I'm very interested in this '$250' brake flaring tool. A guy i work with has a lot of experience with this, done a couple cars and trucks using the '$30 parts store special' I'm very much a 'high quality tools' type of person, so i'd like to use the good one if possible, but if the cheap one is just slightly more cumbersome, but still with good results i'd stick to that i guess.
do they do metric? What fittings are standard and what fittings are metric? are the threads that go into the actual brake components themselvs metric? taper seal or some kind of o-ring?
i found the 'classic tube' catalog, they seem like they really have their act together, about 20-25 bucks for each crimped SS line. thats probably cheaper than the parts store special rubber ones, eh? plus nice drawings and layout of all the fittings.
I have access to a hydraulic hose crimping machine, but its hard to find the stainless fittings. i could get zinc plated and do rubber line fairly easily, but then again the corrosion issue comes up.
having worked with both 'stainless braided' and regular hydraulic line, i'd probably choose the hydraulic for durability myself, but the fittings are going to corrode like crazy no matter what you do without stainless.
the other option would be to run all the hard lines JIC with a conventional 37 deg single flare (i have good tools for that) and crimp an AN on the wheel end of the hose, or even adapt out the brake system fittings by using an adapter fitting or drilling and tapping for a standard hydraulic part.
just some ideas... i'd like to get the whole system re-done for around $100, lets get creative!
