naru
9
Everything posted by naru
Ignition module in the new distributor is fried. Take it back and demand another.Be indignant. Check the charging voltage imediately after start up w/the new disty in case it is excessive. Consider bench testing the alternator first.
Feel for compression at the plug hole as the engine is rotated.Next TDC is compression stroke TDC.Can be tricky sometimes. I prefer to watch the intake valve close but that means having the valve cover off. Not sure about the sprocket holes.
Blacks to positive. Yellows and a gray to negative. Tach move while cranking? Test light on coil negative flash while cranking? Stock coil?
Rear Bearing or Differential bad ?
naru replied to abcus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1.Nah 2.Not sure,but,I think they are different ratios.Check the sticker on the cover if it is still there. 3.I would check for play in the LH wheel bearings. Sounds like one of them is loose enough to allow the shoes/pads to contact the drum/rotor when highly loaded in a RH turn. Almost certainly the rear since it has extra brake dust,noise and vibration. As rear bearing repair requires axle removal as a preliminary step,you will be able to rotate the wheel and axle bearings independently before being completely commited to the repair. -
EGR light on after installing Weber on 1985 Brat
naru replied to Tonyp5143's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is no good reason to delete the EGR. There are good reasons to keep it. Cannister can be canned. Plug the purge line. Not sure if the plugged return line w/be problematic. I`d probably unplug it. -
Incline suggests a fuel level problem. No need to guess about flooding or starvation. Next time it acts up,pull over,shut off quickly and check the fuel level in the carby sight glass(wish all carbs had those). Might need a mirror. That will tell you whether the carb is flooding or starving.
Light is unrelated to the vac lines. http://www.ultimatesubaru.org/forum/showthread.php?t=96306 -
That is a bad idea. You stand a good chance of killing the O2 sensor by spraying silicone into the intake. I`d check compression on the "bouncy" motor.
Best plan would be to leave well enough alone. Things sound about right. If you are concerned about the temporary 500 rpm idle and have an urge to tinker,I suppose you could adjust the choke housing a little richer so that the fast idle stays engaged a little longer.
84 DLs were single range. I thought digital dashes were on anything w/GL-10 trim.
Engine - wont start! After valve job and head gasket
naru replied to thedoctor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
First question.Got spark? Item in question is the choke heater. Should not be powered from the coil.Might draw too much current and prevent proper spark. Check for spark after disconnecting. -
Idle stop solenoid powered up and working?
Distributor advance repair
naru replied to the sucker king's topic in Historic Subaru Forum: 50's thru 70's
Mounting screw(s) fell out. -
It lowers cruising speed combustion temps because the exhaust gas is made up of a large percentage of water. Water has a higher "specific heat" than most other things. That means it absorbs more heat than most other things before the temp goes up. Removing the EGR w/o modifying the ignition curve will adversely affect ignition timing. EGR also decreases engine pumping losses. Subaru did not do away w/it on newer models. Some models have "internal EGR" that does the same thing w/valve timing and head design(no egr valve).
Since the accelerator pump is strong,suspect ignition. I would change plugs,measure plugwire resistance and inspect the cap and rotor.
Key won't turn car off unless alternator is unplugged
naru replied to kabarakh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
As much as I would like to take the glory,I was not the first to point out that the alternator was backfeeding the coil. Since removing charge light fuse#12(it is between the alt. and the charge light after all) had no effect I`m having serious doubts about that part of the theory. I think the coil was being backfed somewhere else. Might be able to find it by unplugging fuses etc. but who cares? Elegant solution in the end. -
There are 2 senders. Engine doesn`t care about the gauge one. Engine temp sender has 2 wires.
CTS=coolant temperature sender. 2. This is usually a leaky injector. 3.Hesitation on accel is most often ignition.Check wires cap rotor etc. 4.Could be many things,over/under fueling,vacuum leak,loose wire.... Seeing how #2 suggests a leaky injector maybe said injector decided to be very leaky for a moment.
ABS problems
naru replied to whitetm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
ABS control module. Ohmmeter will likely show low resistance between the power input and ground Disconnecting each wheel sensor is a waste of time. -
This is almost certainly a leaky injector flooding the engine. Might want to check the CTS too. I`m having trouble understanding what the original symptoms are. Hesitation on accel? Stalling? Shudder? All of the above? Year? Mods?
