JWX
Everything posted by JWX
I think the wastegate pipe should be bigger, and a bit longer
12? I want me some of that
why WJM no better pistons? or is FSP a stock internals class
I'm thinking about trying it if I can see an advantege to using EA-82 stuff
INDASH VOLTAGE guage GOING WHACKO
JWX replied to CITRUSHARK's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what car is this? -
a little but not really set them side by side and you see the diffs
man those wheels really do look good on the car. I knew I shoulda kept'em
I thought divorced wastegates DPs were stupid
legacy axles should work, but they have a longer track (ie wider)
Uh oh... Spy pics of my NEW TMIC setup (56k ouch)
JWX replied to lastchance's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pics? -
more info/pics on the dist setup?
cause the engine is mounted wrong, duh! :-p TWTIWBTW
how about an RX drivetrain, with awd and a proper susp. what do those have under them anyways? is it multi link in the back or what?
two intake manifold questions
JWX replied to pyromanic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
flows better cause it is bigger at the neck (where the carb/throttle body bolts on at) same size runners and single port tho. and yes you would need to make a custom adapter. there was a guy who did it might have been on the old board. -
I thought he sold it MS and all?
or use the SPFI manifold with the webber, thats worth some ponys as the FI manifold flows better. or for the bestest one evAr use MPFI heads with a custom manifold and dual webbers. -
it was an 88 :-p
Jesus christ he said he ordered that stuff like 2 months ago.
1987 RX Turbo at the drags last night
JWX replied to BoostedBalls's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so will a stand alone, with better injectors. and you'll be able to make more power. but if the band aids work for you go for, for me they would be a waste of money. -
its all band aids, bloody band aids I say. -
what wiring? its carbed with a dist. I didn't do the swap, and he spliced in to the main harness and used the stock dash, switches for teh fuel pump, ign, and fans.
so ya I was messing with it last night when I got home from work, decieded to try and start it. no go wouldn't fire, so I get some new plugs today, get home go to test the spark re-notice the middle switch decied to flip in and turn the key it starts up. hmm shoulda remembered that switch last night. anyways let it run set the idle speed, drive it around my drive way see teh volts dropping (I took the alt off awhile ago and I don't really remember how it went or how this idler wheel went to keep the belt off of the oil cooler line coming out of the engine.) so I park it agian, walk in my house notice the smoke alarm going off look up and its full of smoke, look towards the window notice that it is still open and teh fan going full blast pulling the smoke in(I had to dump a lot of MMO on to teh enigne to free up the Apex seals) so it runs, drives now to get it into drivable shape and put some miles on it.
how to for td04 and a spider manifold on ea82t?
JWX replied to eddygordouk's topic in Subaru Retrofitting
is that with your engine? -
why do you need 400 bucks? that like a TWE header, which would flow better.
