Kurt17k
About Kurt17k
- Birthday 04/17/1989
Location
Sioux Falls
Interests
Working on cars building projects
Occupation
welder
Biography
Got into subarus about 5 years now just want mess around with head/ block swaps
Vehicles
97,98, legacy 04 forester
Kurt17k's Achievements
Member (2/11)
0
Yea i was looking at that but didnt want to do that route cause my luck is horrible. Wouldnt it leak though, with the expansion of the aluminum and whatever pipe i use being different causing it to leak water? I guess i dont have a ej22 single port head with egr off at the moment to see if its casted in or they used a connecting pipe? Something ill look into. My plan was to start with a 5/16 bit go through to exhaust then go to 9/16 bit and tap with a M16x1.5 tap.
Ok heres what i have a 93 EJ22 with dual port heads going in a 97 legacy wagon. Yes i have the wire harness/intake to make it OB2, BUT i need a egr port in the 93 heads is this possible? Or is this tapping for egr just for JDM heads? I started drilling with a 5/16 bit in drivers side exactly were a 96 EJ22 with single port exhaust has the egr tube, and i found a water jacket before i found exhaust port? Help would be greatly appreciated! Thanks and happy holidays
The o rings not leaking or the seal on the shaft. I get this slight shimmy/viberation back and forth on the steering wheel and its not the brakes cv shafts or the tires or outta balance tires. But i feel the wiggle on the output shafts are little more then what they should move and thats gotta be it?
I have a 97 legacy gt and i want to get a middle of the road header price wise. Due to the stock being rather beat. Anyways i am lookin at a obx header and it says its for 98 impreza rs with a 2.5 my legacy has a 2.5. Now will this fit my legacy? I dont see why it wouldnt but i like i said im kinda new to subarus any ideas thanks
