pliptheshevanel
Everything posted by pliptheshevanel
  1. 4wd wagon 1987 wagon. When do you think you could ship it?
  2. Mike,
    How long do you think it will be on the crossmember for my 87' 4wd GL Wagon? You can email me at brandonbelcher@hotmail.com. Thanks
  3. Okay just to clarify, we are talking about the crossmember that is made of tubing that the axles connect to right? I believe I got the moustache bar confused with the crossmember.
  4. Re: WTB: Rear Crossmember for 87' GL Wagon
    have one in WA and can ship $30
    What kind of shape is it in? Any pics? Thanks
  5. Awesome, thank you so much. I tried searching for posts but couldn't find anything because EGR has too few letters. Guess I should've mentioned that earlier too.
  6. 1987 GL Wagon I've read on here about the EGR light coming on at 60K just to remind you to clean it etc., but mine came on at 50K? My question is where exactly is the panel to reset the light underneath the steering column??? I removed the cover and looked under the steering column and could not find anything resembling the panel to reset the light. I know about the different connectors to read and clear codes, I just can't find them! If someone could please give me somewhat of a detailed how-to to find and correct the EGR light issue, I'd greatly appreciate it!
  7. Ok so I have one last question about this Weber setup. If I drive the car for 30 minutes or so and shut it off, the engine will keep turning over 2 or 3 times but it doesn't backfire? Is this a fuel mixture issue that I need to address on the Weber? I never experienced it happen with the Hitachi.
  8. Found the fuse problem. Even though the electrical connection to the choke was insulated and covered well, somehow an arc was making contact with the power steering reservoir? Slid a piece of plastic in between the choke and the reservoir, and voila. No more blown fuses. The car is running great now, better than it did before this whole mess started. I'm loving the Weber!
  9. Well this morning we fixed the problem. The vacuum we were hearing was coming out of the bottom of a black canister on the left side of the engine bay. It was routed to the front of the EGR valve and also to the manifold. Air was sucking in the bottom through holes that I suppose is a part of a reed valve system? I think it's the anti-afterburn valve from what I've read on here, correct me if I'm wrong. We removed it and plugged the vacuum lines coming from it, and BAM perfect idle. Some tuning on the Weber had it purring like a kitten and it runs great now. However, fuse #11 (IG-COIL, FUEL, ECC(IG)) kept blowing when the car warmed up and the choke opened. I disconnected the wire connector going to the choke and all was well after that. I don't know what is causing this though? The choke wire was connected onto the old blue wire going to the Hitachi carb, and the other 2 wires with the choke wire were left cut and insulated. I don't know why it keeps blowing, and if I can't figure it out I won't be able to choke it. Any ideas?
  10. The EGR valve is working correctly, I've put my finger on it while revving the engine and it moves like it should. It's not stuck fully open and when removed, the engine doesn't run any better. It sounds like something on the left side of the engine bay is sucking serious air, but carb cleaner or starting fluid has found nothing! I don't know if it's just the sound from the belts or what, but I can't find a leak. Could it possibly be ignition related? Low rpm idle problems, like it's not firing on all cylinders? I mean the car has less than 50,000 miles so I wouldn't think it would be a disty or anything like that. There wasn't any play in it. ughh
  11. The car is a 1987 GL Wagon, EA82, 4X4 w/ manual transmission, 48,000 miles. I posted a few weeks ago about a sudden problem with the car idling. It was running great and one night I parked it for 2 hours. Came out to start it up and the problem began, wouldn't idle. Car would start up and do the normal 2000 RPM surge until I depressed the accelerator to set the choke, and then it would die. To keep it running, I would have to give it gas and brake/gas it when I stopped to keep it running. The car would run fine once I got it moving though with no problems at all. I have spent hours and hours on this forum just searching and reading related posts on this issue. I have replaced fuel filter, PCV valve, plugs/wires/rotor button/cap. I've used almost a whole can of carb cleaner checking for vacuum leaks with no luck. So basically I figured it was the Hitachi carb, because it gets gas fine but won't idle and has a TERRIBLE miss in it under 2000 RPM. So based on what all i've read