127
Diff issues are a red herring in this issue. Those cracked bushes will allow the diff to rotate under load, this will be added slack in the drivetrain. The wheels and tyres are held in place by the suspension arms, struts and bushes in the system. Something in there must be amiss for the tyre wear issue you’re seeing. Going by those diff bushes, there will be other very well worn bushes throughout the whole suspension system on your tribeca. Pretty common for older vehicles to have issues like this. Cheers Bennie
Thanks mate. Seems I’ve opened a real can of worms on this one. Seems I need to pull one piston from the GT block (EJ205?) and take some measurements from centre of the gudgeon/wrist pin to the top of the piston and compare to what I have - unless you happen to have one of these pistons out already and can grab a measurement for me when you have five mins to scratch yourself? Thanks for all your help and insight on this one. Cheers Bennie
- 7 replies
- ej20g
- phase 2 block
(and 2 more)
Tagged with:
I too looked into this. But that pressed fitting would never be the same if you tampered with it. Interestingly, from what I remember of modifying the odometer reading on a six gauge long cluster (only so it read the same as the factory cluster it was being converted from), you can remove all these bits. So I don’t know why they changed the setup from one to the other, it makes sense to share the same bits between models - but then again, it was the 80’s! Cheers Bennie
Awww... no pics?? Bennie
It’s the first wrx version of the EJ20 turbo, or EJ20G. The Gen1 Liberty/Legacy had a different piston again and DOHC heads that were more inline with the NA EJ22E - they even shared the same hydraulic lash adjusters and cam followers which is why many had the heads and pistons swapped under warranty due to lifter tick - I believe the exhaust lifters bleed out as things cooled down as they’re upside down in orientation. Or poor oil change routine was the issue. Now I’m hoping the rod length is the same. This game keeps getting better and better The learning curve is steep and unanticipated! Thanks GD! I’m also guessing the phase two DOHC has a different cam belt length too. Time to go count some teeth... Cheers Bennie
- 7 replies
- ej20g
- phase 2 block
(and 2 more)
Tagged with:
Ok, I’m now at the point of “bugger it” swap the pistons. Put fresh rings in too. I have an A B A B block and have a set of pistons that are the same and correctly orientated - a left side A & B and a right side A & B piston sets as per the block markings. Will speak with the engine shop on Tuesday (most likely) to see what they reckon. I might even get them to put the pistons in if the price is good. Cheers Bennie PS - glad I go all reactive then think about it, you can see this process in this thread where I basically talk to myself. Still happy to hear suggestions/experience with this/other ideas on the topic.
- 7 replies
- ej20g
- phase 2 block
(and 2 more)
Tagged with:
I should add that I have hydraulic buckets, I’m thinking that the total lift of the valves may not be achieved with just turning over by had as I won’t have full oil pressure. Thoughts? I don’t have any plasticine or the like to squish and see how close things get. Cheers Bennie
- 7 replies
- ej20g
- phase 2 block
(and 2 more)
Tagged with:
Ok, need some help here, hoping someone can help out (@GeneralDisorder?) First GT forester series 2 (2002) head is off. Piston is noticeably different - GT on the left, EJ20G/whatever it is on the right. This EJ20G/x piston is what came with the heads I’ll be running with. I’m now worried the valves might hit the pistons. I’m hoping I can put one head on (not fully torqued down and thinking without the gasket too), refit the timing gear and rotate the engine to find out if the valves will kiss the piston. Also to note, the GT had thin MLS head gaskets, the HG units I got ages ago in prep for this build are thicker composite gaskets (OEM). I really don’t want to swap pistons on this thing! Here’s hoping! Some background info on the build: this will be going into my Gen1 RS turbo. The heads match the intake bolt pattern and the intake equipment matches the engine management system, hence the head swap onto a known good block. And no, I don’t want to run later model management or run aftermarket management, please leave comments like that to yourself thanks! Cheers Bennie
- 7 replies
- ej20g
- phase 2 block
(and 2 more)
Tagged with:
Home built hovercraft w/ ej22 power
el_freddo replied to Hovercrafter's topic in Meet n' Greet. Your USMB Welcome Center
^ that is an awesome way to live! I was going to ask if you can swap dizzy internals to avoid the need of the resistor, but that still requires getting parts. The EA82 had an electronic ignition module in it instead of the old points system. Very reliable until a coil dies, or it slowly dies. Got any pics of your setup? Cheers Bennie -
Where the bloody hell did that come from?! Very random. I’m glad you got onto it early. Cheers Bennie
Looks like an awesome project! The single port injection from the Pontiac is an interesting way to go about it. And was that a snapped bolt in the cylinder? That’d be annoying to say the least! Cheers Bennie
It used to be done back in the day when it was stud and nuts - no stretching. DO NOT “retorque” the head bolts on any EJ engine. These bolts’ final tightening sequence is done by rotation in degrees, not by measured tension. Leave them alone. Either do the required work on the engine and run it or just do the cam cover seals and wait till it spooges a HG then bin the vehicle if it’s not worth anything to you. Cheers Bennie
86 Gl transmission Leak
el_freddo replied to bradley2519's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For auto, most certainly and it’s a common issue. For manual, the gearbox shares oil with the front diff. Cheers Bennie -
Same in AUDM. The series one L (85-mid 87 in AUDM) has DOJ on inner and outer for the rear shafts, the series two L (mid 87-94) had only the inner joint with the DOJ arrangement. I’m 99% sure these are interchangeable on the L series. Cheers Bennie
Direct bolt in. Dual range lever is needed and rear diff must match as mentioned already. Cheers Bennie
- 96 replies
- 1
- Dual Range EJ
- LatinAmerican Domestic Market
- (and 7 more)
@Geoff F - what marks did you use for each cam? Cheers Bennie
- 20 replies
- 1
- timing
- bent valve
(and 2 more)
Tagged with:
Someone recently posted a link to MY/EA81 rear shafts. Can’t remember where I saw it though. Cheers Bennie
Good! I doubt the auto would be up to an EJ. You’ll love the EJ with the manual. Watch out in wet weather when putting the pedal down! Cheers Bennie
Getting to know my xt6 (1st Suuub)
el_freddo replied to Karmasrenegade97's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it’s the EA81 turbo then no. You need the 4wd Leone from ‘85 onwards. 4wd/AWD coupes will also work basically anything 4wd L series/Leone from ‘85-94 Cheers Bennie
