pump to be safe, it's original and should be changed out anyway. While I was rummaging through there, I ditched the mechanical fan. I've also gotten rid of the A/C condenser in front of the radiator. What I'm wondering now is if it's possible to get rid of the A/C compressor completely. Is there a way to rig up the mounting plates to still have the alternator in it's spot? I'm thinking there is, I'm just not sure if there would be enough adjustment in it to get the belt tight enough to compensate for the lack of the A/C pulleys...
	Actually just pulled out the mech. fan on Ben today. Gonna see how his temps look before I decide whether or not to bother with a replacement.
	How are you doing Jeszek! Just wanted to let you know that that write up you did for the electric fan conversion is awesome. I just pulled out the mechanical fan today because it is annoying and I'm going to see how my temps are for a bit before maybe moving on and following your write-up. Good stuff!!
	  Bored? Can somebody explain how this all works?l75eya replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales... You know to add to that real quick, I come here all the time and never have a problem. My system (I build computers for a hobby) is more than secure, and never have I ever had an issue at this board. At my brother's house one day, I jumped on the board on his Dell laptop. All seemed fine, but the next day, his computer had the ever so prominant windows xp security virus. 2012 edition. Something I'd never seen before, and even I wasn't able to get rid of it fully so I just wound up wiping it. Just a little fyi, no matter what system you use, go to CNET and download AVG anti-virus free edition. Get rid of all your other kaspersky and other types of virus protection, and just have avg. I've worked in the field. It is the best. My 2 cents on the matter. Also, back to the initial post, thank you guys for the replies, between all of you, I've got the idea of how this whole system functions down pretty good now. Cheers.
	You know...I've never had that happen... Not once. And I've driven hundreds of thousands of miles with my battery in it's non-full upright seat-belted position. I've had tools short the battery out before...an errant wrench, an extension, whatever may have you. You know what happened? There was a spark. No fire, no explosion, no massively overwhelming dire situation of any kind really... Mind you, I'm not trying to negate the fact that there is a *chance* (albeit slight) that the gasses in the battery can build up around said battery and be ignited by such a spark. In which case, yes, there would be a big explosion and it would not be fun. However, that is not to say I will negate the fact that an engine can separate from a passing jet, and fall into my house. Both of these things are possible, but really, would you consider it a likely enough scenario to call somebody an idiot for not having their battery fastened properly? Give it a rest.
	  Bored? Can somebody explain how this all works?l75eya replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales... Okay, that got basically all bases covered for me. Just to reiterate and make sure I'm understanding the 'ticking' phenomenon properly, the ticking noise occurs when the lifter is not fully 'pumped up', if you will, with oil. When the lifter *is* filled with oil, it is working hydraulically, as it should, and is supplying constant pressure to the rocker arm. When the lifter experiences aeration of the oil within, that pressure is temporarily released, allowing the small piston in the lifter to recess slightly and thus whenever the valve is opened the rocker arm and the piston in the HLA come out of contact with eachother. When the valve returns to it's closed position, the rocker arm then smacks into the HLA piston, making a clacking noise. Thanks for the explanation GD. It's been bugging me for quite awhile now to understand exactly how these things work. It's hard to picture it and imagine the function based on a schematic or drawing. Whenever I get to a point where I'm actually working with these components tangibly, I'm sure I'd have figured it out. Thanks again:headbang:
	  Bored? Can somebody explain how this all works?l75eya replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales... Okay, yeah. That does help. It's a little hard to picture it working that way from that illustration (where in the picture it just appears to be floating just under the rocker arm). Alright so I can picture that, the tiny piston coming out of the HLA is constantly applying pressure to the rocker arm. To keep the gap in spec, you're talking about the gap between the rocker arm and the tip of the valve stem?
