126
5 speed dual range fulltime 4wd questions
el_freddo replied to IROCDUDE89's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Agreed with FerGloyale. I believe there is the FT4wd box in 3.9 ratio but it’s a difficult one to find. If you want a better diff ratio the only way to do it is to customise the pinion shaft. I’ve got 4.111:1 in mine and it works a treat. I do wish I put in the extra effort/coin and got 4.44:1 though. If you do got for a 4.xx ratio you’ll need to also shave the crown wheel to clear the larger L series low range gears. Mince you’re running one of these boxes there’s a coupe of “rules” to keep the centre diff happy: 1) always run tyres of the same make/model with the same pressure! 2) once on anything remotely loose/slippery LOCK THE DIFF! This will reduce the possibility of one axle spinning faster than the other. Locking the diff in these situations will prolong the life of the diff (which is hard to find in good condition these days!). Cheers Bennie -
@czny it helps to tag @GeneralDisorder in your thread as this will throw him a notification, Just the same as you’ve been notified of the mention I’ve used here In my opinion, there’s nothing wrong with the EJ22 heads for this setup. What I presume GD was saying is that there is a better combination that gives better power etc. But ultimately, you’ve got to work with what you’ve got - or are willing to get. EJ22 heads may flow less and mean less overall power, but it’ll still move a vehicle at the end of the day... Cheers Bennie
To keep costs down I carefully purchased my engine from a parts yard. It had 127k km on the clock. Turned out the clutch was completely toast. Then I “bench” test as I wanted to make sure my wiring worked properly - and to assess the head gasket situation as I really didn’t want to do that job already, mainly due to cost. Here’s the first start up, exhaust mid section poked out under the rear door of our shed: Worked a treat! These head gaskets survived a 5min run at 4K rpm in soft sand on a beach with the temp gauge at 120*C (mechanical temp gauge plumber into the coolant out pipe in the heater circuit). I also froze the block in the first week of moving up to the snowfields - the replacement coolant didn’t have any antifreeze properties in it! Head gaskets survived after some very careful engine start, runs free seconds, sit a few seconds, start, run a bit long etc and repeated this until the radiator hoses were liquified. Then drove it to the season staff carpark where it was a much more sheltered. Left it to thaw out then swapped the coolant out. Four years later they let go! Anyway, bit of a long story there! I guess I’m saying enjoy the exeperience. Make some informed decisions and that’ll help with a successful conversion Cheers Bennie
From what I’ve read (not made a frankenmotor - yet) if you want to use the ej22 heads the 99 EJ25D is the bottom end to use. The reason for this has something to do with the block basically being the stronger EJ251 block but with the EJ25D pistons. The crank and rods are basically the same from what I can gather. Bolt all that together and your EJ22 management should handle the job well. Just run the best octane rated fuel you can get your hands on Have fun! @GeneralDisorder - what years is the EJ257 found in? Cheers Bennie
el_freddo replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
@sparkyboy - they’re the original “Scorpion” rims by scorpion Subaru back in the day. There is a very similar rim available nowadays that’s based on this rim. Can get them in black or white and are probably very light compared to these rims. I’m really digging the look of the brumby with these rims now! Cheers Bennie -
Everyone is for their first! Don’t focus on the number of wires and how they’re jumbled up. You need the following wires: - permanent power (fused) - back up power (fused) - starter wire (use the EJ’s starter setup, you just need the wire to the starter and the other to trigger the starter circuit (fused) - fuel pump wire (fused from memory) - vehicle speed sensor wire (VSS), hook into the speed sensor in the back of the instrument cluster - AC relay wire (good if you’re going to run AC) - thermofan relay or cut off wire (earth switched) From memory that’s it. The rest of the wiring plugs into the ECU or the engine and sensors etc. Cheers Bennie
All good mate! imageshack photobucket Theyre two suggestions. Others may know of more... Cheers Bennie
Buy a whole vehicle - ensure it’s running! Pull the harness and cut it down to just the engine management wiring. Test run this with the engine still in the donor vehicle. If it’s starts and runs without any codes you’re good to go with the rest of the conversion. The gearbox and driveshafts aren’t touched unless you fit the EJ AWD box. Cheers Bennie
New boots: The “other one” (offroad L series) is partially covered in mud atm. Cheers Bennie -
need 90-94 loyale rear wagon gate
el_freddo replied to mtnman38's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I’ve only known the rear glass in the tail gate to be rubber mounted. No glue used until the legacy era. Cheers Bennie -
That’s your issue. Use a tyre calculator thingy and you’ll get two different rolling lengths/circumference/diametre. Not by much but it will count. Just like putting the wrong diff ratio in the rear end. One set of axles is trying to rotate faster than the other one. It’ll run just fine in 2wd, no doubt about that. But in the slippery stuff either the front end will drag the arse end around or you’ll have a tail happy arse end that’s trying to get past the front end - much like a highly excited dog running around. Cheers Bennie
First Time Subie Owner - 1986 XT Turbo
el_freddo replied to Whitestorm's topic in Meet n' Greet. Your USMB Welcome Center
