Like I said in the original post, the fusible links tested good (I was getting 12+ volts on the running end). Checked voltage at ignition and was only getting .6 volts. All the fuses were good. Took a look at the ground and hot battery cable connections, ground looked good, hot cable on the starter end not-so-much. Cleaned the starter post and decided to just replace both battery cables..............started up just fine! I don't quite understand this since, as Cougar mentioned, the stuff that wasn't working (hazards, brake lights, door locks, etc.) run off unswitched power. That's why I was concentrating on the wiring between the battery, link box and fuse panel. Does this (Loyale) system require power to the starter to close the loop to unswitched sources? That's the only thing that makes sense as to why a bad starter connection would prevent power to unswitched sources.......but still doesn't make sense. Anyway, thanks for all the suggestions.
