128
^ I second these! Typically due to a loose castlated nut. Cheers Bennie
If you find an EA82 AWD gearbox it will bolt in the same as any of the EA82 4wd gearboxes. Grab the solenoids off the LHS strut tower for the locked centre diff actuation. In these the front and rear diff ratios MUST be a match or you’ll stuff the centre diff - and this item is harder to find than one of these AWD gearboxes! Cheers Bennie
If the engine won’t crank it sounds like a starter issue. Check that you can rotate the engine by hand to ensure it’s able to rotate freely. Then look into the cranking issue. If you mean that it won’t fire up, that’s another ball game altogether. When doing the timing, assuming it’s the same as the EA82, did you align and fit the first belt then rotate the crank one turn and fit the second belt? Cheers Bennie
1982 loyale interchangeably other years
el_freddo replied to Rywi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
‘84 will be the year many models changed over to the L series platform with exception of the Brumby/brat/MV. Rule of thumb is if it looks the same as your vehicle parts will swap over. I don’t know if yours has round headlights or not, but there are three headlight configurations for the EA81 vehicles that will swap parts over to your vehicle - round (early 80’s models), single square and dual/quad square headlights. Only part really worth modifying into your EA81 vehicle from the L series is the 5spd dual range. The rear diffs swap over too as a straight bolt in. The rest is different. Cheers Bennie -
92' Loyale Parking Lights stuck on
el_freddo replied to Sjoubert928's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ah righto! Definitely sounds like there’s something screwy at play. Hopefully it’s an easy/simple fix. Cheers Bennie -
There is no “reasonable” shipping from Australia. It’s WAY cheaper to send stuff in from overseas, but sending it out/back to the point of origin would cost easily double. It’s a joke. Pack and Send might be the best option but could be quite slow. Someone would have to go and investigate. Cheers Bennie
EA81 Coolant Bypass Hose
el_freddo replied to GLwagon1984's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I found one from another model vehicle. I can’t remember if it was from a Holden (GM) Statesman or a Toyota Camry. I remember it had a long straight section on it with a 90° elbow in the correct diametre. Cut it to what you need and off you go! Sorry I can’t be more specific than that. Cheers Bennie -
There’s a switch on top of the steering column, flick this off and it should turn the Parkers off. Cheers Bennie -
They also help keep your legs out of things that would severely damage them in a crash, not hugely, but it would help to some degree! Plus it looks better than looking at the wiring nest that can be under there some times... Cheers Bennie
1987 GL radiator and power steering hose
el_freddo replied to makermk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Why do you want to use an EJ PS hose? You’ve got me curious. If you’re doing an EJ converion the PS lines plug straight into the EA82 rack for RHD vehicles. I’d imagine it’s the same for LHD vehicles even though there’s a block to connect to. Cheers Bennie -
And here’s a curve ball on the EJ22 - no single ports in Australia, and most likely any other world markets. From what I can gather the single port EJ22 is a US market only item. I believe the single port exhaust head is employed to heat the cat converter quicker to meet some emissions target. Cheers Bennie
Siiiiicccckkkkkk!!! I love that colour! I always wanted my old torana painted in an orange like that! That’s for the update, you must be getting excited after all this work you’ve done! Cheers Bennie
Manual Transmission Linkage
el_freddo replied to nontrivial's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you can’t get reverse it’s ALWAYS the bushes and the selector shaft bolt that’s worn out. A small amount of play is magnified at the other end of the shift lever. Cheers Bennie -
I doubt a photo of the cut down wiring will help you I’m sorry. It’s too hard to tell what’s cut out and what was kept. The way I’ve done it is to tape the wiring together from plug I know are from the engine and sensors etc. Do this all the way to the ECU, leaving out the wires that are not associated with the engine plugs. You will have wiring intertwined so do your tracing carefully! And you’ll find many wire joints where it splits off to other plugs such as the TCU or cruise etc. Work out what they go to and make a decision as to whether you need them or not. If cut, curl the end and seal with some shrink tube If there are wires not taped together coming from the ECU trace them, tape with different coloured tape and find out what the pins do. You’re looking for: - check engine light (earth switched, needs power on the other side of the globe once it’s fitted) - power wires - there’s a few of these. Permanent, back up, ignition from memory - fuel pump relay and associated wiring. And the fuel pump wire too (black with red trace/stripe from memory - vehicle speed sensor - AC reference and control wires - thermo fan relay wire(s) I recall something about grounding a wire to tell the ECU it’s a manual, it’ll be in the wiring diagram somewhere. From memory you’ll need to add this wire into the plug to the ECU. It can be best to lay your wiring out in the vehicle before taping the whole loom. Do a test fire to ensure the engine starts and runs as it should. Check for any engine codes. When it all checks out as good, tape the wiring fully how ever you like to do it. Put it all back together and enjoy the drive! Cheers Bennie
