el_freddo
    134
  1. The gear lever arrangement needs to sit up a lot higher, just saying in case you haven’t realised already. Just out of shot at the top of the pic is usually a single stud that’s unused. This is where you’d make a plate to mount to this stud and the two studs on the bottom of the gear lever as seen in the pic. The L series used a bracket that had a rubber bush built into it to reduce drivetrain noise transfer to the body too This is one conversion I’ve not done yet but believe it to be a very worthwhile swap. You’ll lose the Massey Ferguson highway tractor vibe and feel like you’re actually driving a modernised vehicle. Cheers Bennie
  2. I believe they don’t. Different hole size to snug them into the gearbox mount from what I recall. Easy to work it out if you have the two available to play with. Cheers Bennie
  3. @idosubaru- the EJs have their VSS on the gearbox from the Gen2s IIRC. So depending on the models you tested in a run without the instrument cluster, they may have been fine. The XT6 ECU is probably too dumb to do much about not having a VSS to reference… @SaltyMikethe brumby only came with that cluster you found online. Our units were never factory delivered with the longer cluster and dashboard, they came in the coupes (I’d love one of these but hen’s teeth now), some sedans and the touring wagons which went to the digital dash at some point. Afaik none of our MY/EA81 clusters came with a built in VSS like the MPFI L series vehicles did. Cheers Bennie
  4. The EJ251 is an awesome engine to run once you’ve swapped the HGs to the MLS type. The statement about needing HGs more often is bogus unless you keep reinstalling the factory part number referenced by the VIN. Using this part will just keep the same issues reoccurring. If your foz has the security system with the transponder component in the key you’ll have to find out if the ECU, transponder chip and security module need to be swapped as a group. Swapping the ECU could cause the engine not to start due to the security system. The EJ22s are available in Oz up to the last Gen2 Liberty model in ‘98/99. From there our Gen3 models came out with the EJ201 (from memory) and EJ251. Have you double checked the cam belt timing “to be sure to be sure”? Any vacuum leaks, cracked nipples on old van solenoids? Fuel tank purge solenoid working? I’m not sure where it’s located on your model Foz, on the earlier EJs they’re under the intake manifold on the RHS. Cheers Bennie
  5. Not interchangeable from what I’ve seen with the two clusters a part at different times. The VSS just refines the running of the EJ and reduces fuel use I believe. It will run without it and I doubt it would throw a code either. Cheers Bennie
  6. A fella over here out west uses a GPS unit for the VSS. I don’t know what’s involved but it’s worked well for the many conversions he’s done. You could run a magnet and pick up setup on the tailshaft or one of the drive shafts. The EJ doesn’t care too much about how fast it’s spinning from what I understand (unless it has a speed cut), it mainly needs to see if it’s stationary, accelerating, cruising or decelerating to operate the engine properly. The only reason they say you need the GL dash that’s longer than the DL one is because (from my understanding) over I the US you guys got a VSS built into the speedo - I thought it was all EA81 speedos but it seems it might only be the GLs. The other way to go is to use the factory EJ VSS and use the EJ instrument cluster in place of the DL cluster. It fits quite well, you should find some pics online of this conversion easily I’d say. Biggest problem is wiring it in if you’ve already cut the loom down. Cheers Bennie
  7. @Link0demons- I like that suggestion about the cam timing being out. I heard of another situation like this but on an EJ22 from memory. Weird behaviour - full throttle it was fine, idle was poor/low, everything in between with load was jolty. The issue was the crank had skipped several teeth from alignment with the cam belts which were synchronised with each other. It’ll be worth the effort of removing the timing belt covers to check the alignment - and an easy fix if it’s out. It’s a cheap fix too if this is the issue. Typically it won’t show up as an engine code either, but may trigger other ones. Cheers Bennie
  8. New plug, boot, coil pack etc is worth a shot I’d say. What’s there to lose? If it doesn’t work it sounds like it’s time for a new head minimum, worst case is a replacement engine. It’s up the the owner - how much stuffing around vs how much coil they’re willing to mess around with to fix what’s potentially a simple issue. Cheers Bennie
  9. To fully drain and swap the auto fluid there’s a trick that requires two people - disconnect the fluid in to cooler hose and face this at a bucket. Get another piece of hose on the rad to the vege oil/laundry detergent (I’ll refer to it as vege oil from here on). Have a mate start the engine and let the auto pump out all the auto fluid and hopefully suck up the vege oil. Once you see the auto fluid change to the vege oil colour get old mate to shut off the engine. Alternatively, do this as a two step part - drain fluid first, once it reduces flow shut the engine off. Drain pan, fill with vege oil, start engine and allow auto to suck vege oil with the other end of the hose still in the collection bucket. Once vege oil is present at the out pipe for the bucket shut the engine off. Vege oil in the engine, I doubt it would last long but there’s always one way to find out!! Water in the brake system should work fine for what you want to do - this is something we considered out bush when a rear slave cylinder gave out on one of the vehicles we were with out in remote Western Oz. We ended up clamping a flexible hose for the remainder of the trip home…. After all this work they still might not accept the vehicle with the fluids because they’ll still make a mess when the vehicle is crushed/munched. It’ll be a more environmentally friendly mess but it’ll still be one they won’t want to deal with… Cheers Bennie
  10. What model Subaru are we talking? I don’t know how much that imperial liquid quantity is in metric terms, but it’s normal for some oil to come out when you remove a cam cover. Having the vehicle situated with the cam cover facing up an incline will help reduce this oil loss. Cheers Bennie
  11. Looks like a similar setup as the VT commodores use, most likely common across many GM models since then. To remove this I use a silicone gun nozzle cut down to fit the fuel line size, with a slit cut down one side to get it on the fuel line and up into that joint to release it. That is one very clean top of the fuel pump! Cheers Bennie
