126
I noticed a change in fuel use but I put this down to running the wrong 5th ratio for the EJ, even though the diff ratio was matched to tyre size. When turning my theory is that there's more friction in the centre diff doing it's thing. Other than that there's really not much difference as mentioned by Gannon Cheers Bennie
EA82 5MT into EA81 Brumby grumble
el_freddo replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Person I'd be cutting the linkages rather that the body work these days. I don't think the lever mount plates are different between AWD and PT4wd. If there is a difference it'll be due to the centre diff. Cheers Bennie -
Happy with home rebuilt rack EA81
Jono, you're a tripper mate! Cheers Bennie -
LSD was standard on the RX's. Only the RXII had AWD from factory I believe. LSD optional on the GL-10 or the GTs. Not stock on the GL or DL, I'm not even sure if it was an option on these models... Cheers Bennie
82 glf recently bought have questions
el_freddo replied to Dustin297's topic in Old Gen.: 80's GL/DL/XT/Loyales...
And that's for the love of the vehicle GD. My $500 L series (12 or so years ago now) isn't quite in the same category, but I've definitely spent more on it than I purchased it for - but she's modified, reliable and does what I want plus some at times. Dustin, if you're going to restore this hard top and know what you're doing mechanically etc, now is the time to do it! Also don't be stuck with just sourcing bits in the states if need be. Cheers Bennie -
XT Turbo Recovery/tow points?
el_freddo replied to waterpoloman13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you can't find a tow hook, wrap it over the engine crossmember Cheers Bennie -
All 36 mm hub nuts same torque?
I've always done the front and rear up the same. No torque wrench used, just a 3/4 inch breaker bar and "some body weight" Cheers Bennie -
I reckon this is the first lifted Gen2 sedan I've seen. Looks mint! Cheers Bennie
Good effort Jono! I'm wanting to do the same and was wondering if this job you did was on a manual rack or a power steering unit. Sounds like your brumby has copped a fair bit of loving in the front end work department! Cheers Bennie -
1992 Subaru Loyale yay? Or nay?
el_freddo replied to Winterpie0220's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good point. Even though I spoke about that earlier I forgot that they're at college Cheers Bennie -
And hence we march towards automated vehicles and are already seeing vehicle management systems so integrated and complex that it's almost like you change radio stations and you have issues! Yes I know economics play a factor into this. I know I'll be "staying back" with the older Gens to avoid programmed obsolescence of newer models. Passion for the older stuff helps too And in saying that GD, I realise you're running a business and I'm not. I guess this is why I find your advice so brutally black and white at times that can be disheartening to someone that's new to mechanical stuff that just wants to learn. And how will restorations of modern classics happen? My dad still keeps his factory restored 1929 Chev going without great issue. I can't see these models being quite like this. Cheers Bennie -
Seems like you need to run a certain cam grind from delta cams to get the best from this build. Do some reading, drop thread links in here and hopefully it can be worked out for your setup. I reckon the EJ253 (going by an EJ251 with a sports exhaust that's in the family) would be a good engine and upgrade over the stock VW donk in there atm. A fella I know over here has an EJ22 in his '80s kombi (T3??) and he loves it, so the 2.5 should be even better I reckon. Cheers Bennie
Hey Bob, I've replied in your other thread - but finding out that one cylinder is down on compression that throws a red flag for me. How do you know that the issue is a valve? It could be the piston, rings or worst of all the bore. You can certainly build the franken motor you talk about but I don't know how well this will run as a result as I've not built one of these engines... Yet. I'll leave off here for others to add to. But like I've said in your other thread the ej22 intake, heads, sensors and timing gear will bolt on and run that ej25 block. I'd hate for you to put it all together only to find an issue with that cylinder that's down on compression. Cheers Bennie
Dohc will be the EJ25D Sohc is either the EJ251 or the EJ253 depending on the year. Being that yours is a 2002 model year (going by AUDM) it should be the 253. Either way it's the sohc setup. Subarus are like Lego. All heads are interchangeable - but to what sort of performance to expect depends on what's used. The only issue is that you have the 251 or 253 I've read that these blocks are not great for the franken build, only the EJ25D is the block to use (but I could be wrong on that. @GeneralDisorder will be able to clarify). To get that engine running at the very least, use the '97 heads, intake, sensors, timing gear (including the sprockets/gears/wheels - what ever you want to call them). Again, I reckon GD will be able to advise if that setup will work or not. Cheers Bennie
Finding the Right CV Axle
el_freddo replied to Brianmitchtay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There was no marking balls for me, those little mongrels went every where when I pulled the joints and cages apart. I did make an effort to keep the inner and outer race and balls separate to each other. Anyway, I'm going with new aftermarket shafts that shouldn't be cheap Chinese junk. Wish me luck. Cheers Bennie -
Interesting. All GTs over here are twins... Cheers Bennie
Seattle (Rat City), '86 GL Owner
el_freddo replied to TheRustyWolf's topic in Meet n' Greet. Your USMB Welcome Center
Ooh I love that colour!! neat head unit setup. I used a block of wood, got some filler to smooth it out and never finished it... It's been 13 awesome years Cheers Bennie -
I should send my shafts over to you as this trick hasn't worked for me But they keep on trucking even though they're noisy as hell Cheers Bennie -
Couple questions about 83 4wd transmissions
el_freddo replied to ErikAnderson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Shame you're not near me, I've got two sitting around and another three in parts cars over here (in Oz). I know shipping to the states would be the better part of $1000AU... Not worth it Look around, you'll be surprised what's hiding out there. Have you put up a wanted advert on the site? Cheers Bennie -
I did my EJ conversion while at uni. I searched for parts on my holidays, did my research of wiring etc between assignments then put it all together in my final year over the mid year holidays If you retain the factory gearbox you'll need an adaptor plate and get used to spinning the front wheels off the line if you're not careful! Or swap in the EJ AWD box, but lose the dual range in your case due to USDM AWD EJ boxes only being single range. Really though, getting the wiring cut down and working correctly is the biggest hurdle in this conversion in my opinion. Cheers Bennie -
1984 Brat push button 4wd not working
el_freddo replied to Subarute1984's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So I'm guessing auto as you haven't definitively said so. If this is the case ignore my post as this only applies to manuals from the L series - I thought yours may have had a gearbox conversion done. Best of luck getting your ride sorted! Cheers Bennie
