chadwick
Everything posted by chadwick
i collect pictures of subarus but only certain ones its my hobby i collect them and have them in a folder on my computer and use them for my screen could you send me pictures of loyales, gl10's ,regular gl's too and dl's, i find it fun to see other peoples subarus its a hobby i enjoy! thanks
hello all subaru owners i just traded a 1999 legacy outback for a 2004 legacy 35th anniversry edition sedan with all the goodies the car has only 7k on it the girl traded it in for a 2005 instead,man so nice i'm spoiled with this one. sunroof, power seat, tweeter kit,compass mirror,rear spoiler, hood deflector,rain guards,alloy wheels and my favorite color blue
91 subaru loyale 72k for sale thinking about buying it no rust or rot at all 5spd sedan when you push the 4wd button it doesn't work the garage said it was not the switch in the stick part, anyone with any solutions or answers?
these models also have wheel bearing problems to, i have seen many go on these cars, i work in a subaru dealership you will know when it goes you will here a groaning noise if you do take car of it right away, if you don't it can lead to further issues with the axle and so on, otherwise they are good little cars!!!!
91 loyale check engine light
chadwick replied to mudduck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes my 94 loyale did that the check engine light came on, it was a code for a idle air speed control valve, the car would start racing up and down then the check engine light came on, see if this is the same instance or code, this only did this now when i came to a stop at a light or just at idle -
Hello everyone happy new year! Well its just amazing the amount of headgasket issues i have seen at my dealership within the last 2 weeks with the conditioner recall, sometimes that stuff does not stop the leak.So far i have seen 2002 impreza outback sport,2000 outback,2001 subaru forester that were all leaking and the conditioner has not stopped the leak.On the other hand we just had a 1999 legacy outback towed in with headgaskets leaking also.A girl came in with a 1999 legacy sus sedan with leaking headgaskets to, her coolant resevoir was full of oil, so we told her not to drive the car. this issue with headgaskets is getting way out of control i hope subaru cures this issue, i would be interested in hearing other peoples issues they have had with headgaskets.
we had just had problems with a 1998 subaru outback we did everything from coil pack to plugs and wires to a top end cleaner to a new fuel injector and nothing worked, then we had to remove the head ,the misfire was #3 consistant. It ended up needing new valves, believe or not car ran great after that. this car had other issues to we had it for about 2 months at the dealership of course we had other repairs done and we had a second car to. the dealership was great and the mechanic was wonderful this dealership i would bring it back to any day
hey everyone thanks for the advice on doing a compression check.Today we did a compression test and everything was normal no problems. My god this one is a tuffy!!!!!!!!! The valves were checked and we had made sure they didn't drop sometimes these subarus do that. i'm thinking maybe something wrong with the head, we also checked the timing and that was ok to.Hope to figure something out, i would appreciate any more input from anyone.
A 1998 subaru outback with a #4 cylinder misfire. Replaced plugs and wires, still running bad,replaced coil pack, still running bad. put fuel injector cleaner in and top end cleaner, still running bad, replaced fuel injector for #4 still running bad. anybody with any ideas, keep in mind that check engine light comes back on with #4 misfire after you clear the code then test drive it.
torque bind is your tranfer clutches for your awd, they bind when you turn it feels like the whole car is jittering and shaking. they are in the back of your transmission they need to be replaced could be costly depending on the dealer. the dealership i work at the repair is about $900 or so, it won't go away, once they start to bind they are pretty much shot
hey i have a 1999 legacy outback that had the same problem, mine had to be replaced with a reman transmission. It was still under factory warranty. internal seal failure was the problem, on the other hand mine would race up when i would come off a hill and the the tach would be at the other side then it would lurch hard into gear. this even did it on the driveway i have an incline also. good luck!
hey how is everyone? well guys i told you that i work in a subaru dealership and we had a 97 outback with headgaskets gone, well car is doing great but, we just had 2 subaru's towed to our dealership with 1 overheating and the other one leaking coolant pretty bad. the first one was another 1997 outback with 104k on it temp needle kept pinned on hot, not good he had overheated a couple of times, so we sent the heads to be machined which are ok good for his sake so we need to put the engine back together and it should be ok!!!!!!!!!!!!!!! then another car came in which was a forester 1999 or 2000 about 90k on it with coolant leaking pretty good it had the conditioner recall but guess what this one did not hold with the reconditioner, not good. so this one had headgaskets done and all oil seals done including rear baffle plate. all of a sudden headgaskets galore we have them but not as many as now, i had known there was problems 1997-1999 2.5 engines with headgaskets but ya know its pretty bad i have worked for there for about 2yrs or so, my customers have complained to subaru and subaru has hepled them with the repair which was great. subaru is good about helping there customers. i have an outback 59k on it if headgaskets go on mine of course it will be cheaper for me to have the repair done cause i work there. so anyone want to share any headgasket stories with me let me know i curiuos to hear about it gotta go
heh very nice outback looks sharp 120k service coming up i would do all fluids, filters,plugs and wires and maybe even check on timing belt at that year timing belt should have been replaced at 105k don't let the headgasket problem scare you any car could have that problem new or used but hey good luck enjoy it. i have a 99 outback and love it!!!!!!!!!!!!
i am a extreme subaru fan! i love subarus have owned many 1986 green gl wagon with dual range 4wd 190k 1986 brown gl10 turbo seadn 2wd 165k 1988 red gl sedan 4wd 89k 1988 gold gl sedan 2wd 100k 1989 gl 4wd turbo wagon white 160k 1990 loyale red 2wd sedan 69k 1991loyale wagon gold 4wd 80k 1994 loyale wagon 4wd 123k green 1997 legacy sedan 55k awd blue now i have 1999 legacy outback 59k awd wagon white and i love it i have had many subarus some i sold 1 went to the junkyard one my girlfriend got in a accident with and it was totaled the rest still out there going its amazing! hope to have the 1997 soon when its done on the demo fleet although my friend has a 1993 legacy sedan for sale 155k only needs rear struts, but good condition. i like to know what kinds of subarus other people have so drop me a line let me know tell me about them peace out