The EJ25D will be fine in the dirt moving those tyres no worries. The Auto will do all the work, upgrade the external cooler if in a warm climate. On the road at cruise is where you’ll feel the power loss - general acceleration and in the hills/inclines. Going slow over rough stuff won’t be an issue. There were guys on here turning 29 inch tyres in the L series with the piddly little EA82 1.8L carb fed engine! The EJ25D will do just fine. Also, you can’t compare a Jeep’s lift to a Subaru’s lift. They’re completely different and if you follow your mate’s lines on the track you’ll get stuck very quickly. Subarus need to be driven very differently. Pretty much the only advantage to lifting and off-roading a Subaru is the fact that the diffs stay tucked up under the vehicle, effectively keeping them up higher relative to wheel hub/solid axle height. This is where the Jeep almost needs bigger wheels to create more clearance under the diff pumpkin. If you want to get really involved, a 2 inch subframe drop with a 4 inch strut top block will give you an extra 4 inches height. Use some stiffer springs (not necessarily higher springs otherwise you start to enter dangerous suspension setup territory - unless you’re carrying a heavy load ALL the time!). The add the tyre size you want to use, trim the guards/fenders to make them work properly. Go off-roading! Cheers Bennie
That’s your indicator to replace the radiator with another unit - go for quality or replace more frequently. Or leave the radiator and do your repair. That end tank WILL fail and it will kill your engine as a result. Been there done that. For me it happened at the worst possible time/place. We were 600km from home. HGs were shot when we replaced the radiator. Your call. I’m with GD and Ido on this one, I highly recommend you get a new radiator. Cheers Bennie
If you got the heater working it will bleed out the rest with a decent drive. As Tex said, get the nose high (do this after a drive now), let it cool right down. Top off then go for a drive up to operating temp and then some more driving. Once home get nose high, cool, top off if required. Done. Check again in a week or earlier if needed. Cheers Bennie
I can’t fathom that temp when we’re experiencing daily temps in the mid to high 30’s (°C) and overnight lows anywhere between 10 and the mid 20’s. Yesterday we peaked just over 40°C and we were still at 29°C at midnight. Overnight low dropped to 25°C. So well below zero temps with engine blocks etc freezing is difficult to comprehend, it’s very rare for that to happen over here, even in our snow country (that we’re lucky to even have in the first place!). I didn’t know about block heaters until this forum, and I’ve just learnt about battery warming blankets... Cheers Bennie
92' Loyale Wagon Engine Rebuild
el_freddo replied to J41YD3D.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
^ This is the most important step in setting up the cam belts on the EA82. Skip it and your engine will only ever run on one bank “properly”, the other is just dead weight and the engine will be a gutless wonder that’s painful to start. Personally I’d just do the HGs and focus on getting that correct. Shave the heads to get the flat again, be meticulous in your mating surfaces cleaning. GD would probably recommend pulling the pistons and putting fresh rings in there (his first recommendation would be to move on to a later model platform as this one is dead by lack of available spares). I would no be splitting the block just because you pulled the engine out. It’s not a “might as well” job and it will rack up the money and effort required to get it back together and operational. Cheers Bennie -
Restoration Update and Part Numbers
I’m yet to attempt this on my brumby. I have the original trim in the shed but it’s at that point here that someone is most likely going to nab the trim piece or the whole vehicle for it! Maybe that’s an over exaggeration but it’s the way I feel about it with just screws holding it in! Cheers Bennie -
83 4MT stuck in 3rd / options needed
First link, don’t like the generic advert with their generic pics. Avoid in my book. Same for the 4th link. Second and third are EA82 single range 5 speed 4x4 gearboxes. Last is the EA82 dual range 5 speed 4x4 gearbox. The EA82 five speed will need some mods to fit to the EA81 platform. There are many threads on here about how to do it and it seems a good mod to improve drivability and the gear change feel is more car like than tractor... I’d go with the last link of those gearboxes as its dual range. Grab the rear diff or confirm that it’s the same as your current gearbox, should be 3.7 ratio in your brat. Read up on those swap threads to see if there’s anything else you need for the swap. Cheers Bennie -
I think you’re talking about the bush that sits in the top of the gearbox at the base of the shifter/gear lever, correct? Look into the bush used at the base of the EJ series vehicles, earlier the better as I think they’re possibly smaller. Use this to shave down and fit into your shift lever’s bush space. Or make one with a 3D printer or some other creative method and material. It’s not worth pulling the gearbox out to swap because of this issue unless you’re doing a 5speed swap from the L series. Make sure the piece that has the pin through the selector shaft is tight. If there’s any slop do the slot and bolt mod. Cheers Bennie