	So I've just been moseying around in the FSM. I fixed ben's tick of death a couple of months ago by replacing the oil pump. When it was ticking I did my best to read through the boards and figure out what was wrong, and from what I gathered, what happens is the hydraulic valve lash adjusters don't get the amount of oil into them they need to function properly. What I'm trying to figure out, is exactly how this all works. I was wondering if somebody could try and explain it to me if you guys are bored lol. Here is a picture from the FSM Now I do know that the lobe on the cam spins against the rocker, and that pushes the valve in, opening the seal and allowing oxygen/gas/ in on the intake stroke and allows exhaust gases out on the exhaust stroke. The valves are closed during the combustion stroke. What I can't quite picture is how the lash adjuster functions. The valves stay closed through spring force, correct? What does the lash adjuster do, in what way does it push up against the rocker? Does it push up against the rocker? Just curious guys, I'd love to read an explanation if anybody has the time..
	  1989 Subaru DL coughs/sputters when coldl75eya replied to Aurie's topic in Old Gen.: 80's GL/DL/XT/Loyales... Just my 2 cents, I never drive my cars until they have warmed up, unless I'm in a real like emergency type hurry. My carbed 87 just won't drive until it's warm, it'll sputter and stall and buck me around unless I floor it, so I just start it up and let it fast idle around 1500 - 2000 RPM for about 5 to 10 minutes, and then it's good to go. Ben is fuel injected and he doesn't mind the cold too much, but even he will throw a fit if I drive him without warming up first. He takes much longer to warm up though, for whatever reason, but after about 10 to 15 minutes idling with him, he's ready for some 5,000 RPM highway drivin'
	AH! I had forgotten about that O-ring. I haven't even looked at the pipe. That might be whats leaking. Thank you! Gonna go check that out
	Hey peoples, I hope everybody's holidays were fun and filled with snow. Mine unfortunately weren't, so I haven't had chance to play in the white fluff yet. That being said though, bringing this back to the subject, poor Ben has yet another issue; he's leaking coolant. Slightly. I wanted to post this up because I have had a chance briefly to peek under the car and look around for a likely source, but I still haven't been able to narrow it down. I'm thinking maybe somebody here can cue in and perhaps point out something I haven't thought of as of yet. He is slowly dripping, and the drips are coming off of the very bottom (naturally) of the inner timing belt cover. One drip coming off at dead center, another drip slightly more towards the driver's side. While I was under the car I looked at the lower radiator hose and it is very old, but does not appear to be leaking at all. The upper hose looks fine as well. The trans lines, I can only see the upper line clearly and it looks okay as well. I figure it might be the water pump however I can see the weep hole from under the car and it doesn't appear to be leaking. If I figure correctly for drips coming from that location, there's only a couple viable possibilities, and that about covers all bases, does it not? Upper, lower, trans lines, and the pump. I am going to get new hoses (should I really go OEM for the hoses?) and put them in, the ones on there are 18 years old or so and look terrible so I figure even if that doesn't solve the problem, it is preventative. If that doesn't fix the leak, I guess my line of action after that should be the trans lines? Are those a bi*** to change? Do those even run coolant through them or do they run trans fluid? And then after that I guess ultimately it's time to do the water pump What do you guys think? Cheers!
	  slop in front axel, bearing... shake...l75eya replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales... Very interesting read, I have almost identical problem though I do get bearing squeal and grinding that comes and goes and sometimes varies between grinding/squealing only while accelerating (goes away while coasting) or the complete opposite of squealing/grinding only while coasting (goes away while braking/accelerating). Something has been up with my front left axle/bearings since I got this car. At one point I jacked up the car and had almost 1/4" of play laterally in the wheel. That's when I had the axle replaced and the bearings done. After a trip across the country I have the noise again that comes and goes. I have noticed the castlenut come loose once or twice and tightened it back up/ put a new cotterpin in but still the same symptoms. I'm just going to pull a whole knuckle out of a yard car one day and replace it, but for now, I just drive it. So long as it feels tight *shrugs*. Considering they're not too hard to get, maybe you'll want to just replace the whole knuckle as well to rule out all possible variables. Just my .02 Good luck! lol