on here about the Hitachi problems and how the Weber is superior, I ordered a kit on Monday and installed it today. We installed the new Weber and everything went great. Dented the power steering reservoir to allow clearance for the electric choke, plugged all vacuum lines, and routed the PCV valve to the Weber air breather with 2 T's, as per what most everyone on here does. Hooked up vacuum to the disty advance and the EGR valve. What happened when we started it up? Same thing with the Hitachi. No idle. The car starts up fine and shoots straight to the 2000-2500 mark, then if you touch the accelerator it will die and not idle. We went by the manual on all the tuning procedures with no luck. If the RPM's drop under 2000, the car still has an awful miss and spudder to it. Checked for vacuum leaks again and found none! We put a cork in the hose going to the ASV for now, could this be the problem? If the ASV were to be bad, would it still matter now since the Hitachi is gone? We tried advancing the timing by turning the distributor some with no luck. I assume the timing is good due to the car running fine up to 80 MPH that I've hit while having these problems. I'm puzzled on this problem. Can't find any vacuum leaks and the Weber is working fine, just no idle. The car was given to me for free, so I don't have anything in it other than the Weber and the tune up stuff, but I'm not looking to put much more into it. If I can't get this figured out, a for sale sign is going on it and I'm moving on. If anyone has ANY ideas or have had this same problem, please hep me out on this one.
  12. Thanks for the help guys. I ran a bottle of generic fuel system cleaner through it as soon as I got the car 2 weeks ago and put another bottle of Lucas fuel system treatment in it last week when I filled it up. It ran great until I started it up Sunday night. Today I went to change spark plugs and wires in it then noticed I don't have the right socket for the plugs! I did get it running long enough to spray carb cleaner all around the intake and around every hose going to the carb and didn't find any leaks where it's sucking air. It starts up fine, but as soon as I put it in gear it wants to stall out unless I get on the accelerator and even then it sounds like it's on its last leg. Tomorrow I'm calling a garage that's pretty close and taking it there (or having it towed there). It can't be anything major, but I just don't have the time or area to work on it (parked at an apartment complex). I'm thinking it may be the fuel pump though, but it gets gas fine at start up????? I'm stumped. I'll let you guys know how things work out.
  13. First off, let me give a quick background of the car. I was given a 1987 GL Wagon a couple weeks ago from my girlfriend's aunt because she can no longer drive it, and I desperately needed something easier on gas than my truck to get back and forth to work. The car only has 47,000 miles on it and ran great for the 2 weeks I've had it. The problem began yesterday night. I went out to start it, and it fired right up and idled around 2000-2500 RPM like always. After a few seconds, I pressed the accelerator pedal to lower the idle speed as the big warning sticker says. Anyways, the car just bogged down and died. Tried it again, high idle, pressed gas, sputtered and died. Now when I start the car, it idles hard around 3000 + RPM's and sputters and dies once I press the accelerator. Today I changed the fuel filter with hopes that was the problem. Still getting the same problem. The car is getting gas just not after I press the accelerator. I can sit there with my foot on the pedal and let it warm up, but it sputters and has a pretty bad miss in it. I don't know much about these engines other than having a 2000 Legacy a few years ago. I'm assuming the fuel pump is OK, fuel filter is NEW, air filter is OK, and that's about all I know. Tomorrow I plan on changing the spark plugs, wires, and cap with hopes that fixes the problem, even though I'm sure it won't. I'm almost positive that the plugs in it are more than likely the originals. This car is in GREAT shape, been garage kept and ran every once in a while. It ran great up until yesterday. Also, I noticed today that the hose connecting the breather to the exhaust was cracked and not even connected. This couldn't be the problem, could it? Maybe the heat isn't getting to the choke or carb, therefore it won't run on its own? My Silverado has the same hose going from the manifold to the breather to help warm the engine quicker. That's why I don't think it's the problem on the GL. I'm clueless about it now. Someone please lead me in the right direction and many thanks in advance!
