About 96LegacyEJ22
- Birthday 10/14/1989
Location
Portland
Interests
Cars, Women
Occupation
Lot Attendant
Vehicles
92 Legacy, 96 Legacy
96LegacyEJ22's Achievements
Advanced Member (3/11)
In the second video it's between 14-16 which isn't normal around here. We are anywhere between 500ft-1000ft here. My buddies frankenmotor sits at a solid 20 and my brothers 93 leggy turbo also stays at 20. I have retimed the engine 3 times now. And about the vacuum leak I have smoke tested it over and over again and can find no leak. It acts like a vacuum leak. But I cannot find it, if that's the case.
Video never seems to come out good. Anyways. Motor stalls hard when coming down from revs and sometimes just shuts off randomly. I checked my timing and it is half a tooth off on the drivers side. But if I were to adjust it at all it would be just as far off on the opposite side. Did a leak down test and all are between 15-17%. So they are all consistent. When all the timing marks are lined up is it normal for the intake valves to be open on cylinder 2 and the exhaust open on cylinder 4? Got one step colder plugs and gapped them to .28 with no change.
So I have been playing with engines on my 96 Legacy L for quite some time. Some of you know, some of you don't. I have been having weird issue that I cannot seem to figure out. To start off. I had a 12:1 compression EJ25D/22E combo with delta cams. This motor ran like a top for 8k miles. Yes 8k. Motor was un-tuned on 92 octane. It was an experiment. Ran great till the day I blew a hole in the #4 piston. I then built a standard frankenmotor. You know the one with stock EJ25D pistons and cammed Ej22E heads. Stock head gasket size on both of these motors. This motor ran great until about 15k miles. Then it started to burn oil and all that jazz. Also started to idle really rough. I had scored the cylinder walls on the last motor when installing the pistons so I figured that would eventually happen. Decided it was time to build another short block. So I built an EJ251 with ACL race bearings and NPR piston rings. Cylinder walls are great on this motor. Short block is solid. Got this motor put together and used an STi HG when doing this motor. Same heads as I started with. I still have the same rough idle. Sporadic idle sometimes but not all the time. However always rough when warmed up. If the car has been sitting over night and I go to start it in the morning. It starts like it normally would but slowly revs up to 1.5k RPM's (cold start idle) but while it is doing this it is misfiring. Every morning this happens. About 30-45 seconds later this stops and the motor clears up. Wondering if my issue is in the heads. Since that is all I used from the last motor. So far what I have done. Crankshaft Postion Sensor Camshaft Postion Sensor Checked timing Replaced coil pack NGK plug wires New plugs Coolant temperature sensor Smoked tested the intake. No vacuum leaks. Replaced the MAF with a known good working one Replaced the IACV with a known good working one. Replaced the ECU Oxygen Sensors Cleaned the fuel injectors Replaced fuel filter Fuel injector o-rings Probably a few other things. Next step I am going to do a Leak Down Test. Just here looking for more ideas because I am just about out of them.
Frankenmotor question. Searched.
96LegacyEJ22 replied to xbeerd's topic in NA Fuel Injection Engine Tech
Yes it does. We figured around 12:1 compression with Flat top pistons, OEM Head gaskets and the Dual port 2.2 heads.
