el_freddo
    126
  1. Be aware that if the module or spark dies completely and won’t intermittently run it means you have a dead coil AND and dead module. DO NOT replace the module without replacing the coil first. A dead coil will instantly kill a new module. Ask me how I know... Cheers Bennie
  2. Dizzy ignition module or a lot of shaft play that’s not allowing the module to detect the trigger wheel or the points to open sufficiently as required. All the best with it. Cheers Bennie
  3. You can remove the glovebox then the fan to get at the ducting. If you have AC you won’t get very far and that’s not removable without pulling that system and possibly the dash out in the process. Cheers Bennie
  4. This is the “toilet bowl” gasket: As you can see the gasket isn’t sitting right. On the underside of the throttle body there’s a groove this O ring style gasket sits in, mine doesn’t really sit as it should. I’m not after new nuts - I got the manifold separate to the rest of the kit so any extra weight was stripped off for the international shipping. I’ve just let this part of the project slide atm. As for after market dizzy, no idea there sorry! Cheers Bennie
  5. Probably minutes to that speed when in low range. When in 4wd normal highway speeds should be achievable. But only do this in the wet otherwise you could break something in the 4wd drive train taking an intersection. Cheers Bennie
  6. @Subuhrue - I’ll be checking in don’t stress about that! I’ve got my main wiring loom installed after checking a few wires that didn’t marry up on their labels compared to the wiring diagram. Ecu is going into the glove box (right hand drive so this works well). I’ve got my inlet manifold gaskets, O2 sensor and everything else I need including an already modified dizzy with the EA81 drive gear fitted. What I feel I need is that toilet bowl gasket. Mine is enlarged. If you happen to find one can you grab me one as well and I’ll sort something out with you? I also need to source some nuts to fit the throttle body back onto the intake and get a thermostat housing (at m&d’s an hr away). Then it’s a case of putting it all in, fitting efi rated flexible fuel hose, O2 sensor and see if she’ll fire up Just have to see out the end of the school year first and get a few other projects out of the way... it never ends! Cheers Bennie
  7. Don’t worry about the extra gaskets, the EA82 is bound to leak after the first start up. Cheers Bennie
  8. He’ll say the EJ conversion isn’t worth it these days and to sell up to get a Gen2 or 3 platform where parts are interchangeable and still supported blah blah blah... I too am doing the spfi conversion. In. Very. Slow. Steps. If you can call them steps. Hold up atm is motivation to add some wiring and sort some nuts to put the throttle body back on the inlet manifold. Also I’m after the “toilet bowl” gasket as the one I have is enlarged Cheers Bennie
  9. I can’t fathom how you guys over there manage to break so many of these oil pumps. I’ve done three or four oil pump removals each from a different engine without issue. All the best with finding one over there! Cheers Bennie
  10. If you’re running an oiled k&n filter you may have coated the AFM in oil and restricted its ability to properly do its job. It may not throw a code either. Paper filters are the best yet option in these! To check for codes: remove driver’s kick panel above the driver’s feet area. Up near the steering column you will find a set of plugs, one set green, another set black. If I recall correctly, plug the black plugs in together (if you can’t find them they could be taped to the main loom. Take a torch with you and look around in that area). Once you’ve got the plugs connected, turn the ignition into the ON position without running the engine. You should hear the fuel pump cycling on and off. If not, disconnect the black plugs and connect the green plugs together. On the instrument cluster the check engine light will flash. Long flash for tens, quick flash for ones. If no codes it will give a series of quick flashes to indicate the market designation of the ecu. The ecu will show all stored codes then cycle through them again until you turn the ignition off. This allows you to check and triple check your code recording. These codes will then relate to specific sensors on the engine. These are the sensors to check up on/replace. The list of codes can be found on the forum somewhere or in a basic maintenance manual such as Haynes or Gregory’s Knowing thatyiure running a K&N filter I reckon this is the issue. Cheers Bennie edit: duh, just looked at the link from wtdash AFTER writing all of the above out...
  11. Checked for codes? It could also be a dead/dirty throttle position sensor or air flow meter. Hows the air filter in this thing - fresh/dirty?? Cheers Bennie
  12. I’m guessing that you only go wheeling as day trips, close to town, in a group that makes recovery/fix easy? I’ve never bent a front or a rear strut and have been pretty loaded up. I can’t afford to break stuff out bush, especially if help is more than a day or two’s walk. That = very expensive just to get back into town let-a-lone all the way back home if parts aren’t easily accessible. Cheers Bennie
  13. Got a blocked exhaust/dead cat converter? Cheers Bennie
  14. You could have a dead bearing too. Definietly jack the suspect wheel off the ground and rotate it. I reckon the issue will become pretty obvious. Cheers Bennie
  15. No. Subframe swap required = custom work. New shaft cheaper and easier. Cheers Bennie
  16. What?? This isn’t self sufficient house plumbing and tank water storage. Wrong forum? Cheers Bennie
  17. It wouldn’t be the first one. There was a Gen1 done near me but I can’t find it on the web. I found this build though: https://forums.nasioc.com/forums/showthread.php?t=2393987 And I found another article about a turbo’d build where the author fairly flogged boosted Subaru and their fanatic owners. He clearly didn’t know the ins and outs of Subaru life... Back to the OP - you can also achieve lift with a subframe drop - aka a body lift. Cheers Bennie
  18. I’ve not ever heard of anyone replicating a factory Y pipe for the EA81 or EA82. If you require a new cat, it’s a custom job for the Y pipe - or delicately mod your existing Y pipe to use a single in/out cat converter. Cheers Bennie
  19. I’ve done it on mine. The crank seal was SOOOO old and crusty that a bit broke off and it leaked over a certain rev. I limped it home at 80kmph hoping the oil light didn’t come on. That was a very nervous 28km. I did as above - crank seal and oil pump reseal at the same time. Cheers Bennie
  20. They’re also used as a dampener if the strut comes close to full compression. Good if you’ve got a loaded vehicle on rough tracks, and has been great on my lifted L series that doesn’t have extended swing arm bump stops... I doubt you’ll need them on your 2wd. Cheers Bennie
  21. Heater circuit hose from the water pump. Check it out for pin holes. Cheers Bennie
  22. Mine only does this in summer, even then, it’s random. Cheers Bennie
  23. Hopefully there’s no damage to the ecu. I’d also look into why the fuel pump isn’t working as it should. Could be a dead relay or a dodgy connection - or again, a fuse. Cheers Bennie
