Skysm182
Everything posted by Skysm182
1.8L EA82 troubleshooting
Skysm182 replied to drums_andsubarus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Timing is where i would look first. -
Easy way i have done without taking the pump off is by placing a rag around the oil sprocket and using a oil filter wrench to hold it in place while you wrench to nut off.
Sealing cam carriers to heads
Skysm182 replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Anaerobic gasket maker cures in the absence of air. -
Needed - 92 Loyale Wheel Hub ..
Skysm182 replied to GorgeSuby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Never drive in 4wd on concrete. Only loose soil, rocks, or snow. Or else you will bind up the rear differential. -
Ea82 head bolt stuck in head
Skysm182 replied to Skysm182's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Got it out using pb blaster to loosen the corrosion, constantly rotating it with a socket, and i used a punch to drive it out when i got the threads level with the head face. -
Engine is out. Head is off. I have been using pb blaster and working it in and out with a hammer. But once the threads get almost level with the head face it doesnt go any further. Will try using a punch to persuade it some more. -
While taking off the passenger head, the center bolt was stuck on there like no other. I got the bolt unscrewed and the head off (didnt damage the block threads thank goodness), but the bolt is stuck inside the head. It rotates both directions but wont come out. Any suggestions to get it out? And should i replace that bolt or clean it up really well once i get it out?
Hello all. I am looking for a specific rebuild Ea82 rebuild thread that i was following to rebuild my own engine (phone lost all my bookmarks). Original Poster had very detailed pictures of the step by step process of pulling the engine and their tear down of the engine in doing a head gasket/reseal and put back together. I remember one specifc picture of an outside picture of the engine lifted from a light blue cart. Any help is very appreciated. thank you EDIT: Just found the thread (pulling engine through the eyes of a noob). very well written walkthrough.
Sealing Ea82 valve covers
what should i lube it with? -
lots of oem part numbers in this thread here. http://www.ultimatesubaru.org/forum/topic/147766-subaru-ea-82-oem-part-numbers/ includes head bolts small and large and washers.
What is the best way to seal the valve covers. Should i go with the molded rubber or just use ultra grey? With thegrommets, should i go aftermarket or dealer?
when you re install, do you have to add new tar glue sealant or what?
How do you pull and repair the sending units? My 91 loyale always gets down to empty even though there is a quarter of a tank of gas left.
Mystery Wagon Problem
Skysm182 replied to BestCar/OnlyCar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am very interested in where this thread goes. I had this same problem this spring where i started the car, drove it 3 minutes, stopped for gas, and it wouldnt start back up til i came back hours later to possibly tow it. havent had that problem since. -
If his doesn't work get the $35 ultrapower tx96 coolant temp sensor from rockauto. That is what i purchased and received a genuine subaru part for half the price of everywhere else
Bad MPG on ea82 need help !!
Skysm182 replied to Skylar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have the oem parts numbers for the hoses that go to the valve covers. I can look them up after i get off work tonight if you would like. -
Hydrocarbon Emissions Failed
Fixed my problem by ordering a new CTS from Rockauto (got an oem one under the brand name Ultrapower for $35). Fixed my idle issues, it now idles when warm at exactly 750 with very little deviation. And now I have no codes whatsoever. Soon will take it to get emissioned for the final test. Edit: took it for emissions and it passed with flying colors. Changing the old cts fixed my high hc and jumpy idle. -
Update! Please bear with me. Got the intake off and the old cardboard gaskets off. While I was doing the intake gaskets I bought some small diameter tubing and replaced just about every small air and coolant hose in the engine, changed the oil, changed the oil pressure sending unit, installed the pcv reroute kit (thanks Stubie Subie) and changed the disty cap and rotor. Put everything back together and it started up fine. Took it for a test drive and it has plenty of get up and go. So i fixed the misfire. Got it home and checked the stored codes. When the engine is off I still have codes 11 and 13 but now I have codes 21( coolant temp sensor) and code 24 (idle air control valve). I then Cleaned the MAF with MAF cleaner. pulled the battery cables to clean them and clear the codes. Put everything back together and it wouldn't turn over at all. Went out the next morning and it started right up. Back history: The previous owner must have had a problem with the IAC cause there is a new wire that runs from the IAC all the way to the ECU. Before I fixed the intake gaskets (with the engine warm) I could unplug this wire at the IAC side and it would kind of affect the engine but only slightly. Now when I unplug that same wire with the engine warm it falls on its face and dies right away. I thought I read somewhere on here that the IAC is only meant to work with the engine cold or warming up. I think what is happening is with that the CTS or corroded wiring is telling the engine its cold and that's why its screwing with my IAC and the high hydrocarbon emissions. Just a hunch, idk. The car has always when cold idle around 1500 rpm I push the accelerator and it idles down and than slowing goes back up to 1500. When warm, the idles jumps around from 550 to 800. i need to get a multimeter and check the resistances of the cts. I want to replace 5-8 inches of the cts wiring on the harness side, can someone link me to the correct connector that plugs into the cts? I have searched but don't really know what I am looking for. Any thoughts or questions? thank you -
Be sure to check the small bypass hose from the top of the water pumps
