naru
9
Everything posted by naru
antifreeze leak from heater hose 84GL
naru replied to ajp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It is simply called a PCV connector. Looks to be still available new. http://www.cheapestfactoryparts.com/oe-subaru/427337050 I would cap all the open hoses before driving. -
Engine only needs to crank,not run, in order to use a timing light. If the timing is in the ballpark,you can get it close enough to start by adjusting timing thru its range while a buddy tries to start the car. Most 78s have point type distys. I would check thier condition and adjustment if so equipped. 78 Electronic distys have external ignition control units. Only 10 volts at the coil is problematic. Check the voltage going in/out of the ignition switch/fusible links/fuses key on/off.This will isolate the high resistance connection. It would be well worth pulling and drying the spark plugs w/a torch(stove works too) after so many unsucessful starting attempts.
If there is no pulsating ground at coil -(use a test light),then the MODULE is bad ,not the computer or anything else. Module is best tested in situ.
No ignition amp or "cannister" on an 86 MPFI. Coil should have 12 volts on coil negative. If a test light lights up on coil -,but does not pulse w/engine cranking,the ignition module is bad.
EA82T runs great and then bogs down and stalls
naru replied to KristjanJohann's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Probably fuel pump or clogging in tank filter sock. Check the pressure. -
Unscrew the outer tie rod end to replace ihe inner bellows.There is no other way. Don`t mess around w/the inner tie rod.You would need to remove the boot first anyway.
90625 0018 & 90625 0020. Inner and outer
Direct replacement Ignition Coil EA81 Turbo (Hitachi)
naru replied to Non Culpa's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I`ve used the AIRTEX/WELLS 5C1017 for a while. -
+1 A good whack w/a big sledge.
Why cant I get the tie rod off?!
naru replied to Rocketdog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You could just ignore it for now. It takes a long time for the tie rod end to develop play from entrapped dirt. I have had a ripped tie rod end boot on my truck for years,but,I`m not replacing anything until it actually becomes loose.- 23 replies
- wheel bearing
- gl
(and 3 more)
Tagged with:
It won`t come apart because it is a tapered fit. Puller is best,but,hitting the steering arm w/a really BFH works everytime.Use a big one and hit it hard. Don`t hit the tie rod end. Avoid using a pickle fork,if possible.They often rip the boot.- 23 replies
- wheel bearing
- gl
(and 3 more)
Tagged with:
timing for 9.5:1 compression EA82T
naru replied to BoostedBoxer421's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Less than stock. It is more about avoiding detonation than air/fuel ratios. How are you monitoring the knock sensor? There is a reason turbo cars come w/lower compression. You should run the highest octane you can get. I expect it will run fine until the meltdown. -
Fix the EGR. http://www.tuneruniversity.com/blog/2012/05/dont-block-or-remove-the-egr-valve-its-saving-you-money/
1993 Loyale 4wd wagon no spark
naru replied to motorrad2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the fuse only has power on one side.it is BLOWN! -
84 GL Rough Idle and low oil pressure
naru replied to JustGo_GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Inspect the spark plugs and/or remove plug wires one at a time to find the dead cylinder. -
Got power on both sides of fuse 12? If so,I suspect the diode is open or poorly connected. Presuming the fuse is OK,you could run a new wire w/an inline diode between fuse 12 and ignition relay G/W to bypass the existing faulty circuit. -
You are wrong on several points. The ignition coil is not continuously powered.Power is switched by the ignition switch. The ignition relay is not powered by the ECM.It is the other way around. Power from fuse 12 flows to pin 38 and also thru the diode to the ignition relay coil and pin 28.
