el_freddo
    127
  1. Opposite applies for the Series 2 (‘87 was the crossover year). The series 1 had 3.9 ratio for the manual trans. I’m not 100% sure if this was across all manuals or just in the touring wagon (raised roof/roof bump model). That is definitely an EA82. Cheers Bennie
  2. You’ll need a new fuel pump. It would be a good idea to remove and clean the fuel tank, replace all rubber fuel lines including those under the intake manifold. While the manifold is off replace all coolant hoses with new items. You could get it started first then do all the fuel and coolant hoses so you know for sure that it’s a runner to begin with. Alternatively, try some Aerostart to see if it will fire on that. Good idea to drain oil and assess its condition, replace with cheap stuff for the purpose of initial start up and giving it something fresh to lubricate with. If there’s water or coolant in the oil you have a head gasket issue. Cheers Bennie
  3. Flywheel and clutch pressure plate! Starter motor too. Grab the pedal box with the brake pedal, clutch pedal and clutch cable. The instrument cluster could be a good idea for the correct lights when in 4wd etc. Gearbox cross member. Rear diff for sure. Unlikely to be an LSD, but you never know... more likely if from a turbo. Grab the cv shafts front and rear for spares. Fronts will be different (and required) if factory turbo. Centre console, 4wd lever etc. If it has rear discs grab them as well. That about it I think. Your list was pretty good. Cheers Bennie
  4. If you’re already thinking this way you’ll regret ever selling it. Also if there’s little rust in it, fix this and keep it as rust free examples are quite hard to come by - and if you could buy another example it will never be the same as this first one of yours. My sentiments anyway. I’d only sell my Brumby if I was pushed really hard and needed to get out of a bad financial position. It’s a family member to me - not the same as one of my kids though Cheers Bennie
  5. What model engine to each of these have? If they have the same engine designation such as both being EA81 or both being EA82, then yes, the lift from the GL will fit the hatch. If one is EA81 and the other is EA82, then no, the lift kit will not be a swap over option. Cheers Bennie
  6. Yeah, we have the returned service men and women’s Legacy foundation. I believe our govt requested Subaru rename the Legacy for our market - it’s the only one where it’s known as the Liberty. And you can probably guess why it’s not called a Liberty in the states I’m sure someone over your way could confirm this. I reckon I read it on here somewhere... Cheers Bennie
  7. Yeah we did! Our govt didn’t tax vehicles with dual range gearboxes like the states did - this is apparently why USDM Subarus were single range only after the L series/EA82 Subarus. We have a 2002 Forester auto in the family EJ251 with ~350,000km on the clock, still going strong. My sister’s 2000 Liberty RX with EJ251 and manual has well over 400,000km, still going strong but on a second hand gearbox due to bearing failure on the upper layshaft. It’s still running its original centre diff. My L series has 530,000km on the body, is highly modified and has no original drivetrain as a result! Cheers Bennie
  8. I’d be swapping the O2 sensors first as if suspect these are dead before the ECU had issues. My 20c on the matter. Cheers Bennie
  9. Problem is the threads overlap or are very close to it. Two threaded holes about three mm apart would be a whole lot stronger. Cheers Bennie
  10. You could do this in stages. Start with the engine and gearbox conversion. Gearbox will need custom crossmember, tail shaft and possibly gear linkages (I’m about to do this and find out in the next few months) Wiring is “easy” - after you’ve done one or two loom cut downs: Basically you work out what’s the ECU plug wiring, what goes to the engine, O2 sensor, AFM, starter motor, ignitor etc, then cut away the rest. If there’s a splice in the wiring, cut out the one that branches off from between the ECU and it’s respective plug at the engine end. There are several wires you’re looking for as well - VSS (vehicle speed sensor), check engine light, main power with ignition, permanent power, back up permanent power, coolant temp and oil idiot light wires. The last two can use the factory EA81 wiring to keep it simple. If you want the EJ instrument cluster it can be done and fitted with minor mods (from my understanding) unless you have the long cluster arrangement. Wiring stuff I’m not sure about for the cluster as I’ve never used the donor’s cluster but have seen it done on other forums. The brakes will