el_freddo
    135
  1. Yeah mate I’m down under! That pic is of our Liberty, our equivalent to your Legacy over there. Great car and yes, essentially the same as the outback without the lift or larger tyres or two tone paint work. I didn’t know they were doing the stop start feature in the Gen3 back then, is this legit or an aftermarket option? I too prefer older cars where the driver actually needs to drive properly. My thoughts are too many ppl become reliant on their safety systems rather than practicing proper driving techniques. Anyway, congrats on your daughter’s purchase @Ravenwoods! Cheers Bennie
  2. Jack up your front wheels and check for bearing play or noise. Also rotate wheel left then right and vice vests to load up CV joints and listen for any creaking or odd sensations as you do this. Do this on the rear wheels too. Cheers Bennie
  3. Was the donor vehicle an auto? I’m wondering if it is an auto ECU where the pin to tell the ECU it’s in front of a manual was not correctly fitted/removed/grounded - I can’t remember off the top of my head without looking up the wiring diagrams. If this engine ran perfect in the donor vehicle there must be an issue somewhere in the conversion and cutdown of the wiring loom. I’d be looking at any joints made in your loom to ensure they’re good and to rule them out. Cheers Bennie
  4. Wow that’s a lot of stuff you’ve done and probably reflects the maintenance afforded to it by the previous owner. I must say I agree with things like the suspension. We replaced all the suspension bushes about 18 months after getting it on the road along with the front struts. But you expect that with hundreds of thousands of kms on the clock already. That was a $AU1500ish. The original gearbox was replaced due to a dodgy bearing from I think being run low on oil. Second hand one sourced and is still going well. I think we’ve replaced one or two CV boots in six years and I’ve done the front wheel bearings as preventative maintenance. Only real issue ours has is an intermittent issue with the IACV stalling the engine sometimes when between gears at low speeds (typically downshifting). The new IACV is too expensive so we just live with it. We swapped the headlights too - but only because the opportunity for a clearer set came up for a steal. They’ve gone the same way because the vehicle lives outside. The cut and polish kits can take care of this easily enough. The vehicle went through a period of smashing tyres and rims (17 inch aftermarket rims) on our “ultra smooth” Victorian roads, and completely obliterated a rim on a Queensland road while up north. A set of 16 inch factory Subaru rims seem to have sorted the issue so far. We’ve not had the interior issues mentioned. The driver’s seat is still firm and comfortable to use on long distance trips. A side view mirror was replaced after the lib was rolled on its side one time. Dropped back on its wheels, fluid check and off she went again as if nothing happened. Same for the driver who was fine other than a little shaken up. Paint now tells that story and some others mishaps (not ours!) but is otherwise good without any real cosmetic issues from time outside and our baking sun. It’s a metallic green in colour We added some driving lights for many hours of night driving and to upgrade the crap high beam. I reckon the low beam on the Gen3 is one of the best from the Subaru line up of the earlier models. If you DIY any work on the vehicle it’s a no-brainer to me. If you know what you’re getting and what it could cost to replace it’s the same deal to me. Here’s the last uploaded whole vehicle pic from 2017 that I could find with the 17 inch rims before they were destroyed: A minty-off-the-show-room-floor-fresh looking Gen3 Outback passed me in my Brumby last weekend. It was a beauty and had me thinking I’d have one if I was in the market. Haven’t seen one in that condition in a very long time! Cheers Bennie
  5. We have a 2000 RX model Liberty/Legacy in our family. Picked it up cheap because of a fried clutch. While the engine was out I replaced the head gaskets not knowing the genuine replacement items would do the same thing as mentioned by idosubaru. Ours made these weird bubble looking things where the coolant was leaking from. Almost looked like a fungus. Replaced the HGs with the STi multi layered steel units and haven’t looked back. The car now has 480,000km and is going strong. If you do the HGs I’d recommend replacing the valve stem seals and reselling the cam retainer plate. I’ve found this seam between the cam retainer plate and the head is where oil typically seeps from rather than the cam cover seals. Adjust the tappets too while you’re there You’ll have a solid car there. They’re built very well. Cheers Bennie
  6. It’s an interesting one @1980ea71Brat! Dunno that I’ll be of much use from here on. The only good thing I can see is that the issue is consistent and not an intermittent issue that can be super painful to pinpoint. To add some confusion - @heartless- I thought closed loop was programmed into the ECU for cold running until warmed up. Open loop then reads the various sensors to run the fuel maps for the given parameters. I haven’t read up on this stuff in ages so I could have it wrong! Hence the confusion comment. See if you can test the temp sensor for the ECU @1980ea71Brat, it could be out of spec but not enough to throw a code. What’s your knock sensor look like too? If cracked, replace it! Double check those O2 sensors and ensure you’ve got them the right way around. When cutting down the loom, anything in there to do with the fuel tank in terms of pressure or temp sensors? If so, I’m wondering if these could be causing issues. Cheers Bennie
  7. Potential wiring issue. Also check the alignment of your timing belt. Ensure the crank aligns with both cam wheels correctly. What’s the fuel return pressure looking like? Cheers Bennie
  8. Ah the pitch stopper rod! That makes sense! So long as it works! Cheers Bennie
  9. What torsion bar did you weld? There’s only front and rear sway bars on this, the rest of the suspension is coil on strut/shock. Cheers Bennie
