el_freddo
    134
  1. In Oz the screw on dizzy caps and rotors are only with the MPFI fuel injected EA82 engines. All other EA82s got the push on rotor button and clip on caps. Other differences in parts - clutch cable maybe shorter for the US market and I believe the throttle cable won't fit our subarus over here. There are differences between MY and L series seatbelts and buckles. They will fit but won't be the same as the other belts. And ensure you get the belt AND the buckle to ensure they'll work together Cheers Bennie
  2. MPFI non turbo. If it was turbo a good hint would be a "scalloped" section in the engine crossmember under the RHS head. This is for the up pipe to the turbo. They would've had to have changed the exhaust from the turbo setup too. It may never have been a turbo unit - the old fella might've had it as a turbo conversion project... Either way it'll have a "factory" oil leak between the head and the cam box, usually about 5 mins after you've resealed it! The push button 4wd with the auto engages a set of clutch packs to engage the rear end. If these are flogged out you'll only get drive to the front wheels. It'll be obvious whether it's working or not. The MPFI system is pretty good for power and efficiency once you've got it going. If there's rust on the bores either rebuild it or find a replacement engine - even a good carb block will do the job with the MPFI heads fitted. The only difference in the block is a crank case breather near the bellhousing on the RHS of the block. Everything else will bolt up once the MPFI heads are fitted (direct bolt on too). It should be a good little runner once you've got it sorted Cheers Bennie
  3. Head gasket for sure. Also look for rust in the bottom corners of the windscreen as they can typically rust here. Another place to check is behind the spare wheel. They're good little runners when you look after them - even then they don't need much attention in the long run Cheers Bennie
  4. Welcome to the forum from a fellow Aussie mate Search some more and you'll find more subarus forums too. There are a couple of Aussie based ones (but we're all just as knowledgeable and friendly). Cheers Bennie
  5. What was the condition of the hatch in the yard like? It's got me wondering if they'd help out an Aussie hatch owner that needs a rear cut (mate of mine). Sounds like you got a good score on the radiator! Cheers Bennie
  6. Nice mate. I bet you turn some heads with those stickers! Do you offroad/rally or just daily it? Cheers Bennie
  7. With a heated garage (we ALL know you have them! ) it'd be a good time to strip the engine down and do a thorough rebuild before the next spring comes around ;) A hone, rings, pistons should do the job. At worst you could need a rebore, which would still need rings and pistons (oversized!). While you're there a new set of bearings would be the go. Then the last bit would be dropping a mild cam in there Cheers Bennie
  8. So what did you end up finding? Sorted now?? Cheers Bennie
  9. Sounds good mate! I love our brumbys. Got any pics to share? Cheers Bennie
  10. What's with the wheels sticking out of the guards? I'd get done like a dinner over here with the cops if I had my wheels even half an inch out of the guard if they were looking. Your setups above would be asking for trouble over here! Keep the build thread alive! Cheers Bennie
  11. Nice one mate! Your US Gen1 wagons "look weird" with the flat roof. We ONLY got the raised (or what I've heard called "postal wagon") roof in Oz. Any other mods planned? Have you played around with the other globes to try and get rid of the hot spots the LEDs have created? I'm about to replace my globes in the cluster Cheers Bennie
  12. Bummer. I've just stumbled across a pic of the piston we pulled from the engine I was talking about (sheer coincidence!). No unusual noises, no loss of performance (then again, it was an EA82 so...): I seriously hope it's not this. But it'd be a good time to drop in a mild cam while you've got the block split Cheers Bennie
  13. Inlet manifold gaskets? That'd be what I'd check first. If nothing is obvious there then start thinking HG. Cheers Bennie
  14. Compression test will tell you if the compression rings are good. If you oil rings or landings are shot it could allow oil to be sucked unit the compression chamber when you coast or decelerate, when you go back onto the throttle it starts to burn the oil build up with the fuel mixture. The longer you coast or decelerate for, the more smoke once accelerating again. Engine will use oil but run fine otherwise. I had this occur on an engine in the L series, we only just pulled it down a few years ago to find at least one cylinder with broken oil rings. My other thoughts would be valve stem seals but since you've done all of them they can be ruled out... Cheers Bennie
