amr9000
About amr9000
- Birthday 10/31/1993
Location
Fresno
Interests
Cars, Mountains, Hobby Grade Cars, Technology of almost any kind
Vehicles
96 Impreza Outback (MT)
amr9000's Achievements
Advanced Member (3/11)
0
danbennett2u was right, it was the dust shield of a foreign spindle, hammered it out and all was well.. then I had a slight squeak from the same area but like gratefuldude said, it seemed to go away after a little driving.. hoping that I can get the speedometer cable to work! I can't get it smogged unless it does cause it causes the engine light..
Hub/Assembly
amr9000 replied to amr9000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
actually I found it's cheaper to just buy a used spindle.. xP -
I just drove mine for the first time!! I finished overhauling the entire thing down to every nut and it is Gorgeous (in my eyes at Least) it's a 96 impreza outback.. I do sadly have to replace One wheel stud and it will be officially, mechanically done.. I also deep cleaned the entire interior, dash, seats and all (including taking anything apart that would come) and it shall be registered and road legal in the weeks to come. I Love This Day!
well I called the tranny shop because there's no point in fixing it if it's still under their warranty anndd they told me to drive it first because sometimes general weird things can happen when it's in the air, "vibrations etc." so I figure I'll just put it back together and drive it around the block.. see what happens..
I didn't know there was a viscous in there... but it's not in the oil, I just drained the oil down anyways, but it is a consistent metallic and kind of.. machined sound, like there is one point of the driveshaft hitting one point around it... though it makes the same noise with the shaft out.. another piece of info is that it doesn't make the noise in the same way in different gears in fifth it's almost always there fourth it lasts longer 1, 2 and 3 it hits for a second while giving it gas and reverse doesn't at all also is it possible the bearing on the output of the transfer being dented would have this effect?
so I just got my new jdm tranny into my impreza and got everything hooked up and it started making banging noises.. from the transmission, I asked a couple people and they talked about not having any load on the wheels and shtuff and possibly that having no oil in the transfer.. does anyone know if the transfer carries it's own oil? and how to deal with that if it does
Hub/Assembly
thanka john shawn I'm not sure how big my compressor is but I use my impact for anything the breaker bar just can't touch fuzpile, I thought porta power was a lift or.. metal.. bending machine..? what're you suggesting exactly
