Mock up in solid works, Subaru R160 Locker
Awesome. Thought about using the front stubs from the EA gearbox as a template? These clip in like so: The carb boxes are 23 spline, same as the rear, but I'm unsure about the difference in diametre of these stubs in the diff housing/oil seal. It sounds good though, some stronger stubs would be awesome, hope it doesn't then break something harder to replace further along the line Cheers Bennie
Weird Oil Pressure?
You can hook up an after market gauge by using a T piece to add the extra sender into the system. This is what I've done with my EJ: This can easily be done on the EA82 as well. You can even make it a "remote" T piece where you move it away from that low position on the front of the EA82. You use some copper pipe or a flexible hose. This little oil gauge in the cab is great to know what's going on in your engine. Cheers Bennie PS: ignore all the oil on the block, I took this photo after fixing a blown pressure gauge hose!
1990 Loyale No Power but good battery
Have you got a multi meter? What you need to establish is that the fusible links box has power to it, there's usually a cable from the positive side of the battery to the box to provide power. Also pull out and check all the fusible links if you haven't done so already, sometimes while they look good they're fried, moving them will tell you if they're good or not. Are there any other mods that have been done to this vehicle? Probably a question I should have asked earlier. Cheers Bennie
My '83 GL: The Ski Wagon
What's that black box for? The electric window box, the one I've been talking about should mount behind the kick panel. I can't remember how the MY's do it but the L series is designed with the kick panel free of the bonnet release handle bracket... Cheers Bennie
This black box mounts above the bonnet (hood) cable lever, it uses the same mouting bolts - at least it does in the aussie delivered subi's... I hope this makes sense! Cheers Bennie
Nah They've usually just got a number on each item - crown and pinion gears - that should match, this shows that they're a matching item as you're not supposed to change just the crown or pinion gears, they should always be moved as a set. Mine had "30" engraved on both the crown and pinion gears, it can be hard to see. Cheers Bennie
EJ made to run like a big 2 cylinder, lots of lowend Tork Discussion
Why hasn't anyone tried spinning the passenger's cam 180 deg and replacing the belt to see what happens? I'm 99% sure that the EJ subarus are still a batch fire setup so the EFI system should be able to do it, the knock sensor might have a hissy fit though. I don't think custom cams are going to change much, you're going to end up with 1&2 firing then 3&4 firing one after the other, then the exhausting, sucking, squeezing without any power. I can see how the V8s can get away with it, they're essentially running as a 4 cylinder with 4 bang events that can be spread out enough to match the 4th event in the cycle evenly to the 1st for a continuous spread for power strokes. You'd probably have to look into a custom crank that would have all 4 pistons hitting TDC at the same time to achieve the double explosions at opposite ends of the cycle to make it a regular beat - there'd be one explosion per revolution, instead of the current 2 explosions per revolution. If I've got this very wrong, flame away, I'm happy to stand corrected, but this is how my mind is thinking at the moment. It'd be a bit of fun to see what would happen, but a lot of work just for some ************s and giggles. Cheers Bennie
$200 winter car has turned into an obsession.
Cheap subarus usually turn into a beast, I've got one of them too. I'm now at the point of buying things like rims and building gearboxes that I've paid well over double of what I paid for the subaru in the first place :twisted: But I wouldn't have it any other way. Yellow lenses in the snow for the win - otherwise you can't see crap in the thick fog! I've done the same in the snow here one year, except I was cheap and used cellophane to cover my lights. Worked a treat! Cheers Bennie
Awesome printer! Where can I get one/get bits to make one?? Loads of potential there! Cheers Bennie
Trike Builder Needs Your Knowledge
Or when you're "old enough" I could buy Tweety from you :twisted: This is a common conversion from EFI to the old school carb & dizzy setup... Cheers Bennie
So to clarify, auto locker (unlocker techicnally)? From my reading of this thread I'm under the impression this is an auto unlocker setup over a manual locker - air, cable whatever. Am I on the right path here? Cheers Bennie
Anyone got an idea how I can fix these cracking issues?