  15. Checkout www.offroadingsubarus.com/forum --> members ride --> new brumby Bernadette. In this thread are details of the swap including pics of adapting the dual range EA82 lever rod to the EA81 interior hi/lo lever for a stock looking interior. Push button 4wd only engages the rear wheels via a cable actuated by a vacuum canister that's operated by a set of electric solenoids. If you get an MPFI or MPFI turbo box it'll have the larger 25 spline diff output stubs. The a vortex XT model came with an AWD gearbox that bolts straight into the EA82 L series - much nicer to drive on the open road while still keeping the true 4wd function. Cheers Bennie
  16. Performance wise EJ18? Nah I don't think there's much you can do unless you're going a small capacity turbo setup. If NA the old adage "there's no replacement for displacement" rings true. I've also heard the ej18 can use more fuel as you "ring it's neck" to get better performance. It will be more reliable than an EA82 hands down and certainly won't leak oil like the Eaa82 sieve! Otherwise all the work and money you're putting in to make this reliable would be exactly the same as an EJ20 or EJ22... Cheers Bennie
  17. Having to correct diff output stubs avoids needing to build custom shafts. But I guess if you're going for the EJ brakes you be making them anyway... And having 25 spline stubs would help as you'll get one on the liberty shaft, all you'll need then is an MY shaft that matches the spline count on the ball bearing's race/cage. Cheers Bennie
  18. I've got an OBX front LSD in my L series - it is in an EJ casing to match the engine but you can fit L series internals into the EJ phase one cases - they're basically the same. So the OBX will fit - but if you have a dual range you will need to shave the bolt heads to clear the low range gears. After I had mine installed I was told about a kit you can buy to replace the washers and other bits in the LSD to make it better. Apparently from factory they have issues with bolts not torqued the same, or even finger tight bolts, washers internally that are cracked or of different thicknesses when they should all be the same. Some people get the dremel in there to clean up case casting marks or machining ridges to make them nicer. Mine works well, definitely got me out of stuff/helped when a front wheel breaks traction. As for refreshing the Internals I've not gone there before (I've only swapped out 5th gear and the bearings in the rear housing), but you will need a decent press and a pot load of patience! Cheers Bennie
  19. Cable ties ("zip ties" over your way) are my choice of instrument to put the out cam covers back on - not just for the EA82s If you've stripped teeth and some are melted onto the crank or cam wheels, ensure you remove this before putting the belts on! Cheers Bennie
  20. Lewis, sorry to be the bearer of bad news - the diff output stubs on the MPFI gearbox is 25 spline like the EJ. You need a carb box with the smaller 23 spline diff output stubs. The larger ones will not fit the standard MY drive shafts. They can be swapped though - you need to split the box. If I did an EJ conversion on a brumby I'd go with the AWD box and swap the output stubs for this exact reason. Manual/quit mounts it doesn't matter. You'll need to work out what will work with where you want the engine to sit. You can use EJ engine mounts which will dictate where the engine will be, or go EA mounts on the EJ plate and have two options (two mounting holes). This will then determine what happens at the rear of the box which will probably need to be custom anyway! Cheers Bennie
  21. Welcome to the forum mate! It's amazing to hear how many people know subarus from their family's ownership... I'm not one of those But we did spend a lot of time flogging a fugly ("gen1") brumby in my neighbours paddocks when we were teenagers! And I recently found out my wife's dad once owned an early my wagon - saw it in a family pic, just enough of a photo bomb for me to recognise what it is. What's the grand plan? Maintain/lift and offroad/lower and turbo conversion? So many ways to play with these vehicles it's not funny! Cheers Bennie
  22. Nice Brumby/BRAT - and a targa too! Love them! I've been driving my mother inlaw's for the last week and it's made me really miss mine Look after it, they're a piece of motoring history, even if it's not obvious to everyone!! Cheers Bennie
  23. Nice hatch! A mate "over here" has one that he's repairing back to an acceptable state. I'd love so source a rear half cut for him but that'll be literally impossible! As for engine mods, go the EJ with a factory wiring loom cut down. I did mine in my L series and it's the duck's guts! (Good thing!). Add a super charger into the mix and you'll be glad you went with the ej22. My mate with the hatch actually did this build with his and offroaded it pretty hard! Now he's trying to save it from the dreaded rust cancer Look after it! They're certainly a unique Subaru! Cheers Bennie
  24. I'd be looking at the O2 for sure. Interesting how all that testing stuff works over there. We don't have it here but if you remove any/all of the anti pollution gear and are busted, the EPA comes down pretty hard on you and will throw the book at you! All the best with it! Cheers Bennie
