Hi all. Just joined the board. Was lurking different sites, and saw that there seemed to be good help here, so here I am.
Some quick info on the car:
2000 Subaru Impreza Outback Sport
EJ 2.2 Liter 4 cylinder manual transmission
125k miles
The incident happened while the car was stopped. I went to turn the key and the engine barely started, idled very, and I mean very poorly for a few seconds then shut off. Before that, it was running fine.
I'm thinking it's the timing belt, so we tow the car to my buddy's garage and tear into the front end. Get the timing belt cover off and we see that the bearing housing of the inside idler pulley (the one with the teeth) is blown completely out. The pulley is just riding against its mounting bolt. The timing belt is not broken but it's clear from the timing marks that the engine is out of time. See attached photos.
Now for my questions. Is it possible that the belt only jumped a few teeth and that no valve/piston damage has occurred? From the photos you can see how far "off time" the camshafts are with respect to the crank shaft. Does anyone know how far off time you have to go before piston meets valve in a bad way? Also, how can I tell if I have valve/piston damage? Should I just replace the belt, pulleys and hydrollic tensioner, put it back together and just go for it?
I'm sort of lost as to what I should do. Thanks very much for your help.
The damaged idler pulley
The following pics show how off the timing is
