roadglider08
About roadglider08
  • Birthday 01/05/1949
  • Location
    camano island
  • Vehicles
    I Love My Subaru
roadglider08's Achievements
Newbie
Newbie (1/11)
0
  1. Your right of course......I set asside each pulley as it came off and installed new ones that came in the kit with new hardware. The tensioner pulley did have the washer installed on it. Also there was an instruction sheet that was very clear as to which pulleys got what and as to the torque. I examined the old belt yesterday and it had slight wear on the rubbing edge but that was it. My plan is to monitor the belt condition over time(pulling the covers every 2-3 months)
  2. I verified the pulleys and washer installation plus proper torque on all fastners. I did replace the aft belt cover on the right side due to being torn up and now I realize it is doing almost the same thing but not nearly as bad. The car runs great and the belt is not damaged other than one edge rubbing into the cover but nothing visible on the belt. Thanks for your help.
  3. The car had a very leaky water pump. So while I was there I replaced the T belt which came with all new the pulleys.
  4. Bought the car used and the person we purchased it from had a Japan Domestic motor installed. The kit I used came with T belt and four new pulleys. I made sure to install washers under appropiate pulleys. The cam pulleys look stock. The ones on the right side are a plastic material with the cast hex ridge and a pulley fence only on the forward side. The pulleys on the left look stock and have guides on both sides.
  5. I have a 98 Legacy GT with 2.5 JDM engine. Installed a new T belt with new pulleys and on start up timing belt rubbed the inside cover on right side of engine. The pulleys on the right only have a belt guide on the forward side...... Wonder if there is something different with the JDM engines? thanks :)
