el_freddo
    128
  1. I’m trying to track down some factory part numbers that are USDM specific. If someone could pls PM me a USDM VIN for a manual Gen1 or 2 Legacy that would help me out heaps! The VIN details won’t be going any further than me and will only be used for parts searches online to get the correct bits I’m chasing. Cheers Bennie
  2. @SaltyMike- is this surging also associated with difficulty starting the EJ22? Asking as another thread about a hunting idle issue reminded me of a hard starting a fluctuating idle issue I had with my EJ22 many years ago. I had several codes show up, CTS, TPS, knock and I think an O2 sensor issue. It was an absolute dog to start, idle was poor at best and it ran like a dying dog under load. I’ll give it this though, I was still able to reliably drive places once it started, just it was missing a few ponies in this situation. I changed all the sensors at once rather than chasing down what the real culprit was. At the time I was living in our alpine area and working outside in the snow at the remote staff carpark wasn’t a time I was going to individually swap and test which sensor change made the engine operation return to normal. Once they were all swapped, the TPS “gapped” and an ECU reset all was well once again! Cheers Bennie
  3. I had something similar and these were (from memory) the things I swapped out: - cleaned TPS - new coolant temp sensor - new knock sensor I don’t know which one was the issue. I’d be looking at the coolant temp sensor and TPS closely. I’d say if you don’t know the history of the coolant temp sensor, get a new one fitted. This is the video I did back then, while a bit different to what you describe, I reckon it’s related. Mine is a Gen1 EJ22E in an L series with a cut down wiring loom like what you’ve done in the vanagan. Cheers Bennie
  4. Got any codes associated with the idling issue? Or any codes at all? No vacuum leaks present? They’re a couple of things to start with Cheers Bennie
  5. EJs can have a slightly blown head gasket for ages before it’s picked up! Sad you’re moving the vehicle on. A HG swap isn’t too difficult, a second hand engine could be easier if a HG job is outside you’re scope of confidence. Cheers Bennie
  6. Thanks for the complement. I’m not much more than a backyard mechanic as I like to do things myself. I might go a bit further than some though - and thus I share what I’ve learnt/found along the way All the best with that spark plug, it sounds nasty! Cheers Bennie
  7. I’d think if there was a hole there it would push out coolant until the level in the radiator couldn’t get to the hole any more. This would do two things - first, the cooling system would never pressurise, leading to poor cooling performance. Second, reduced coolant volume will circulate the coolant quicker through a cooling system at or above normal operating temp. And if that’s your original radiator you’ll probably find it’s full of crud. If that hole isn’t your issue the partially blocked radiator could be. Last thing, do you still have the air dam/engine undertray piece still fitted? This is designed to develop a low pressure system in the engine bay at speed to draw air through the radiator. Without this you could find your engine running warmer than normal in hot weather but I doubt it will allow the cooling system to boil. Cheers Bennie
  8. How does this work? Factory heat shield then the blanket over the top? Seems like that would be a super tight fit for the blanket. Cheers Bennie
  9. How much different is the JDM unit to the USDM unit?? If you’ve got the factory engine management that matches the engine type and all sensors are working properly I don’t see why it wouldn’t pass a smog test - assuming the test isn’t a standardised test for all engines in a particular class. Will the XT6 “mature” and avoid smog testing at a certain age? The EZ has to be better in the emissions department compared to the factory EA82 or ER27! My 20c from across the big ditch. Cheers Bennie
  10. Good to hear that these were replaced. When buying genuine cam cover seals I’ve always needed to order the spark plug tube grommets separately. Next question: how did you clean out all the oil that was in there from before the grommets were replaced? Not an easy task! I had my engine on the floor when I did this and I still found it difficult! I used some torn down rags made into strips, shoved these in and twisted them around the spark plug as much as possible using a long screw driver, then did it again with a fresh rag strip until I was confident the tube was pretty clean. Then I removed the spark plug and used a fatter rag strip to clean out any last bits. I could’ve used some Metho at this point to give it a thorough clean but I don’t recall doing that. The results? Well the project is still sitting there waiting to be finished off and used so I can’t report on it yet. Cheers Bennie
