126
The factory VF2 or what ever you have from the EA82 will probably instantly boost then run out of puff in no time. Get an EJ spec turbo like a TD04. Cheers Bennie
That’s just my gearbox build for my off-roading purposes with the addition of AWD for everyday driving. Ironically now that I have this gearbox built I don’t drive it anywhere near as much as I used to! It’s also got a front LSD - a very worth while effort too! All up I reckon it’s probably cost me about $2500AU over time in collecting parts etc and paying a dude to put it together the first time in phase1 cases. You could do yours for the cost of a gearbox and some fab work. If you’re good with a grinder and welder that shouldn’t be outside your ability. The front shafts will need to be changed to MPFI L to fit the EJ box. Cheers Bennie
You’ll need an “EJ” spec turbo. Something like the small TD04 should do the job nicely. Mid you’re looking at 8-10 psi you’ll probably want to swap pistons over to turbo units. Also look at intercooling, as this will help with detonation Ive not done it but a mate has boosted an EJ22e with a SC14 supercharger and runs 5psi with an intercooler. It’s pretty awesome/scary for a permanent front wheel drive! Goes awesome off-road too! Cheers Bennie
How many new oil leaks did you find after this? Cheers Bennie
Popping out of gear under acceleration
el_freddo replied to Skierman19's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Or a broken retainer spring inside the gearbox. There are three or four 10mm plug bolts on the side of the gearbox close together. These have the retainer springs and balls behind them. Use a hooked piece of wire to pull the springs out. Compare them all together - they should be the same size. Check what GD mentioned first as these are easier to do. Cheers Bennie -
You’ll need custom: - Prop shaft - Gear selector linkages - Gearbox crossmember or an XT6 one may do the job, I’m not 100% on that though... The AWD with ej22 is well worth the effort. If running 27 inch tyres get a box from a forester as this will match the diff ratio to the tyre size I’m running a bitza box - phase 2 EJ dual range front cases, L series 1.59:1 low range with auxiliary oil feeders, SG drive and reverse gears, L series centre locking diff and matching rear housing, custom pinion shaft for 4.111:1 diff ratio (wish I had 4.44) and a 27 tooth speedo drive gear to pull my speedo back to proper accurate And I’m running 27 inch tyres with the EJ22 Cheers Bennie
1984 GL Highway + hills = top speed of 45-50 mph
el_freddo replied to Subuhrue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
First I’ve heard of this for an L series! Our have one in the Y pipe and a resonator type muffler in the middle then the rear muffler. Cheers Bennie -
Simple Lift 88 GL Wagon
el_freddo replied to Lilblusubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
^ that 2 inch lift would be a strut only lift. Which means you won’t have any down travel left in your suspension as you max out the cv shafts. Cheers Bennie -
It’s not the valves clattering - it’s dead hydraulic lash adjusters that aren’t holding their oil pressure. The remedy is to replace them or have them serviced, someone will know. I can’t remember those details as I’ve done the most common and ultimate performance upgrade for an L series - an EJ conversion As for your low oil pressure, pull the pressure relief valve’s spring and ball, clean them and their “place of residence”. Fitting a 2 or 3mm spacer between the spring and the retaining bolt can help with any loss of spring tension too. I’ve done this twice without any issues. Cheers Bennie
In the L series?! That must be a Californian spec thing as I’ve not know Subaru’s to have two cat converters until maybe Gen4 (AUDM though). The other issue could be a problem with the regulator in the trans. My first thought was a blocked exhaust but the fact that it’ll rev to 4000rpm says otherwise - unless it’s in the early stages and is load dependant rather than rpm dependant. Cheers Bennie -
To be honest there’s really no way to do it without changing or modifying the steering linkage. You could do strut lift but kiss the longevity of yourCVs good bye! Cheers Bennie -
Exact details of the model in question would be helpful. Certainly start with the fusible links and go from there Cheers Bennie
Voltage drop to fuel pump
el_freddo replied to soobie87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
@soobie87 - did you get the issue sorted? My thoughts would be the fuel cut relay/engine revolution sensor box. It’s a black box somewhere above the driver’s feet. 8 pin plug from memory. You should be able to throw a jump wire in to fire up the pump whenever the ignition is ON. Only recommended to do for diagnostic work. If the box is dead get another known good one Cheers Bennie -
STOLEN 1988 Subaru GL Wagon
el_freddo replied to 88SubieSnack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bugger mate. If she’s thrashed I hope the damage is only in the engine and not the body etc. And I really hope you get it back and the waste of space get what’s coming to them. As a coincidence my mother in-laws targa brumby was broken into as an attempted theft (second time in a year). Very lucky. Cheers Bennie -
Shifting in and out of 4wd
Yeah Bugger the 40/50mph stuff. I’ve slipped into 4wd from 2wd at higher speeds than that (100/110kmph) without issues. Just do it in a straight line. With the tyres, if you’re running different sizes or even same size, different brand/tyre model you may have binding issues that will lock it in 4wd - or make the car feel really unstable when that binding tension is released through one wheel. Not fun on snow I can tell you that! Cheers Bennie -
When shifting from 4wd high to 4wd low ALWAYS use the clutch! And it’s best to shift into the next higher gear if on the move Cheers Bennie -
California in about 2014 looking at the OP. Cheers Bennie
