Everything posted by ontherun987
Side marker lights won't go off
ontherun987 replied to ontherun987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it happens that often? -
Well thanks for the help , I spent 2 hour playing with it. -
My 1987 Gl Side marker lights won't go off unless I pull the fuse or disconnect the battery . I have no idea where to start with this, any thoughts?
hitachi carb - where does this part go?
ontherun987 replied to belacane's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am unsure, but on my 87 gl hitachi carb it had that little ball under the spring (looked like the one in you pic, on the side with little curl) and pump -
On the rear axle nut, do they need a torque wrench? and to what ft pounds? 1987 subaru gl 4x4 thank you
who/where do i get ea to ej swap parts?
ontherun987 replied to TOI's topic in Old Gen.: 80's GL/DL/XT/Loyales...
adapter http://www.sjrlift.com/index.php/catalog/engine-swap-parts/ea-to-ej-swap-kit-detail wiring harness http://www.sjrlift.com/index.php/catalog/engine-swap-parts/engine-wiring-harness-detail -
knocks while driving in straight line
Ordered my shoes from rock auto part #0812529 and the hardware kit from ebay http://www.ebay.com/ctg/Raybestos-H17289-Drum-Brake-Hardware-Kit-/75387644?_tab=1&_trksid=p2047675.l2644 -
I don't mind, I like watching little threads grow -
The light comes on when the 4x4 isn't engaged. I went and opened up the brakes and found this -
Is it normal for the 4x4 light on the dash to come on when I take off and then go off when I reach cruising speed? -
I looked at my ujoints today they look good, I don't know how to check the carrier bearing. I drove it today I put it in 4X4 and it felt like the rear end locked up for a few seconds, And I left skid marks in the road. Something that I forgot to mention is the my car has been siting for months, waiting on tabs. -
I did the right front cv last year, but other than that no -
My 1987 gl makes a knock while driving in straight line at about 10-15 MPH, It does sound like it's coming from the right side.It feels like I drove over something. All from CVs look good and I can't find any thing else that looks bad. I do have a bad ball joint on that side, would that make noise while going straight? Any thoughts ?
reseal motor ea82??? PICs of leaks
Like? -
I have a 1987 gl ea82. I replaced the alternator, and it ran fine for a while but my tick of death has got worse. now It seems like it is have a hard time starting. Any thoughts ?
Motor oils and brands
My famnily has always used Castrol GTX, what weight should I use? -
I have ea82, What motor oil brands and weight should I use?
Great video... Ride it till it rusts away
Cool thanks for the help:headbang: -
Is there a rebuild kit for the oil pump or do I have to buy a new one? -
Would Seafoam in the oil and an oil change help the tick? -
Thank you you all your help:headbang: I will look into the oil pump and lifters -
I have a 1987 gl with a 1.8 ea82, I holds oil but is covered in it. The ticking has gotten louder on start up, I read on here that resealing the motor would help with the tick. So with resealing, do I just replace the gaskets? Do I need to resurface any thing? Any special tools? Any other thoughts? I am sorry if these are noob questions, Thank you for your help. Here's some pics
I currently have two belts on my alternator, and order two belts when I got the alternator. I would like to keep the setup the way it is.
