127
Awesome find @6 Star! Can you drop the link to that thread in here for a read (and vice versa)? Cheers Bennie
What you need to know @faunjoustino: - GD owns and runs his own Subaru specialist workshop. His advice is worth gold in our community. - while it was your dad’s vehicle and you’re precious of it, what you plan to do to get it up and running could be an exercise in wasting money - only because you can’t definitively explain why it was overheating. Personally I would’ve done as GD said as a matter of course for me. Getting it started on the old fluids won’t hurt it so long as there’s oil and coolant/water where it should be. Once it’s running then work out where any issues are - coolant leaks, split hoses or if it is the dreaded head gasket, which being the DOHC EJ25D seems highly likely. Once you know it runs and what needs what, that’s when you start spending your hard earned to keep it running sweet and to daily drive it. This is when you change the oil and the coolant etc. I hope this puts a few things into perspective. We understand it’s sentimental to you, but this doesn’t mean you have to waste money on it for no good reason. Trying to catch all of your new coolant when you need to pull and tear down the engine due to HG replacement is not fun. Many of us have been there and done that! Cheers Bennie
Greetings from San Fernando, Ca
el_freddo replied to Lambert818's topic in Meet n' Greet. Your USMB Welcome Center
Welcome. You’ll be well versed in a lot of the Subaru mechanical stuff with 5 head gasket replacements under your belt already! You’ll pick up on some tips on getting this task right every time. Cleaning all mating surfaces and other bits is one large part of a successful HG replacement in my book. Cheers Bennie -
86 GL pukes raw gas out of vent line
el_freddo replied to grandpaphil's topic in Meet n' Greet. Your USMB Welcome Center
G’day grandpa Phil! That sucks mate! To paint a clearer picture, you have an ‘86 L series with the EJ22 fitted? Any recent maintenance that’s had anything to do with fuel lines? Usually the cause of fuel coming out of the charcoal canister is fuel lines incorrectly connected. There could be another issue at play where the fuel tank is pressurising and pushing fuel out the vent line. Hoping you can provide more info on this to help resolve the issue. Cheers Bennie -
Cherry 1993 Legacy
el_freddo replied to Jshoffbuhr's topic in Meet n' Greet. Your USMB Welcome Center
Do you have ABS? And if you do is there an issue with the ABS system? I don’t know if this applies to the Gen1 - I know of some later model vehicles that will disable the cruise if there’s an issue with the ABS system. Also, if your Speedo isn’t working your cruise won’t work either. The cruise uses a reed switch built into the instrument cluster behind the speedo. I don’t know what circuit this operates on but it would be worth checking all your fuses too. If your legacy has an electronic speedo as found in the higher end Gen1s, it’ll use the reed switch at the gearbox for speedo and cruise. Make sure all your brake lights work too. Some vehicles will disable the cruise if you have a stop light that’s not working! Hopefully it’s something simple. Definitely share some pics! You’ll need a third party hosting company to post pics from. Imgur is a popular choice these days. Welcome to the forum Cheers Bennie -
Did you replace the O rings on the coolant crossover pipe when you had the engine apart for HGs? These can also weep overtime and make and have coolant smell. If they’re really bad you’ll see a small pool of coolant on the top of the engine block. Cheers Bennie
- 105 replies
- 1
el_freddo replied to pontoontodd's topic in Off Road
Just caught up on a few pages since I last dropped in on this thread. Congrats on completing the Vegas to Reno rally! Sounds like a tough gig to say the least. What’s that old saying about real race drivers driving their race vehicle home? Hats off to you and your vehicle. And I’m really stoked for you about the low range and centre diff lock! I had ideas but you’ve done something so much better than what I was thinking (mimicking the factory low range but at the centre diff). I truely hope this venture gets off the ground and that many take it up. I’d love one but as the usual Subaru fan, all desires and no cash. Plus I don’t currently have a later model Subaru for this. I’ll be spreading the word if you want it to get around, let me know! Love the pics. With the wildlife shots, any chance you could drop the name of the creature under the pic? The one that I was most interested in looks like two small snakes, but I think they’re legless lizards, correct?? Keep up the sharing and developing of parts, you’re in a tight niche market but hopefully the parts will move easily allowing you guys to do more of what you love! Cheers Bennie -
You’ll need to use the forester heads and intake on the EJ22 block. Plug and play doing this from my understanding. If the foz was an EJ251 you’ll be down on power. A properly maintained EJ251 is a great engine in my book, almost up there with the EJ22. Thinking about it you might have an EJ253, someone will know for sure. Cheers Bennie
Help: Identify SPI throttle body
el_freddo replied to torpedo51's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Original Owner may not have know about the EA82 SPFI adaptation to the EA81, or couldn’t get the parts to do it. I’ve heard a similar thing over here in Oz - we didn’t get the SPFI. I’ve only heard about this, never seen it, apparently some fella(s) adapted a Holden Camira EFI system to the EA81 or EA82. It was most likely a TBI unit - I heard it was a common conversion for other 1.8L’ish 4 cylinder engines. I’ve thought about the same thing from the Nissan Navara 4 cylinder petrol engines for the EA81, maybe one day... I guess the Original Owner was working with equipment they knew would work, or that they knew they could make it work - and they’ve obviously got it sorted. Since you have the mega squirt tune, it could be worth your while keeping the setup as is and just run it. Cheers Bennie -
Tesla swap would be mint! I’ve seen a doco about Amon in the states that do it all sorts of old and high end vehicles. Insane amount of torque on hand. From what they were saying the circuitry needs some trickery to manage the batteries or something. It was an interesting viewing. Sadly I can’t remember the name of the program, but the host was driving a silver bug converted with what I think was a Tesla unit via the gearbox for an authentic driving experience. Cheers Bennie
