naru
9
Everything posted by naru
Red dust means the spark is grounding out inside the disty. The dust is oxidized iron from the shaft/advance weights. If you look carefully,you will see small eroded areas. I would check plug wires,plug gaps,rotor and cap. Doublecheck the shaft play too. I see this most often on GM HEIs where the spark fires straight thru the rotor plastic.
naru replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1000 Van Where it all began. 1966 FF-1 Van -
HEY! Come back here! -
ADVICE NEEDED re: flywheel/TDC position
naru replied to NickNakorn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Disty 180 degrees out? -
EA-81 Turbo FF (Front engine,Front drive) I like the OBRUT. -
Rarest Old-School Subaru Part or Option?
naru replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here are a couple of canidates. I`ve never seen this optional coil and igniter for ea-81s before. Anyone know what it is? Heavy duty transistor ignition? Capacitive discharge? Multi-spark? Part# 457296001 for 17,500 yen if I read correctly. Also the optional ea-81 limited slip differential. #722040000 for 68,000 yen. -
Anybody have a factory skid plate? -
The Subaru space suit has to be pretty rare. Socks and was towel too. I`m liking the look of the Mechanic jumpher. -
EA82 T.P.I. has no top end power
naru replied to Hatched's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I`d double check cam timing. Fuel pressure while driving too. -
Assuming the timing belts are correctly installed,I suspect the ignition timing is incorrectly adjusted. Did you connect the timing connectors at the fiewall? Move the disty very much? -
3/4 brakes arn't bad,wait what?
naru replied to Uberoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You got a 3/4 one for an 81 brat,not a 13/16 one for an 81 hatch. -
Retarding timing excessively increases temps possibly making dieseling more likely. Idle speed too high will too. If it still diesels w/correct timing,idle speed and idle mixture adjustment,try one of these: http://www.ebay.com/itm/Weber-32-36-DGEV-ICU-Idle-cut-off-valve-solenoid-fuel-shut-off-valve-DGEV-/400375516204?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d383d8c2c&vxp=mtr
Clean P-1 1500 Another P-1 1500 -
Destroked Justy I-Production land speed record holder more info http://driveperformance.subaru.com/Print.aspx?printpath=/Articles-(1)/dp41/dp41_attic&classname=custom.SDArticle -
1973 Baja 500 car -
Twin carb -
For the complete collection. They came in about 6 sizes up to 15HP. Here is a nifty Gakken brand RC one that sold very recently on ebay for $80. -
Twin carb SRX -
1600 RX/A -
Subaru snowmobile? Actually,I think they are Polaris snow machines. Polaris used Fuji Heavy Industry motors. -
These old ones are better than I thought!
