el_freddo
    128
  1. That’s how my first conversion started. Got an EJ20 for $100, then ended up getting an EJ22 engine, loom and ECU. Haven’t looked back. That EJ20 is now going towards another project. Cheers Bennie
  2. Rotor pin has nothing to do with cam timing as it can be pulled out and incorrectly installed - throwing a red herring into the mix. Cheers Bennie
  3. Look for rust. Typical places: - windscreen surround/corners - under rear fixed side windows, followed by the wheel arches - rocker/sill panels - body work behind the front guards in the section behind front wheels - good place to trap dirt, road grime and moisture - generally under the vehicle, especially if in salt country - at which stage this will rust out super quick anyway if not treated properly. Engine will leak oil like a sieve unless pulled apart, cleaned, cleaned and cleaned before reassembly. If the EA82 blows a head gasket, replace it with an EJ22. You will thank me later Hoard parts! Cheers Bennie
  4. EJ22 engine management is the go. It’ll give you the option of upgrading the block later down the track. You will probably have to fit a cam angle sensor as I don’t think the EJ18 uses one - another reason to avoid this setup. Cheers Bennie
  5. Not necessarily. If they just set and forget there could be many underlying issues that come into play once you drive off and things start moving as the suspension does its thing. Cheers Bennie
  6. Doing a factory efi EJ22 install is much easier than fabricating parts for dizzy and Weber in my book. Cheers Bennie
  7. It doesn’t matter which cam is at 12 and 6 o’clock, so long as both aren’t at the same and the crank lines up each revolution. Cheers Bennie
  8. @89Ru - the centre diff will make the clunk noise in either direction and no noise in a straight line. It sounds like a dull knocking sound that’s speed and load related. I don’t recall any skipping or real binding sensations when a gearbox I put in my sister’s Gen3 had a shot centre diff. Good to see it was only a drive shaft though! Easy fix if not frustrating at the least. All the best! Cheers Bennie
  9. Are you sure it’s not a centre diff clunk noise when turning? Cheers Bennie
  10. Looks good mate! I hope mine is that good one day!! Cheers Bennie
  11. It can and has been done many times before - the wrx engine into an L series. Not for the those who don’t know their way around an engine bay or how to read a diagram - unless you’re paying someone to do it, at which point get a good wrx with a dud engine and swap engines. There are loads of threads on the net about these sorts of conversions. Have a read of those and go from there. Cheers Bennie
  12. PS - that unit in the side of the radiator is only a temperature switch. It’ll do diddly squat for your gauge reading until it “turns on”, then your gauge will go sky high. Cheers Bennie
  13. EA temp sender unit is in the intake manifold just under the thermostat. Two things you can do: 1) fit the EA temp sender unit to the EJ coolant crossover pipe - might need to have a plate welded on to allow appropriate thickness to seal properly. 2) plumb into the heater hoses (the one coming from the coolant crossover pipe) in a metal T piece that’s got a wire to an earth point. Both are effective. T piece is easier when it comes to engine swaps etc. or you can fit a mechanical/electric aftermarket gauge for ultimate definitive temp reading. Same trick with the T piece. Mechanical doesn’t need an earth wire. Your shroud looks good. I presume the fans fit around everything on the front of the EJ? Cheers Bennie
  14. Welcome to the forum @Wilco88 Looks like you’ve covered all bases with getting this question out there! What idosubaru said Cheers Bennie
  15. Go OEM. Might cost a bit more but it’s cheaper than another HG job in the next year or two. In saying that I have no experience with those aftermarket gaskets. Cheers Bennie
  16. Stop confusing things @Ionstorm66!! If you follow the procedure properly you can’t stuff it up. Line up the cam timing marks on the flywheel, pistons are mid cylinder. So it doesn’t matter as long as the dizzy cam wheel is aligned with its mark when the belt is put on. What DOES REALLY MATTER is the one crank rotation between fitting the second belt. Without this rotation the engine will only ever run on one bank or the other when messing with the dizzy position (rotating 180 degrees). Correct. The 2:1 confusion is from crank rotations. ^this!!* Pfft, more of an option mention than a plug! As @idosubaru said about the EJs - early ‘90s. The real trick is looking at the cam followers/rocker arms. If they’re HLA, non interference. If they’re solid with adjusters, they’re interference. Only time you’ll snap an EJ belt through poor maintenance with an idler bearing seizing. Or copping a stick through the cam cover, I almost did that job once! Cheers Bennie *unless the question is “should I just EJ this?”
  17. Replace both belts and tensioners. It might not be an old belt that “just snapped”, it could be a seized tensioner wheel that melts the cambelt and makes a huge mess. If there’s any melted rubber on the crank or cam wheels, clean this off - ALL of it! It’s not fun. Best bit about the EA82 cam belt job is you can’t stuff the engine as they’re non interference. The other option (and I have to say this partly for shits and giggles) is to EJ it. Then your L will be really fun! Cheers Bennie
  18. Rear tyre toe in/camber shot on the side that scrubs the tyres out? They say they’re non adjustable but the rear camber/toe in is changeable from the three bolts on the outer swing arm. I need to do mine but haven’t worked out how to do it with tyres on etc - or how to measure it. I have other issues to sort out first! Also, no lift in this rig? Cheers Bennie
  19. Battery drain issue - make sure the boot/trunk interior light is turning off when the lid is closed. Cheers Bennie
  20. That’s an easy one, you’ll be fine. Cheers Bennie
  21. My weapon of choice was an angle grinder. Very satisfying. Cheers Bennie
  22. Also look into the possibility that you have a leaking head gasket. Hopefully not, but if they’re the original HGs I’d be suspect about them. Cheers Bennie
  23. If the injector is clicking, have you looked at fuel pressure or the possibility that the fuel pump is dead? Cheers Bennie
  24. As GD said ^ But... Only way around this and keeping the low range is to find an RXII coupe AWD gearbox. This box has the locking centre diff - you’ll want to find one that’s not flogged out from running different front and rear diff ratios or from dickheads doing rear wheel burnouts using the front hand brake. From here you can cut and shut the pinion shaft to have the 4.44 ratio diff. The crown wheel needs to be shaved to clear the low range gears too. The good L series low range of 1.59:1 will drop in once the crown wheel is shaved to clear. Then you’ve got basically the ultimate package - best low range, 4.44 diff ratio, locked centre for 4wdn and AWD on the road - especially good if you’re running the EJ22. Downer on this box is that it’s a custom build with few spare parts available these days. Over here I have the advantage of EJ AWD dual range gearboxes for the drive gears at the very least. It’s the centre diff that will have this as toast if it dies (I lock it whenever I’m on dirt to avoid wear). Not a simple task, and in the eyes of GD, not cost effective, go get a truck :p (sorry GD, couldn’t help myself!). Cheers Bennie