Nah you've got that wrong mate - my steering wheel is one the RIGHT side The rotisserie is awesome, but I found out last night when finally wiping the inside of the windscreen clean that you need to cover the windscreen from the inside when you're welding upside down - I've got a pot load of little welding spots in the glass at the top of the windscreen that catch on what ever you use to clean the windscreen with. That's my tip. Rotisseries are awesome though if you're prepared to go the whole hog and to what's required to gut and reassemble your vehicle. Cheers Bennie
I would say, from talking to Tweety and hearing of a fella in South Oz that's dropped an EJ in his trike that the EJ is too powerful. This fella can't get it engineered (a requirement in oz) after all his time and effort. Another thing to consider with the trike is that the engine generally needs to complement the look of the trike, this means a clean and untidy engine with a small bit of bling added. I've had the pleasure of riding/driving this superb machine, it goes very well with the NA EA81! You won't be disappointed, Tweety wasn't! Cheers Bennie
Ruby Sue!
With your 4wd lever you'll need to do a cut and shut. I removed the lever from my subi (L series - Ruby Scoo ), cut the tab the mounts to the lever the the cab and re-weld it sitting further forward. I guessed for my application - 3 inch lift with 2 inches on the gearbox crossmember, no lift on the gear shifter. From memory I re-welded mine 5mm forward, this lifted my 4wd lever off the centre console and allows me to easily disengage 4wd now. I should have done it ages ago. Cheers Bennie
The odd ball
Are you going to put some slots or holes in the plate to allow some air flow into the radiator, or you're getting enough air in there even with the plate in place? Cheers Bennie
Let's see everyones OFF ROAD light set-up
I might as well add my simple yet effective setup as well: Cheers Bennie
Lifted Rigs 2012 roll call
^ If I didn't know any better, I would have said it was photoshopped! Ruby Scoo, pretty much the same as in the lifted rigs thread, but she's had some work to sort some issues that "flying" created. This was January 2012: ^ Hopefully the ONLY time she'll see this angle. In action, Victorian high country creek crossing: ^ A snorkel is high on the list for the next mods! How I found her Friday morning at Mt Hotham: Cheers Bennie
My 1989 Subaru XT6
There's something about the XT6 that intrigues me... probably because we didn't get them in over here! Glad to see that it didn't get parted out. Cheers Bennie
Awesome effort there TheLoyale! If this was in oz, A) it'd seem a little out of place with those retro decals and I doubt anyone would put this amount of time into it. I'm surprised how well the interior's held up, and in blue is different. I also like the instrument cluster, I've never seen one like that before Great to see all the work you've put in it so far, I can't wait to see the end result. Respray and fresh decals in the list of things to do as well? Something inside me wishes you kept it all original for preservation reasons, but I realise that this isn't always possible, plus it's not mine to do this with anyway, I guess that's just me though Cheers Bennie
This morning I had to scrape some ice off the windscreen to be able to start the car so we could use it after it had warmed up: Got a good drop of snow today between our 400km round trip off mountain. It's 3 weeks until the official season opening but it's awesome to see this amount of snow falling already It's at Mt Hotham, Victoria, Australia. I'm sure all the ski resorts are getting some good snow at the moment. Cheers Bennie
89 loyal all wheeldrive turbo wagen
This is always fun too! Glad to hear you got the wiring sorted! Cheers Bennie
You'd actually need two pairs Yep. I got mine from fleabay. There was another set on there recently. Maybe if they're re-listed and your super keen the seller might look into international postage. I know it's easier to post items from the US than it is to post them TO the US. It sucks! Otherwise I could see me sending some EJ dual range boxes over there before they're crushed. Cheers Bennie
I totally agree with what you're saying - I want to build the radius rod plate lift blocks into one unit and the rear section with the cracking needs another brace to the bolt that holds the front of the K frame to the body. My rear crossmember lift blocks are in good shape and I'd leave these as they are. Things to do! Loyale 2.7 Turbo: The hand brake (e brake as you know it) is actually from the MY models before the L series came out. The reason for this is that I'm using the same centre console for the power window switches, the only way to get the hand brake to work properly was to keep the matching hand brake. It still actuates on the front brakes, so would be no help to you. Cheers Bennie
playing with my vanagon westy
- What Have You Done to your Soobie lately? (Please post in here and keep it going)
Over the last six months: I did this initially - it even cracked the re-welded section we did: Extra plating: From this: To this: To then being able to do this: And the "return of Ruby Scoo" photo - at Danny's Lookout, Great Alpine Road, Mt Hotham: It "only took 6 months!" But it's been well worth the effort. The first offroading trip will be the first weekend of June Cheers Bennie - What Have You Done to your Soobie lately? (Please post in here and keep it going)
