Charliew
About Charliew
- Birthday 06/21/1969
Location
woodland
Vehicles
I Love My Subaru
Charliew's Achievements
Member (2/11)
0
Well the hill I live on is about the steepest around. I only had time to get a set of cables for the front. Headed up hill had to slow for corners and we did the fight each inch of the way. However we diddnt have to walk so it was better than nothing
Wondering how my subi will go in the snow it is 1991 loyale wagon, 4 door, 2wd 1.8 non turbo 5spd. I bought a set or cables for the front. I`m wondering how you think it will do/what would you do, as in Cables all the way around, just studded tires or what. I will soon be upgrading but we have snow coming right now. Thanks for reading. I guess that can be my intro as well. I`m charliew and I learned to drive in a brand new 1979 brat. So that gets me in the club assume?
Got it done. Diddnt replace gear covers. Did not have to remove air conditioning comp but probably would have been easier. Diddnt tighten the crank bolt right the first time and almost made a boo boo but other thann that It was pretty easy. I had also tore my dash part looking for relays and buttoned it all up before making sure it started. So I got to take it all apart to plug in the coil relay. All in all I learned allot and I`m glad my little buddy is back on the road. Next week I will probably replace leaky valve cover gasket Thank for the help.
thanks guys, I`m reading n I have till friday so I`m in good shape
1991 Subaru loyale wagon 1.8 no turbo 5spd Background Maybe unrelated but I changed the water pump and the car ran great for 2 days after that. On occasion I would be doing 70 on freeway and it would start maxout as in That was top speed without stuttering and backfiring. Ultimatly it would slow until I had to stop. After only 1 minute with engine off I could drive fine again. Last week the distinct sound of s baby crying came from my dash to the right of the steering wheel. Not to the real problem. Was driving and aparrantly lost fire. While on the road I checked fuse. All good so it was towed home. Rechecked fuses themselves for continuity. Fuseable links are good Tested for fire from the coil and found none. The coil has been tested and is good. I also get power to the coil ******Under the coil is what people are calling the ignitor More on that later. behind the fusebox is a relay marked coil. I feel it working for what that is worth. The ecu lights up with a red light so it has power at least. ******The brown relay behind it when I first turn the key on it clicks then when I turn it off I feel it let go however if I turn it off and on rapidly it does not click. If I give it a few seconds and repeat it clicks on and then off again. The ignitin switch is good I also found what looks like a loose ground wire? which I will try to attach a picture of. Never mind I cant do images here yet. Its a black wire with the connection that looks like about a 12mm bolt should go in. There is also a bolt missing from the alt bracket and the stain on the aluminum or whatever it is matches the shape of the connector but I dont think it goes there because like I said its aluminum? The wire is part of a bundle of wires coming through the fenderwell under the window wash container and by the coil which intrigues me a bit. I will ask two questions and back off until I her more from you guys. Is there a way to test the coil relay and the brown relay some call ignition relay. Also tlittle amplifier thingy under the coil can I test it. Well thats it for now thanks for reading.