That’s a crazy amount of dedication and effort for an engine that many, including myself, would’ve binned! Have a bit more faith in your work! I guess having a low expectation won’t be so disappointing if it does leak, smoke, not run! Make sure your valves are correctly adjusted. The first time I fired up my EA81 after a semi similar build, it was only running on one bank properly as the other bank’s valve gaps were too tight and not making full compression. It smoked heaps too, my heart sank - I forgot that I oiled the cylinders during the slow rebuild, once this burnt off she was smoke free! This is what came with my brumby many moons ago. One small bit of pitting at the top of cylinder 1 or 2, can’t remember now... We drained out about 15L of an oil and water concoction! This engine dropped an internal Welch plug and dumped the coolant into the engine. I’m still driving this engine, so with the work you’ve put into yours it should run fine, unless the carb etc needs further attention. Cheers Bennie
After cracking into some log splitting on my dad’s repowered log splitter using an EA81, I thought I’d post a pic and ask other forum members what they have as a piece of home made machinery with a Subaru engine, or what have you adapted a Subaru engine to? Pics are a must! ^ this is Dad’s home made log splitter. We built it when I was in primary school about 30 years ago from a crashed Mazda 808 and a high volume low pressure ram from a Drott bull dozer. It’s got a matching hydraulic switch lever from the drott. The rest was fabricated by Dad, using the Mazda’s 1.4L inline four as the power plant. Several years ago after sitting for more years again, we went to fire it up and found the engine was seized. We’ve got a few Subaru parts cars at his place now, including one Kellogg’s cornflakes spec Brumby with complete drivetrain. He used the EA81 with the bell housing from an EA82 auto to adapt the hydraulic pump to the engine. Wiring transferred over easily. It’s quite a neat swap and it still works a treat. Best bit is if this engine has an issue we have spares to swap around etc. This thing will split the toughest wood we have in our area - the River Redgum. That stuff can pop when it splits and shoot the wood off the splitter! Most of our wood is White Gum, Manna Gum, Grey Box or Stringy Bark. The Manna Gum and Grey Box can be hard to split too. The log splitter sure as hell beats swinging the axe! We also have a small bobcat that runs a two cylinder Sherpa engine, that’s an ongoing project and parts are very hard to come by for that one... So, what have you got adapted to or built around a Subaru engine? I hope you enjoyed the read. Cheers Bennie
- 1 reply
- 1
Sudden drop in oil pressure.
el_freddo replied to Mj907's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like there might be a fault in the wiring for the oil pressure gauge. Could be a loose joint/connection somewhere or possibly a dodgy sender unit too. A mechanical or quality electric aftermarket oil pressure gauge is a good back up to have, or just a good addition to the “too late” idiot light. Cheers Bennie -
You guys must have some crappy aftermarket parts over there. I’ve always used aftermarket ball joints, tie rods, tie rod ends etc and haven’t had any issues other than when the expected wear and tear catches up with them. I’m sure I could go down to my old local parts shop and order new ball joints etc. probably about $AU20 each. Run them until they’re dead - which usually involves lots of abuse offroad until a boot tears, if I don’t pick that up it’s what kills them pretty quickly! Cheers Bennie
Yeah we have four cars in the family too. Expensive hobby! We have Ruby Scoo, my L series off-roader, doesn’t get used much now our family expanded; Redback Brumby and our two DiD Gen3 Pajero/Montero/Shoguns as the family buses. Both lifted, main bus setup more for off-roading/touring... and I have an RS turbo Gen1 Liberty/Legacy in the build that will be put to club rego once it’s done (whenever that is! It’s a complete fixer-upper-er!). I’d like to take one something like that now that I’ve seen yours, but I’d also like a classic round nose mini panelvan, moke or to get my old Holden Torana on club rego... One thing at a time though, lots of projects to keep me busy in the mean time! Cheers Bennie
94 Loyale Illumination Problem
el_freddo replied to DPalms's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You might need to set up a relay - triggered using the wiring for the ash tray light or illumination light for the heater controls/cig lighter. Then run a separate power wire controlled by the relay to the headunit’s illumination wire. This should get around any negative earthing issues etc and have the function work as you’re wanting. Cheers Bennie -
All sorted then! You’ve got the car’s illumination stuff sorted and the stez works as it should now? Lucky you didn’t damage the headunit! Cheers Bennie -
86 GL wagon fuel tank replacement
el_freddo replied to Ned P Pritchard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yep, it’s a fun job... got anything else you’d like to say?? Cheers Bennie -
el_freddo replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Merry Christmas “Old school” Subi nuts, and to the other Subi nuts out there too! It’s snowing hard down here Seriously, it’s shorts and Tshirt weather even at 33 minutes to Christmas Day! Stress less America, you’ll get there Best wishes and I hope you get some Subi bits etc from the big man! Cheers Bennie (ps: not wanting to turn this into a Christmas thread! Thought the pic would be good shared here!) -
FrankenBrat engine: where to go from here?
el_freddo replied to torpedo51's topic in Subaru Transplants
Awesome. The EA81 will do the job and just keep going if you keep the fluids up to it. It won’t be fast though. The EJ22 will be all of the above with some added speed ability too. Still no WRX but a good load of usable torque to help move things along. Got a pic of your EFI setup? Being EA81 I think you’ll find no advantages to throwing coin at an aftermarket engine management system... Cheers Bennie -
Out and about the other day Cheers Bennie
