el_freddo
  1. A back up plan would be a second harness Don’t take what GD says to heart. He plays with the new stuff and seems to have little time for others starting to play with the older stuff... and seriously GD? More fun LS swapping an f150?? Where’s the Subi in that equation??! It’s not even part of the initial question!!!! Argh!! Do your research, learn along the way and take your time with the wiring cut down job. If you get a donor vehicle, pull the wiring, do the cut down then test run the wiring on the engine while it’s still in the vehicle. Once that checks out without any check engine lights etc, then proceed with the engine removal and the rest of the conversion. Cheers Bennie
  2. Welcome to the forum Giles! Long time no hear (I’m not on bookface)! I hope you find your answer, I’d want to do the same too Cheers Bennie
  3. Just be aware that you *might* need to also replace/modify the front panel that the headlights mount to. Modifying the original grille with the quad lights would be way easier. Someone will know more about this mod... Cheers Benie
  4. el_freddo replied to czny's topic in Off Road
    Even so, I’ve been blinded plenty of times with LED bar weilding vehicle’s that just don’t see the oncoming vehicle with dipped headlights... or sometimes with high beams on (enter high beam wars - where I think they work out their lights are still on high beam). Cheers Bennie
  5. Short answer... No. Even moreso if you know nothing of spinning spanners or reading/following wiring diagrams. Either the EJ NAs or the turbo engines will require a wiring loom cut down and an adaptor plate. Go the turbo route and you’ll have to notch the engine crossmember (or find an EA turbo crossmember) and think about gearbox upgrade thoughts too. Once you’ve done one it’s pretty easy Cheers Bennie
  6. el_freddo replied to czny's topic in Off Road
    Down with LED and HIDs! Halogen all the way for me. And what’s with the 55w globes? I’ve got 130w globes in my driving lights. You don’t need much more than this in three or four lights! Added that the “cool white” light is more like a blue light, it’s a very unstable light wave and thus is why they look so glary to oncoming drivers - but also look good to the driver as a driving light, they’re not getting all the thrown light back to them. Cheers Bennie
  7. Going by what 3pin said, it could be a leaking injector or two. Other thought is the Idle Air Control Valve is dodgy or incorrectly adjusted. Throttle position sensor could be cleaned up and reset. Have you checked for codes? Cheers Bennie
  8. Old fuel could be your issue. It certainly doesn’t help! My RS turbo liberty is waiting for some work. It won’t start without starter fluid OR putting a wad load of fresh fuel in the tank and cycling the fuel pump to get the fresh fuel to the injectors. Cheers Bennie
  9. Try checking fuel level in the tank then confirming that the fuel pump runs. It could be a dead efi pump. Does it start with starter fluid? That will tell you there’s a fuel issue. Also check all fuses... just in case it’s that simple. Cheers Bennie
  10. Ah one of the elusive fin tailed brumby/brats! You’re probably the only one here with this extended tray brumby/brat/MV! But definitely not the only one here with a brumby/brat/MV Loads of info for anything you need to know Cheers Bennie
  11. Only thing I do after scraping off the old gasket is to wipe the mating surfaces with a white spirit like mentholated spirits. Then gasket on and bolt up to required torq specs. Cheers Bennie
  12. My aftermarket gauge is T’d off the factory oil light switch point. It works a treat and is well worth the effort in my opinion. Cheers Bennie
  13. Knock the two roll (or cotter) pins out. Use the correct sized punch as the inner pin passes through a hollow section in the diff stub. Get this wrong and you’ll be in a whole world of hurt. I’ve been there, done that. Get the inner CV cup moving on the diff output spline as these weld themselves together with rust if not removed “often”. Once that’s moving, jack up the rear wheel on the side that you’re removing the CV shaft. Remove the strut mount bolt and swing the hub down lower to release the CV shaft off one set of splines. The other side should just pull out. Install is the opposite of removal Cheers Bennie
  14. For the snorkel I’ve used the Pajero NJ NK NL snorkel on my L series. With some sand and a heat gun I was able to bend the elbows back to meet the A pillar and still look tops. I’m not 100% sure how it would look on the MY body though. Here’s mine for comparison, my edges are squarer than the MY. I’ve properly used it once with the bow wave water 3/4 of the way up the bonnet Cheers Bennie
  15. This one is factory turbo with WIAC intercooler. 2L engine. The US varient is the Legacy SS from what I understand. Cheers Bennie
  16. This is sad. Better idea, sell the RX7!! Seriously though, you’ve gotta do what’s best for you and your situation, even if it makes a few hard board members shed a tear or three Cheers Bennie
  17. Here’s a suggestion... don’t get airborne!! There’s no traction when airborne and to me (maybe a few others too), traction is what off-roading is all about! Cheers Bennie
  18. Nice ride. The slow start up could be simply due to not being started for some time I hope the getting to know you process goes well! Cheers Bennie
  19. My two old skool subi’s together, now sporting the same rims together but with different boots. It took me a couple of days to fully come around with the new look of the brumby but I’m really digging it now! Can’t wait for some planned upgrades on the brumby, but I am really enjoying just driving it atm! Cheers Bennie
  20. Looks like it’d go like a cut snake! We need more pics of this thing once it’s outside! Cheers Bennie
  21. Ok, got pics! This pic shows just how long the L series AWD locking centre diff pinion shaft really is: The EJ pinion shaft ends behind where the second straight splined section is. The OBX LSD is up front. The L series low range side gears are sitting where they would be with both cases joined together. You can see how close this comes to the LSD housing. You might also make out the shaving of the LSD retainer bolts, if not, here's a better pic: Locking centre diff, you can see the dog clutch in front of the diff: Here's my first modified pinion shaft with it's very crappy weld job. Apparently it spent the first part of its life behind an STi turbo engine in a brumby. I guess my little EJ22 L series was too much for it in some soft sand at Lancellin when it let go (we were loaded up for our trip out west). No shaving of the crown wheel in this pic. In this pic you can see the shaving on the outer edge of the teeth on the crown wheel: Low range oil feeders for cooling of the low range gears on long hill climbs - works a treat, I have no whining with my low range: For the EA application that's probably about all the pics I have to share. The others that I have are specific to mods required for the EJ dual range. All of the above pics are of my L AWD locking centre diff gearbox with a phase 2 (8 bolt) EJ gearbox I hope that answers a few things for you IROCDUDE89! And I understand if there's any wet undies, really though, it's kind of expected Cheers Bennie
  22. That’s right! So your mechanic probably didn’t check that or remove the flex plate from the donor engine. I’ve also seen a cream coloured plastic plate as well. Cheers Bennie
  23. 1988 was a good year: I’m not sold on the drugs being good fun! But I do agree about the collecting of cars and parent’s lectures... I just wish I lived closer to m&d’s place where most of my cars are stashed! It’s pretty awesome of you to collect, fix and “re-home” these awesome Subarus! Gotta keep them alive so the aftermarket parts industry keeps making bits! Cheers Bennie
  24. Just make sure that RX box is AWD if that’s what you want. Over here it was pretty rare for an RX to have an AWD box! I know they’re standard in the RXII coupe. We didn’t get them over here Cheers Bennie
