el_freddo
    133
  1. That sounds more like maintenance oversight than an issue with the oil cooler leaking! I’ve not heard of any of the turbo engines that run the same system having issues. Technically it’s a heat transfer device - goes either way - hot climate = cooling effect for oil, cold climate = faster warm up of the oil to its optimum operating temp... Anyway, moving on! Cheers Bennie
  2. Isn’t the turbo setup a twin port head with a matching MPFI intake manifold? Over here in Oz anything MPFI - turbo or NA requires the matching heads to the MPFI intake to make the multi port system to work. You can’t bolt MPFI to carb heads - it just won’t work! Unless there’s something majorly different with the US spec turbo setup but I think it’s the same as it is here. Cheers Bennie
  3. And secured properly. I had the cam sensor “walk” out of its slot because the retainer but was loose - engine stalled and wouldn’t start until the cam was pushed back in and secured. With Subarus it’s always a good idea to fit the long block from the donor vehicle with the intake from the recipient vehicle. Swap over cam timing gear if needed - but probably not an issue in your case. Check the timing belt, you could have a collapsed bearing on one of the idler pulleys, this will throw out the timing, and make it very difficult if not impossible to start. Cheers Bennie
  4. You’ll probably find you will have little visual access to the cylinders with the sump off in the EA82 from what I remember of my rebuild well over a decade ago - so I could be wrong. I just remember a rib like cage below the crank area, probably for strength. Personally, I’d say hunt for a good EJ. Cheers Bennie
  5. If you want the proper turbo setup from the 86 you’ll need to swap the heads and cut down the wiring loom for the engine management system. Or reloom the whole vehicle with the turbo loom. The 90 - mpfi or spfi? If spfi, you could both that directly onto the 87 and run the engine management system from the donor car. You could add the turbo, but it won’t last for long - those that have done it end up cracking the NA pistons. Cheers Bennie
  6. Agreed. EJs are good at maintaining a small HG leak for a long time without any real issues. Then things get hot at times and that’s your first sign of impending troubles in the HG department. Cheers Bennie
  7. Never heard that term before. Always a grease nipple over here. We love nipples Cheers Bennie
  8. I’ve read up on knurling pistons but that’s way outside my skill set and tools available to me! Great idea though! Cheers Bennie
  9. Al - get the SF forestry box and shove that in. 1.447:1 low range from factory, and 26 inch tyres from factory. All your ratios will be pulled back to where they should be and you’ll be loving life again! As for the gearbox: - phase 1 EJ box fits inside the L series casing - but it must be dual range to dual range and single range to single range swap. The AWD centre diff housing will bolt on the back of the L series EA front cases. - if you find the L series AWD locking centre diff gearbox (XT4/XT6/RXII coupes/GT wagons) you can swap in EJ diff ratios with a cut and shut on the pinion shaft. You can also fit the L series 1.59:1 low range - if going with the above: the 1.59:1 low range will clear the 4.111:1 and 4.44:1 diff ring gear once it’s shaved down appropriately. @Al Zhiemer - if going the foz box (phase two would be better as it’s stronger) you can fit the L series 1.59:1 low range with a few mods and the shaving of the ring gear. See here: https://ausubaru.com.au/viewtopic.php?f=22&t=13511 You will also be able to run the EJ clutch setup etc. makes it very easy for parts. You could even put the 4.44 diff ratio in if you wanted too. But as you say, sourcing one isn’t easy! ISSUES: - EJ dual range boxes don’t exist in the US like they do in oz. - L series AWD boxes aren’t easy to find either! @rallybru310 - 27 is probably the best tyre option to avoid body bashing to make tyres fit. Also make/get the strut lift built with the camber adjustment built into it. This will straighten up the eye and reduce that positive camber which typically becomes exaggerated with a poorly made lift kit. In my L series I’m running an EJ22 with SG phase 2 front cases and drive gears, 1.59:1 L series low range, custom 4.111:1 diff ratio (pinion shaft is the custom bit for ->), L series locking centre AWD diff, oil “feeders” over the low range gears for cooling and it’s about to cop a rear torq locker. It’s running 27 inch tyres and a 3 inch lift kit. I’m also using factory EJ solid flywheel and clutch setup. It’s got factory engine management that’s more than I need. Apart from some machining for the low range hub, an interference bush on the input shaft, shaving of the crown wheel and the custom work on the pinion shaft it’s essentially all DIY’d. A series 1 L series PT4wd box with 3.9 diff ratios could be a good way to go too. The series 2 L series PT4wd box over here are all 3.7 diff ratio. Cheers Bennie
  10. Take them back and demand a refund. The bearings should be an interference fit fit and need quite a bit of persuasion to get them in. The inner CV falling apart doesn’t make sense why it’s happening. Cheers Bennie