need front EJ knuckles/hub which means a strut swap and a custom driveshaft too. Rear gets complicated with the need of a custom hub that adapts the EJ stud pattern to the EA stub axle. Once you have this the EJ brake backing plate needs to be drilled to fit the EA swing arm. Then bolt all the EJ brake setup onto the swing arm and she’s apples. Next up is working out the hand brake arrangement. Using the section of EJ trans tunnel where the cables enter under the floor mats would make this much easier. That’s about it for brakes. Widening the track width to that of the legacy is another project in itself. You will end up with almost half the tyre outside the guards and you will need to graft strut towers into the rear of the wagon - and brace this to make it last the distance. I hope this gives you some insight as to what you’re up for. Personally I’d stop after sorting the brakes to EJ. Cheers Bennie
  11. That seems odd. SJM? The super junction? No ECU wires should be going through this! As for shields, it shouldn’t matter if they crossover with the wire swap - shields are usually grounded so I can’t see an issue with the swap/crossover but that does seem odd. Cheers Bennie
  12. Depends on how you go about it. I’m not into adaptor plates but know a bit about them. And if someone goes for an EJ swap, some research should be part of this decision! I guess not everyone does this bit before diving in head first. Cheers Bennie
  13. Thanks @Numbchux I didn’t know they were made like that. Engineers over here wouldn’t approve that if the plate is alloy, steel maybe. Cheers Bennie
  14. @91loyaleman - we didn’t get the SPFI over here. Any that are here are imported setups from the states. Cheers Bennie
  15. Just the 5 stud hub that mounts on the stub axle. Meh, don’t need them Steptoe, Plans are in the wings for another production run of these hubs from Australia from what I’ve here. So local to us and is the key ingredient needed for the 5 stud conversion. Cheers Bennie
  16. Did you replace the O2 sensor at the same time as replacing the cat? If not, I’d be starting there. A dead O2 sensor doesn’t always throw a code. Cheers Bennie
  17. Rear brakes you’ll need the backing plate and the most important piece - the EA 5 stud hub. The rest can be worked out if it doesn’t directly fit - eg, WRX backing plate adapted to the EA swing arm. WRX dump pipe should fit no worries - one way to find out since you have the dump already. Cheers Bennie
  18. You need to have two bolts welded together so there offset. Screw one end into the engine, slide the adaptor plate in place then fit the gearbox. You should have enough meat on the lower studs to leave them as is. I’m surprised your adaptor plate doesn’t come with the required bolts. My mate makes them over here and he supplies modified bolts welded by a certified welder (which is required for engineering certification). Cheers Bennie
  19. Wow you guys really beat on the manual boxes! They’re not bad at all IF the driver knows how to drive manual! If you want to know a bad box, try the Brat 4 speed. I call it a highway tractor because it feels like a Massey Ferguson gearbox compared to the later 5speed but is way less reliable! Cheers Bennie
  20. Winning! I hope it serves you well for many many miles to come! Cheers Bennie
  21. Carb or SPFI? Cam belts installed correctly? There could be more at play here depending on what you have. Cheers Bennie
  22. Next time it won’t start easily, try foot to the floor when starting. This tells the ECU the engine is flooded. It cuts injector pulse until engine is running. It could be part of your issue that would point to injectors leaking. As for the power loss I’m stumped on that one. Cheers Bennie
  23. Hmmm it’s an interesting one. Glad the injectors were worth it. Have you checked the timing belt alignment? My other thought was on the valves - remove a cam cover to see if you have hla or solid (adjustable) lifters. If you have solid it could be worth checking your clearances for the valves. Cheers Bennie
  24. If you have a Loyale with an EA82 - or in simpler terms, if the spark plug leads go to a distributor at the back of the head on the vehicle’s LHS, you need to post in the EA82 forum. If it’s carb, any Fawcett pump will do the job, no need to go overboard on the price. Any fuel rated paper filter will do the job required. If you have a SPFI or MPFI EA82 (fuel injected) then you’ll need an efi rated external pump. They’ll most likely be about $200 (over here they’re about that for a half decent unit). I wouldn’t put a filter before it as these pumps rely on fuel to cool the internals of the pump. Cheers Bennie