  10. If he’s not, it’s not a difficult exercise to make your own with some plate, drill bits, some paint, and a jigsaw with some metal cutting blades. The first step is to drill the two holes for the lower studs. These are the reference points that don’t change between the two items being adapted together. Fit the plate to the engine and get an outside line, mark the upper holes for the engine. Fit the plate to the gearbox (will need to drill/cut a hole for the gearbox input shaft to pass through), mark the inside of the gearbox bellhousing (can paint the mating face of the gearbox, push the adaptor plate onto this with the lower holes lined up, everything will be marked for you - same trick will work on the engine too, just do them on opposite sides!). Two ways to do the bolts, one that relies on the adaptor plate for strength (drill and tap holes), the other relies on two bolts being welded together and the plate slotted between the EJ and EA upper mount holes. Screw the welded bolts into the engine bellhousing, then fit the adaptor plate to the engine and you’re set to go. You’ll need to slot the crank bolts for the flywheel to mount too. That’s a quick run down, I’m sure there are other more detailed write ups on how to do this. Cheers Bennie
  11. Hey Rafa, Sorry I missed the acid joke! That EJ20 is the phase two engine, heads are different. But since you’re doing head gaskets anyway, the heads from your original donor engine will bolt on. Just make sure the cooling fluid passages are clear between the block, heads and head gaskets. If your phase 1 heads are corroded on the firing ring, you’ll need to find another set of heads. Cheers Bennie
  12. Why are we diagnosing a spark issue when Heater states the engine will run when fuel is poured down the throttle body? To me this is a fuel delivery problem, and since Heater says the injector can be manually fired with a bypass I’d say there’s an issue with a wire or two between the injector and ECU so the ECU is unable to send the signal to fire the injector, or the ECU injector output/circuit is fried. Not new electrical additions to your L series @Heater such as a head unit or keyless entry? No rodents in your vehicle recently? Might be time to do a continuality check on the wiring from ECU to the injector, only one broken wire is needed to stop the injector firing. If the wiring checks out correctly and you’re getting the correct resistance from the injector, it then points at your ECU. Cheers Bennie
  13. A legacy wiring diagram for the model and year your EJ22 came from helps with the loom cut down. Numbchux’s write up is great to use beside the above diagrams Cheers Bennie
  14. @Rafavidmess- all you really need is the block. Use the intake manifold from your conversion, swap the crank and cam sensors (shouldn’t be needed) and off you go. It would be a good time to do the head gaskets before putting the engine into service, it’ll pay off in the long term. What makes you say the previous owner of your donor vehicle used acid as coolant? If the engine sat for a long time without coolant the passages will form corrosion, that’s normal. I’ve not heard of this causing an issue, just keep an eye out for a blocked radiator if you don’t clean it out the best you can, even then the radiator could block up still. The original donor engine could just be due for its head gaskets to be changed. If it’s been severely overheated the other EJ22 you’re looking at could be the better option. But second hand is always a guess… It’s a difficult situation to be in knowing how hard you’ve worked to get so close to your end goal! Cheers Bennie
  15. Is the gasket also squashed on an angle like you suggest with the ruler? I reckon the installation played a part in the gasket breaking, or possibly the handling of the gasket prior to installing (possibly before you got them). Hopefully the new gaskets will sort out the issue and it’ll be happy days again! The dealership looked after you on the gaskets too! Cheers Bennie
  16. By “They’re” you mean the dealership? Best of luck, I really hope they come to the table to help you out there. Probably the best thing you’ve done is had them do their oil consumption test recently. Fingers crossed! Cheers Bennie
  17. Nice one! I’m pretty sure I did the same actuator setup in my L series. Remote central locking is awesome. Mine was part of an immobiliser kit so it does more than just lock and unlock my doors Anything that adds a bit of luxury to these old rides is mint in my book! Cheers Bennie
  18. Fingers crossed you’ll have this licked! Cheers Bennie
  19. I’ve had new aftermarket CV shafts click the moment the vehicle left the driveway and turned into the street. Aftermarket are certainly not great and they’re not cheap, but they’re available which is the main thing at the moment! Hang on to your OEM shafts while you can ppl! Cheers Bennie
  20. EJ fwd 5spd has the 23 spline diff stubs so you’ve got that sorted if the fugly uses the same I can’t say if that box will bolt in and I’ve only heard that the EJ22E fits between the chassis rail - never seen it or done it myself. Sounds like it’ll be a fun project. Don’t forget if you go carbs you’ll need a dizzy run off the back of the RHS camshaft. There’s a plate that you remove to expose the cam with the slot for a dizzy. Do a search about the dizzy type ppl have used and the adaptor/mount plate they made to fit it all together. You could find just about any dizzy from a late 80’s/early 90’s OHC straight four cylinder (east west orientation engine) that might do the job if you go that way. Cheers Bennie
  21. G’day lordvec, Do you have any pics you can share with us of the current setup? Add in some questions about what’s going on or what you’re chasing would be good too. The 80’s subforum would be a great place to post these questions as they relate to the EA82. Cheers Bennie
  22. @Brat 1986 - are you asking if an L series 5 speed fits in a BRAT? If so, search the forum as there are many examples of how to do this. It’s one mod I’ve not done as I have other plans for my Brumby (Oz model of the BRAT). Welcome to the forum To help others with your requests/questions, it’s best to add some detail about what you’re doing. Back in the day you would be flamed for this! Cheers Bennie
  23. Welcome to the forum @aKro! Tidy lookI got outback you have there. Do the roads get salted out your way? It’s an illegal practice here in Australia with the small yet highly sensitive alpine country we have (yes it snows in Australia every year, just not the same quality as the rest of the world, we often ski on slush or ice…). I’ve read that many parts of the states salt their roads and the vehicles on those roads pay for it with severe tin worm. Cheers Bennie