  11. Late reply, but generally any factory dump pipe will work. Build your exhaust from the end of that. Cheers Bennie
  12. Maybe you’ll be the first for a remote mount electric oil pump? Cheers Bennie
  13. You will need to have your tailshaft machined to fit the replaceable uni joints. I’ve not done this work, only heard about others doing it. I don’t know if the machining is to get rid of the stakes that hold the factory uni’s in or if it includes machining a flat spot for the C clips to sit on properly. I might get around to doing this one day... Cheers Bennie
  14. ^ Post two by GD. He suggests leaving vertical scoring as its typical for an older engine - any bore work will result in oil burning. ^ Read the whole thread! Very informative about engine work. I’ll leave it off here for now. Cheers Bennie
  15. A mate called “Subarino” in Perth, WA has one of less than a hand full of Hatches in Oz, he’s running an EJ22 with the SC14 supercharger on 5 or 6 pounds. It went well before he sold it. Then he bought it back in rough condition and it’s been parked up in his shed for a resto between everything else he does. For him, body parts are the problem to repair rust... All that aside, the supercharger went very well on the EJ22! Cheers Bennie
  16. Put your money into an EJ22 conversion. By the time you buy a Weber, fit it and an exhaust, you’re the best part in on an EJ22 conversion. Cheers Bennie
  17. Engine pulled from a parts yard (DIY yard). Re-ring being done as a matter of course to know the engine is in good condition. I’ve already run it on the ground and there’s no knocks or piston slapping etc. I know many may flog this idea, but I’m going to see how long it lasts as a “NA-t” or high compression turbo build with low boost. I won’t be putting custom pistons in - that drives the cost up too far and kind of defeats the purpose of this exercise. @idosubaru - I’ll do some research on GD’s posts and drop links in here. The bores will not be touched as per what I’ve read from GD’s recommendations. Cheers all! Bennie
  18. Thanks @nvu! I hadn’t thought about removing the sump to manipulate the conrod! It’s been well over a decade since my last full Subaru engine rebuild (EA82 - that was a mistake!). The sump needs to come off anyway so I’ll line this up at the same time as putting the pistons back in. Cheers Bennie
  19. There’s a low range gear before the drive gears (1st to 5th) - it’s opposite to traditional 4wd gearbox setups and is done like this mainly for tidy packaging. Your current low range ratio is 1.19:1 (19% reduction). The L series has a 1.59:1 low range (60% reduction) - the best one subaru ever made. With some manipulation of the hub in the middle of the whole thing and an interference bush on the input shaft (bearing size difference), the L series low range will drop in place of your legacy low range. Do some searching on it. There’s a good thread on Ausubaru.com.au but the pics are blurred thanks to photophucket. https://ausubaru.com.au/viewtopic.php?f=22&t=13511 Hopefully that explains what needs to be done. Gearboxes aren’t as scary as ppl make them out to be. Cheers Bennie
  20. “Looking” @GeneralDisorder for this: I’m wanting to do this to the EJ22 I pulled down recently. I’ve got some questions since it’s my first time diving into this (not the first time having an engine striped down this far). 1) minor scuff marks or scoring on the piston skirts are ok to just “throw back in” or should I gently sandpaper the effected area? 2) the odd line in the bore is ok? 3) best method to sort the ring end gap? 4) best method to get the gudgeon pins/wrist pins back in? I see issues with lining up the con rod to make it all “just go back in” 5) anything else I should know about doing this? 6) any bedding in procedure that should be followed? Any tips or advice is very welcomed and appreciated! I find myself a bit nervous about this because a) I’ve not done this before and b) if it doesn’t work I’ve just blown some decent money on a very big learning curve! This engine will go into my brumby once the work is done Cheers Bennie
  21. Needs bigger! Serious note: I’m not good on tyre size readings but going an inch taller won’t really be noticeable or have any real benefits. I do know what you need to ensure is that the tyre clears the spring perch/seat on the strut when going larger. Cheers Bennie
  22. Reading over this thread and with little auto experience, my question for you @CityLights: where did the replacement trans come from? I’m wondering if it’s from a crashed car or a parts car. And are speed sensors not like manual gearboxes where you can remove them from the side of the box and swap them around etc? Cheers Bennie
  23. Does the engine oil smell like fuel? You could have a leaking injector. If your engine oil doesn’t smell like fuel then learn to let the fuel line pressurise before rolling into the start position with with key. Treat it like a diesel where you have to wait for the glow plugs to warm up when it hasn’t been driven for an hr or longer. Cheers Bennie