  11. When you replaced the cam cover gaskets did you replace the spark plug tube gaskets at the same time? If not, your old ones in there are hard and leaking. Pretty common. Cheers Bennie
  12. Your front and/or rear struts are the issue. Check for leaking oil if they’re original. If aftermarket they’re gas and die quickly from what I’m told. The oil units can leak but still work ok for some time then they result in the vehicle being really unsettled after hitting bumps. If only the tests are dead the giveaway is the vehicle will feel like it tries to crab when in a corner and you hit a bump/pothole/ripple in the road - quite unnerving! A shot ball joint or tie rod end would result in excessive tyre wear and the steering being floaty left and right - meaning very little feeling left and right that moves the car in the same direction. If this is the case you’ll find yourself always correcting the direction of the vehicle like they do when “driving” cars in movies when filmed in the studio… you may also experience a lack of confidence in your steering at speed. Cheers Bennie
  13. So weird seeing this with a flat roof. All of our wagons over here in Oz have the “high roof” with the bump just above the front seats. That’s our standard roofline here! Some inspiration for you: The pic on the trailer isn’t its actual ride height, it’s strapped down nice and tight giving it that awesome lowered look. You can see the roof bump too Cheers Bennie
  14. Just Subarino’s tricks Can’t go wrong there. Cheers Bennie
  15. Get the family member to organise the deal Or the seller is on holiday/out of town for work, I’ve had this but not the lack of communication. Cheers Bennie
  16. Enjoy the install. I’ve got one in a diff ready for Ruby Scoo when the time comes. Got a few bits to sort out before then. Hit me up if you have issues fitting the stub axles Cheers Bennie
  17. Do some research but I believe the STi pink springs from the GD platform were a popular option, as were king springs but I don’t know what’s available through them anymore. Impreza struts could help too but I’m not certain on this. Cheers Bennie
  18. Sadly I bet wreckers hear these commitments all the time only to be put out by ppl that are a no-show, stuffing the way they manage their business. Cheers Bennie
  19. Use the ignition wire that powers up the relays and ecu off the EA ignition wire via a fuse. Never missed a beat for me in my conversion and I was driving that daily for the best part of ten years until recently. Numbchux’s write up gives detail on this I believe. Cheers Bennie
  20. Using the same cone washer? That’ll do it. Replace the cone washer and the concave/convex washer with the replacement hub. Also check the spline on the driveshaft is still good. Cheers Bennie
  21. Take the console and matching shifter etc if you can. As Steptoe said, grab the rear diff to be sure about having the correct ratio. The ‘87 could be a 3.9 ratio depending on whether it’s a series 1 or series 2 (“facelift”). The ‘89 will be 3.7 ratio. Cheers Bennie
  22. You don’t need luck to get married! Just someone else that agrees to and that you want to marry All the best when the time comes! Cheers Bennie
  23. Partsouq has the first part number 001 as unavailable but were $US25ish (plus postage) and the 020 at just under $US17 plus postage - which usually starts at $US17 to Oz. It’s worth adding other bits you need to the order. Warning: it’s dangerous I’d say many of the Subaru EJ setups use this relay design across the range up to some mid to late naughties model IF they changed how they do things. They rarely fail and there’s plenty of them out there. At the end of the day, you could probably open the relay up to clean the contact points and go again Cheers Bennie
  24. Get cracking!! Make sure the centre diff is good in the AWD box before installing it. Make sure it can differentiate smoothly and that the spider gears are the same colour all the way through. If it’s been rallied with the centre diff open I’d say the centre diff will be worn out or cooked. You'll need to remove the rear housing and remove the centre diff to get a good look at it. Very easy to do with the gearbox out of the car and VERY VERY easy compared to removing the rear housing on the PT4wd box! I hope it’s good. AWD is awesome compare to front wheel drive Cheers Bennie
