126
The '88 is a good ride
4X140 to 5X100 adapters
el_freddo replied to 83subaruGLchick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
And in English?? I don't understand why all the back spacers - what are they exactly?? why not run the EJ front struts, brakes and hubs? If you do the rears properly you'll be upgrading the brakes to that of the EJ donor. Best practice is to match the front brakes from the EJ donor vehicle. Cheers Bennie -
Skishop, the ea81s didn't have the twin port like the EA82 MPFI. The twin port bit usually referred to the exhaust ports if I'm not mistaken. The EA82S is said to be a real screamer and a few levels above the normal EA81. by the look of that engine you'll need the bell housing and oil filler neck as a minimum to fit it to a vehicle. Best of luck with what you do with it! Cheers Bennie
push button Loyale stuck in 4x4
el_freddo replied to fishstix's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've never heard a whooshing sound when locking or unlocking the AWD box, and it uses the same system to activate the diff lock as the single range does with engaging 4wd. if you jack a wheel and get under the vehicle (with a jack stand for safety) you should be able to move the engaging arm manually with some effort and feel it click and hold on the opposite position. To verify it's worked spin the lifted tyre (do a rear wheel). If you can't turn it you've locked 4wd in, move the arm the other way and try again with the wheel test. If it is still in 4wd I'd say an interal retainer pin for the engaging fork has gone AWOL :/ All the best with it. Dual range is where it's at for sure! Cheers Bennie -
If your dash warning lights are glowing or flickering it'll be the alternator with the issues. Replace it and you *should* be good to go. It is odd that once warmed up the issue goes away. The only other thing I can think of is cleaning out your IACV and see if that makes a difference. Any stored codes to give a clue as to what to look at? Cheers Bennie
Have you checked the front diff oil level? if it's low it could cause this whining noise and it may go away once it's at the correct level. If the front diff is the culprit and become worse, it'll be easier to fit a new transmission in there. If it's a rear diff they're relatively easy - just swap the whole diff I'm hoping for you that it's a wheel bearing or something simple over a transmission swap... Cheers Bennie
Which one to use is a bit of a punt. If the heads are off you could throw in new rings (won't need a hone, there's an article floating around that explains why). I'd also be getting the crank at the point (TDC and BDC) when the crank moves but the pistons barely do the same - then rocking it "back and forth" rotations as vigorously as possible feeling and listening for any bottom end knock. It's not an iron clad method but it's better than nothing and will show up any seriously bad knock. Cheers Bennie
@MariaB, have you thought about looking into the clutch packs as suggested by ShawnW in the first post? I'm guessing this is an automatic transmission issue as no one has piped up saying their manual is doing it - and a manual doesn't use clutch packs for the rear drive. All the best MariaB. I hope you get it sorted! Cheers Bennie
If it starts as soon as you're moving or very near to it then it could be a wheel bearing or a diff. As you roll over bumps a bearing (and a diff to some extent) will momentarily change pitch. If it's Uni joints in the drive shaft you'll have via ration typically under a certain load or at a certain speed. Above or below this speed it will usually disappear. And it may be accompanied with a rumbling like sound. Cheers Bennie
While everything points to a clutch issue also rule out a chewed out hub spline. If you can rip the hand brake and have the car idle in gear you can have someone check to ensure the castlated nut on either hub isn't spinning. If one of the nuts are spinning you'll need a replacement hub, new cone washer and possibly a new drive shaft if its splines are chewed out too. If there is no nut moving action then it's definitely the clutch Cheers Bennie
Repair mistakes and blunders
el_freddo replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Gannon that lower piece looks good. I'd be trying to shave those end flanges down to keep a lip for hose clamping grip. I'll have to look into these. Cheers Bennie -
Yeah nice trick! I need two 30mm to 40mm adaptors iirc... Might have to go custom made :/ Thanks for the info! Cheers Bennie -
While physically the same and it will bolt in there are potential differences in gear ratios, speedo drive gear and most importantly the diff ratio. These differences are due to the outback having a larger diametre tyre than the legacy. But it'll bolt in no worries Just swap in the rear diff or split the two boxes and swap the gearbox diff ratio (would be easier to source a good working order replacement outback gearbox) Cheers Bennie
Blown threads on cam seal cover
el_freddo replied to kmpdx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the thread is into the plastic baking plate I use cheap cable ties. If into the block, it'll be trickier to sort out as the cable tie trick won't work and I doubt you'll have much wiggle room for a timesert repair depending on which bolt is the issue. If we're talking cam covers then that's a whole other game! Cheers Bennie -
A mate of mine did that when changing the oil in his patrol... $90 of new oil all over his garage floor! You only make that mistake once if at all I reckon! The above red piece, is this an adaptor with one side a larger hose size than the other, or just a trick of the camera? If it is an adaptor, where did you get it from? Cheers Bennie -
A late bloomer
el_freddo replied to SuzithewildSubi's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the forum Dylan. Post up some pics when you can! Cheers Bennie -
She looks sweet as mate! Have you gone for a cruise with the roof top removed? They used to have a bag to store it safely in the boot from memory. There may be some tie down straps in the boot too. Keep the pics coming when you can and look after that beast! (can we get an engine bay pic please?) Cheers Bennie
EA82 5MT into EA81 Brumby grumble
Front dippery sliff? DO IT!! So worth the effort! Cheers Bennie -
How far between those houses? Urban town or rural setting? Rural setting could be a very long walk home... good to hear the box works sweet. Now wait for rain and take it for a spin in the wet Cheers Bennie
