134
Dead fusible link? I can't remember if the charge wire goes through the fusible link. The reference wire certainly would. I'd be checking these to ensure they're all in good health. Cheers Bennie
How I cured my tickety tappets EA81
el_freddo replied to Knucklehead Saloon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So you're running a weber carb? I'm still running factory on both our brumbys. I was going to ask how much shaft play you have in the throttle shaft of the carb. My theory is that the shaft or the mount wears out allowing air into the carb that leans the mixture out. I believe this is most noticeable at light throttle on inclines. If your temp gauge is going over half way there's and issue there. The Thermo fan(s) should kick in at the half mark (too hot for my liking). Since posting about mine not pinging, the other day when it was 30+ degrees it pinged under heavy throttle when pushing it up hills fully loaded with a loaded trailer in tow. Not too worried as this was to be expected in those conditions. Cheers Bennie -
No spark = no fuel pumping. Work out the spark first then go from there... It's better to have spark and no fuel when trying to set something started IMO. With the replacement dizzy, points or module? If module replace it. If points make sure it's wired in properly and the gap is adjusted properly too. You may need a different coil for the two setups, I can't remember this exactly as it's been ages since I've played with the two systems. All the best Bennie
The mystery rattles and the short term smoke
el_freddo replied to Paperscale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dead cat converter. When these break up internally they can rattle around under load. Give it a gentle tap and listen for rattles. As for steam if it's cold weather you will naturally see vapour out the exhaust until the engine and exhaust pipe has heated up properly. At least that's how it works down here. I know in some parts of the states the exhaust always gives off vapour in winter due to how cold it is and the exhaust pipe not getting up to full temp. If you've got coolant in the cooling system and your exhaust smells like something sweet but not right sweet you've got a coolant leak into the combustion chamber which usually means a head gasket. Cheers Bennie -
EJ into EA81 - bonnet clearance, standard height
el_freddo replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Going back to the original question at hand. It's been bugging me... I'm 99% sure that Tim ran an EJ turbo conversion in his MY and this is the reason for the one inch spacer - you need this to allow the bonnet to clear the intake manifold which is different to the NA EJ. Do some more research. I reckon you'll find that any EJ turbo conversion in a non lifted MY will have these spacer blocks on the engine crossmember. But NA EJ conversions will not have them. Cheers Bennie -
I think a lot of the carb EJs went to Latin America and probably to the old European block countries. All of our EJs are injected including the EJ18 that came in some early front wheel drive imprezas. I don't think we got the ej16 here but have heard they exist. Cheers Bennie -
What models in USA or elsewhere got Diamond A coils?
1991 EA81 Brumby (targa). Noticed the little symbol on the coil while hooking up some lights. Cheers Bennie -
Hmmm I always thought the tappet gaps closed as the engine gets hotter due to the push rods expanding when hot... Anyway, if it works for you stick with it. I have one tappet that I just cannot adjust correctly. I can put up with one ticker Interesting about the pinging at light throttle under load. I've been trying to work out how to cure this in my mother inlaw's brumby. I haven't had it occur in my brumby - yet... Cheers Bennie -
How do I wire up '95 EJ 22 just for spark?
Someone correct me if I'm wrong but I'm 99% sure on the early auto EJ ECUs there's a particular pin you ground to tell the ECU that it's a manual gearbox. I've not read too much into it as the loom I've played with is from a manual. I like where you're going with this thinking but I reckon you'll run into issues with error code for injectors. Someone may know a way around this, most likely with a resistor of a certain ohm rating per injector. It may need the TPS hooked up. AFM who knows... Have a read on Ausubi (use Firefox or old version of explorer) with the EDIS system the Silverbullet has setup on his EA81S in his wagon build. I don't think it's really that financially involved. The biggest hurdle for him was creating the crank sensor's wheel. Cheers Bennie -
Sparkyboy - Jono is in Oz. We only get efi and dual port across all EJ engine phases. Any factory carb EJs are imports. Jono the difference in phase one and two engines is that the phase one has hydraulic lifters and the phase two roller rocker style actuation. From phase two I believe all EJs are interference engines. All boosted EJs are considered interference due to the two cams that freewheel if the cam belt snaps, I've never heard of a properly maintained EJ snapping a cam belt. EA82s on the other hand... EJ conversions work very well in EA vehicles when done properly. Key is getting the wiring cut down done right the first time Cheers Bennie -
250,000 km, 250,000 km...see
Sorry you lost me at EA82 -
old cars blamed for road toll in Oz
Don't get me started on what the media and policy makers believe about older cars! I wish you'd post this on an Oz forum, I'd be keen to see what others have to say. If you can't use, or dot want to return to Ausubi (need an old internet explorer version or modzilla Firefox to access atm) you could try out Subyclub.com - they're mainly into EJs but do love a good brumby build thread and being educated about EAs Cheers Bennie -
Upgrade door light switches EA81
I just glued a UHT milk lid to my door and that sorted my door switch Cheers Bennie -
300km on first half fuel tank
XT as in vortex? Can be done. Just depends on how low you're willing to go below the "E". I once drove from Radelaide to Woodend in Vic (about 740km) "on one tank" with a NA MPFI EA82 in Ruby Scoo. Before other mods the EJ did the same but with much better power delivery Cheers Bennie -
This is common knowledge. Do some research as to how people go about this mod - it can be done to look very factory Or drop the SOHC EJ22T in for no chassis mods. Cheers Bennie
Still a baby! Cheers Bennie -
88 GL 10 T- 2.2 L swap, hoping to run Microsquirt
el_freddo replied to Steve W.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's a piece of piss Jono. Mine's been running without issue other than the usual servicing requirements for 8 years - it's been well abused beyond what any EA could take in that time! Worth the effort but I do believe in factory management. Steve, what I don't understand is how it's running factory management and not running right. Something must have been missed - different timing marks on the cam wheel for the cam angle sensor for the turbo variant? Sounds like something's not running right - like an injector isn't healthy, or the TPS isn't dialed in properly. Could be many things :/ Personally I think aftermarket management will only over complicate things. Cheers Bennie -
I hope there's a positive update on this soon! Cheers Bennie
Welcome Gillies, interesting project! Where exactly do you hale from? I'm keen for some pics too (we love pics!). Cheers Bennie
thread repair gurus, beyond coil inserts ?
Give these a go Jono: Same as timeserts but are available in Australia and in different sizes, I grabbed this image for "display purposes" We've used them on a few things but I can't remember the specifics. I believe they spread the load with the larger diametre insert. Cheers Bennie -
Looking for options for slipping clutch on EJ swap
el_freddo replied to Torry33's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't get rid of it! Rear end - shove a set of 80's civic/prelude front end springs on the rear shocks. Job done You'll probably find the rear springs are on their way out with age and that you're hitting rough tracks harder with the prowess of the EJ Cheers Bennie -
Ea Wiper Motor Upgrade?
el_freddo replied to Naked Buell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Interesting. I don't have an issue with either the L series or the MY wiper motors... Cheers Bennie