  12. Looks awesome, great craftsmanship there! Are those front control arms reinforced stock units or completely custom built from scratch? They look impressive! Cheers Bennie
  13. I agree with that. The Subaru in-tank fuel pumps don’t just die - they will underperform causing issues before they outright die, they usually get swapped out before they completely die. I had one completely stop working on my RS turbo - but I believe this was from sitting around with rubbish fuel in it. That didn’t bother me as I was only moving it off a trailer, not 100s of kms from home. It’ll be ingesting to see what the fuel pressure gauge says once you get it installed. I didn’t know there were units available that has the gauge remote mounted from the sensor! I’ve only ever seen the ones that are plumbed inline and viewed from where it’s fitted. Cheers Bennie
  14. Oddly I’ve not heard about this being an issue in Australia - but then again I’m not a mechanic that sees loads of these vehicles week in, week out. I doubt it has much to do with a dropped valve guide. Cheers Bennie
  15. It could be good once cleaned up and made into a glass-top coffee table Magazines (what are those these days?!) or newspapers could be stored in the cylinders Cheers Bennie
  16. Geez mate fair shake of the sauce bottle pointing the bone at the EJ being the issue. It’s simple - don’t do your maintenance, don’t get a good ride! At that age/number of kms the fuel pump probably needs to be replaced too - I’d be doing it as preventative maintenance. The EJ engines are good engines - they crap all over the EA82 by a long shot and some of them do well in the longevity department to be up there with the EA81 - with more power and good economy to boot. They’re not rocket science and before you go there they don’t scan your brain and report back to the government Stick with the proven formula - NKG spark plugs and leads, leave the gaps unless you’re running on LPG. I bet your fuel RON increase will have little to do with it. As for pinging, the older your engine is the more likely it is to ping from ring wear and increased oil consumption as a result. I’m sure you know about this already. Sorry, crap day while feeling like crap, not meaning to be an arsehole about it if it comes across that way. Bennie
  17. It’s an interesting one to ponder - are you building something that historically had this block or are you looking for all out power that would need that extra cylinder bracing? And that’s the other thing - you can get newer blocks and add bracing to the cylinders to essentially make them a closed deck block. Look at what the fellas with the high horse power turbo engines are doing and take notes from them. Many say the closed deck block isn’t needed, I believe the EJ207 is only semi closed deck and that is a high revving engine and a strong unit to boot. It come down to that old adage - what’s it worth to you? You really need to look at what you’re going to build with it, do you need the closed deck block or is it a bit of wank factor/street cred? I can’t put a price on it. We didn’t get them over here in Oz but I know 20 years ago blokes were importing them from your neck of the woods for high HP builds as the engines typically used now were yet to be released or cost too much as a base to start with. Cheers Bennie
  18. You won’t be able to solder on the tubes from the old heater core - they’re plastic! Both end tanks are plastic. You might be able to solder copper end tanks to the core that’s in there provided that’s not the bit that’s leaking. Bite the bullet, buy the new all copper core, fit it in and never look back! Pull it out before scrapping or selling the vehicle if need be!! Cheers Bennie
  19. TGV - as @1 Lucky Texan said - Tumble generator valve. Its purpose is to better mix the air fuel mixture at idle and maybe low engine revs for better torque (maybe, I’m guessing on this one). If they’re not opening quick enough off the line you’ll have running issues. The reason I mention this is because you’ve got an EJ253 and from what I understand of the later EJ253s they got the TGV setup. Yours could be the market test bed engine to get some real world data before going to full production on all models - who knows. But I reckon it’s worth looking into. PM me your VIN and I’ll see what I can find in the parts diagrams for your engine and get back to you. Cheers Bennie
  20. Any TGV setup on this early 253? It could be worth deleting these and see what happens. I mention this as a mate had his GT series 2 Foz do the same thing to the point sometimes it would almost die completely as you tried to cross an intersection. It turned out the TGV system was doing something stupid but not throwing a code. I believe he deleted the butterflies from the inlet manifold and left it as is. This resolved the issue and allowed him to tow his camper trailer around Oz without any further issues. Same thing with WOT - no issue, but partial throttle nothing but issues. Cheers Bennie
  21. I believe @DaveT did this with the CTS for the SPFI system years ago. Maybe Dave can dig up his post on this info? Cheers Bennie
  22. Are you needing to add coolant to the system at all? Grounds on the engine good and wiring to the sender unit not damaged? You could try wiggling it and watch what the temp gauge is doing, this will show up any wiring issues. Nothing near the sender unit that could ground it to give the false reading? Old mate that did the HGs - did they put the painted head bolts in the centre two holes? The other four are unpainted (on the head of the bolt) and these go in the outside headbolt holes. Asking as this always catches ppl out the first time they do a HG on these engines. Have you done an exhaust gas in coolant check just to be sure this isn’t the issue? Cheers Bennie
  23. ^ noice! What gear bag are you running with it? Best bit about the EJs is the parts availability and the extra performance over the (generally old clapped out) EA donk! Cheers Bennie
  24. Hey Todd, this website could help with finding parts to the size you need. A mate got me on to it as we look for alternative parts on our MY Brumby/Brat utes… https://size.name/en That exhaust looks MINT! So shiny, but I bet not for long once offroad! Shame the three pipe done sit horizontally flat beside each other for maximum clearance. If you went that way it would probably be easier to fab up your own headers for that setup! Cheers Bennie
