aaronxs400
About aaronxs400
- Birthday 04/23/1988
Vehicles
I Love My Subaru
aaronxs400's Achievements
USMB is life! (4/11)
0
Ebay/Ground Control Coil overs on EA81 Front struts?
aaronxs400 replied to aaronxs400's topic in Subaru Retrofitting
so, should i go ea82 rear coil overs, air shocks on the back (can adjust ride height) or shorter shocks. -
well, the original plan was to lift it when i install the 4wd and manual trans. looks like this wont happen till next summer when we get another car so this one can be down. so until then, I will just slam it, i miss riding low. -
now what would be the best in the rear? mount up some ea82 rear struts and use coil overs on them (although the lifted guys say ea82 struts are very very stiff, may have to disable torsion tube) or just get some shorter shocks? on my static dropped nissan 720 truck (5 in the front, 7 in the rear, would nearly lay frame) i removed 1 leaf from the pack and used Air shocks in the back, and I would just let the air out when i was parked, and would lift the rump roast end back up when i was driving around. poor mans air ride i know, but we are a bunch of hicks here in central ohio. -
Nevermind, I found several, it appears that the console side pieces in an auto are way different then a manual.
First off, I dont have a 4wd car so I cant go out and look, so Im not trying to be a newb lol. If you were looking at the differential where the driveshaft bolts to, would the rotation of the driveshaft/diff be clockwise when the car is moving forward?
Do forester's have front and rear differentials? What differential is in the rear (code number or ratio)? Anyone have an estimated weight of just the rear differential? My moms neighbor is getting ready to scrap a forester, and im working on a mini buggy project and if they have front and rear diffs, they would be perfect.
Ok, so I have a very nice pro tools hydrualic bender, http://www.pro-tools.com/302.htm It came with dies for 3/4, 1, 1 1/8, and 1 1/4. I can get free 1.25/.090 wall ERW for free. Would 1.25 tubing look or be to small for some nice tube bumpers?
So...Im having a crazy thought for a future build...
aaronxs400 replied to aaronxs400's topic in Off Road
yes -
im completely use to building something to fit a rule set...we have some strict rules in the dragbike world regarding construction. -
thanks for the link! Can I ask what your specs are for the build? what diffs, transfer case, what are your plans for the suspension, tire size? I seen a caption of one of your photos, said you were not happy about how low the diff is...how much ground clearance do you expect at the diff?
