126
Is that rust or dirt in the seam behind the spare tyre? If it's rust (doubtful looking at the rest of the vehicle), get on to it as it'll work it's way right through that whole seam from left to right. Once it really gets a hold it's super difficult to sort out. Cheers Bennie
Both of these sound like the old L series auto box failures - the diff loses oil, pinion bearing runs dry and dies. The pinion shaft then walks itself into the diff centre. Can be a very nasty way to stop your car! I'd be keen to see some autopsy pics to see what was causing the clunk. Cheers Bennie
- 44 replies
- Drive shaft
- Axle
(and 4 more)
Tagged with:
How Much Transmission Oil?
el_freddo replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How many miles on your 32 year old subi? My dad's 29 chev hasn't had a gearbox oil change in 40 years so it must be good stuff right?? Maybe, maybe not - it's only done 11,000 miles in that time. So without the miles travelled, what you're saying doesn't really hold much weight. And I bet if you opened up your gearbox the internals would be covered in a grey layer of crud. Most boxes do... Cheers Bennie -
I've done several rear wheel bearings, no press used for the stub axle or bearing running surfaces. Stub axle removal = a hard wood block and a mallet Bearing running surfaces = 50mm towball and a mallet Works a treat. Cheers Bennie
- 12 replies
- 1
- Suspension
- Maintenance
(and 1 more)
Tagged with:
Thanks mate, this is the first I've ever heard anything about the Subaru gear oil being specially formulated for the synchros and hypoid diff gearset. I've been running Penrite 80w-90 (from memory) without issues. Interestingly, the phase two box doesn't have that second gear cold shifting issue... Cheers Bennie -
I'd love a 4wd button gear knob. For now I've got the rocker switch mounted on the console to lock the centre diff. And as Goyle said, the vacuum diaphragm setup on the single range PT4wd L's is the same unit as the AWD ones. Grab the solenoids and vacuum lines too Cheers Bennie
If you're sucking cabin air for radiator cooling you'll also be sucking in dust and other rubbish you really don't want in your cab. Fresh air would be best and also much more freeflowing than that of sucking cabin air. As for pipes to the radiator(s), some sort of solid pipe like steam pipe would do the job. It could take some serious knocks and not split or pinch. Cheers Bennie
You could use an EJ dual range cable setup for the diff lock... Cheers Bennie
Got a pic as to how this is stuck in there? I can't picture it myself having being lucky enough not to experience this (touch wood). Cheers Bennie
GD, what's so special about the Subaru oil?? Cheers Bennie -
94 ej in Vanagon dies w/o notice
el_freddo replied to blurat1's topic in Vanagon Conversion Discussion
Also check/replace the main power relay (brown unit). The can do funny things to the ECU. Other thing that comes to mind is ensuring your cam and crank angle sensors are bolted in properly. I once had my cam angle sensor wiggle out and it cut all running ability of the engine. A bit different to your problem but worth crossing off the list Cheers Bennie -
Easy: side mount the radiator on the side wall in the panel behind the seats/under the rear window with air ducting out the back of the vehicle, create an opening to the outside world with a grille/fins/air scoop. Could run a radiator each side of the vehicle and use an oil cooler in one for the engine oil (if the auto cooler is up for that sort if pressure - cold starting oil pressure could be an issue with that distance to travel come to think of it...). Dad did the same in a mk3 fastback that he dropped a rotary into. Looked mint and worked well. Cheers Bennie
If you're concerned with the centre diff check it for backlash. It shouldn't be much but really I don't know the exact specs. I've got one that came in my original box that has a quarter inch play in the input shaft. Not good. I've been told this is the worst anyone has seen before they grenade. I'm yet to work out how to reduce this - I'm not in any rush as it's not needed atm. If I'm on the computer I'll upload some pics detailing this. As for the locking lever being left to float, there's a descent stopper built into it do it's unlikely it'd engage randomly. With the rear case removed you should've been able to check the dog clutch for damage - it's a pretty chunky dog clutch so I doubt there will be any... Cheers Bennie
LED and HID conversions are my pet hate - especially the blue hid lights (factory lights included). The driver might like them, but as their oncoming road user coping their lights I can tell you they're all blinding, especially since many of our roads have small bumps etc in them changing the pitch of the vehicle so the lights look like they're actually flashing you. Something you don't get with halogen lights. Anyway, arguement aside, this is how we do better lights in Australia - leave the low beam alone if it's aimed right etc: ^ Holden VT with the driving lights. Two 100mm and two 150mm units with 130w halogen globes. Liberty got an upgrade, see below... The goal is to throw as much light down the road as possible. The earlier you can see the roos the better off you are. Plus many ppl think it's ok to drive down our country freeways with their highbeams on. These ensure you're the reminder... And I'm not into LED bars either - too blue in colour. Once a warm white light is available I'll probably look into them further. Cheers Bennie
Correct. There are many conversions on the forum. Most typical one is the ej22 from the gen1 or gen2 liberty. If you go this way try and get a good running car as you'll have all the important bits to make sure you can get your car running with the EJ. It's a lot of work for just getting rid of the lifter tick though. And to do this conversion reliably you should put in some engine maintenance too. Cheers Bennie
Any play in the bearings of the idler or tensioner pulleys? That's what I'd be looking at... Cheers Bennie
5MT DR 4WD reverse protector ?
el_freddo replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have a look on ebay. I'm sure they're still available. As for PH... Who cares? Cheers Bennie -
I dropped an OBX in the front of mine. Been going very well for about 5 years or so now. Only downer is the stub axle. I don't know how to change this or if it's possible. Shoving a 25 spline cv cup on the MY shaft has been known to work. Cheers Bennie -
So it's been about 5 years on this build... Any updates/further pics? How's it all running? Cheers Bennie
If you do this again I highly recommend dropping a front LSD in there while the box is split Cheers Bennie