@Whitestorm - no worries in asking. My conversion was done over ten years ago and it’s still running sweet. And I reckon mine is on the cheaper side as I took my time to do some research as to what I wanted/needed. I purchased parts when sales were on at the parts yards. I also put my L gearbox in the front EJ cases to avoid an adaptor plate and EA flywheel/clutch setup. All up, I probably came in at $1200AU. This was spent over a 12 month period with all work carried out by myself. That’s an educated guess. It could be less. Actually, this is what I remember: engine $125 - 50% sale loom donated ecu slipped in with the engine gearbox $175. Had an ea box spare. Mods = my time. New seals ?? timing belt ~$250 rear seal $30 efi pump $150 efi rated rubber fuel hose ~$50 (18 months later after lift came) exhaust 2.25inch cat back $450. Seems I was about accurate not including odds and ends like male/female spade connectors, aftermarket fuse panel, loom wrap and tape... all prices are in Australian dollars no doubt your market will be different and I’m sure thing’s will have changed somewhat since my conversion. And what I’ve done isn’t the only way to do it - others will have experience to share and there’s are already many threads about it on the forum I’m about to crack into the same thing for my brumby soon. Just waiting to hear from the engineer Cheers Bennie -
That’s fair enough whitestorm, I’ve ditched mine for an EJ22. A wrx engine and box basically bolts into one of these. Custom tail shaft and gear linkages are needed and a cut down wiring loom. But overall it’s a pretty easy conversion. Cheers Bennie -
Insurance can do that to a bone stock setup too! Cheers Bennie
- 72 replies
- longtravel
- ea81
(and 3 more)
Tagged with:
I love how you guys can just go and do this then drive! I’d have to get engineering approval just to even think about welding in mounts for that rear end let alone modifiying the length of the arms! It’s looking good too! Mean with those tyres Cheers Bennie
- 72 replies
- longtravel
- ea81
(and 3 more)
Tagged with:
Welcome to the forum! With the knock, it’s definitely knock and not lift tick (aka the tick of death or TOD but it’s actually harmless). Cheers Bennie -
Hey Zeekyal, sounds like a beast built for a purpose! For photos use a third party hosting site and drop the image codes in here to show your pic Cheers Bennie
If the crack between the valves is so bad it’ll work it’s way down the exhaust ports and open up into the coolant passages. But that’s typically seen in the turbo models. Head gaskets are the better option for this issue if the other is crack heads... Cheers Bennie
The 2L phase 1 Foz box got the respectable 1.447:1 low range. This will literally drop into a phase 2 dual range box. If running 4.44 diffs, some crown wheel grinding work may be needed, I’m not 100% sure on that one. Having read a number of Subaru manuals when building my dual range box, there’s a phase 2 box with this low range from the factory. I believe this is from or in some European markets, maybe in the Russian market too. I’ve personally never seen one of those. Another way to do it is what I’ve done with my gearbox in my L series: Find one of those L series AWD gearboxes with the locking centre diff. Ensure the centre diff isn’t shot. If it is walk away unless you want a parts box. Best way to check them is have the centre diff removed and check the backlash. Select the desired diff ratio you want to run. You will need an EJ crown and pinion gearset of the desired ratio. You use the EJ pinion shaft with the EA AWD pinion to cut and shut a hybrid EA AWD pinion shaft (longest produced by Subaru) with the EJ pinion gear at the other end. Be specific with your measuring to ensure you get a pinion shaft of the same length back. L series 1.59:1 low range will drop straight into this gearbox. Downers on this build: - it’s expensive and replacement parts are hard to find - in the states you’re stuck with the EA AWD drive gears as the upper gearset is dual range specific - you would still need to run an adaptor plate and EA flywheel/clutch After doing all of that you would probably be better off importing a low km dual range phase 2 box and putting the “awesomest” Subaru low range in. There are plenty of threads on the web as to how to do this (I recommend the write up by Phizinza on his forum offroadingsubarus.com). My L AWD centre diff lock is mated to the back of a phase 2 dual range box from a Foz with 4.111:1 diff ratio (wish I got the 4.44:1 diffs but $$$$s), I’ve matched the speedo drive gear so my speedo is bang on accurate and have the L low range with auxiliary oil feeders over the low range gears for cooling purposes more than lubrication reasons. For my build in the L series this is a great setup as it matches diff ratio to tyre size (27 inch), bolts up to the EJ, uses EJ clutch and flywheel - and the back end of the gearbox bolts into all the L series bits it needs to without any mods. Awesome box, I love it! I hope that’s not as clear as mud! Cheers Bennie
Interesting convo fellas! One other thing about these electric vehicles - battery replacement cost was mentioned. There’s another issue with the batteries - we don’t have any way of recycling them, or safely disposing of them. So no emissions while driving (yay!?) but what cost at end of life of the batteries?? And if two sets are required for the life of the vehicle? There are plenty of other fuel sources available that are renewable - cost will be an issue but if it comes down to it this will be used if we’re up against a wall so to speak. Also there was an Aussie fella that developed high effiencey steam engine or something to that effect. I believe it essentially ran on water - I don’t know how but I do know this isn’t really a good thing in Australia with our lack of water! Anyway, Edward Pritchard (spelling?) is the guy that did it. He made two running vehicles from Fords. The first only had “two gears” - forwards and reverse! The second was more conventional with a manual gearbox. One was stolen and never seen again. The other I don’t know what happened. Everyone he demonstrated this technology to shunned it and it sent him bankrupt. I’d love to see how this thing works as it intrigues me. It also shamed me how people can treat others when they’ve got some top ideas! Cheers Bennie
