el_freddo
    128
  1. Welcome. And a targa to boot too! Cheers Bennie
  2. The heads will bolt on. You’ll have to investigate the differences in the piston if any. Other than the piston question, it’ll bolt together etc. Cheers Bennie
  3. And make sure the switch is compressed otherwise the circuit is closed, same as if you have your foot on the brakes. With a second switch plugged in you can at least have someone manipulate it while you check the tail lights out Cheers Bennie
  4. There’s definitely a difference in the rear. It should be good for what you’re after Cheers Bennie
  5. An auto sparky is basically an electrician that is specialised in automotive electricals. They’re completely different to domestic electricians that work on houses etc. They can usually do more but aren’t full blown (qualified) mechanics. I hope for you that it’s an easy fix! Cheers Bennie
  6. Looks good mate. Beefier rear outback struts makes sense to me - more rear overhang on the outback and possibly a heavier body too. You need to to a whole car pic to show the after effect. Cheers Bennie
  7. Least painful for you, or your wallet? Auto sparky might be the better way to go for this one if you’re not going to investigate yourself. Cheers Bennie
  8. Yes. SOHC EJ fits no worries. DOHC EJ requires a chassis rail mod forward of the engine crossmember. Cheers Bennie
  9. Yes, do it. Your suspension bushes will thank you for it, especially if they’re old. Cheers Bennie
  10. Double check the ratio of the gearbox. They also come as 3.7 ratio. Cheers Bennie
  11. Yes that is true. But you’ve taken what my message way out of context. Year and model doesn’t matter in terms of kit specifics or how to set up the timing. It’s either SOHC or DOHC. Procedure to correctly the fit timing gear is specific to DOHC and SOHC, but it is the same across all models with the specific cam setup it has. Probably clear as mud now, but anyway... Cheers Bennie
  12. Also make sure the plastic block at the base of the gear lever is in good condition. If this is sloppy, the rest of the system will be too. Cheers Bennie
  13. Just cut the bracket off the stick that holds the shaft that pushes/pulls out of the gearbox, remount it up higher on the stick/gear lever and hey presto, you’ve got a quick shift setup. Cheers Bennie
  14. Not hard to create a linkd in account. It’s like business Facebook. Get it in writing from Subaru that this dude is legit and go from there. Cheers Bennie
  15. Very nice mate! Thats some interesting routing of the intercooler plumbing. Cheers Bennie
  16. He’s there to swap the air bags - and take your wrx... I’d be highly suspicious! If SOA won’t confirm the guy is legit I’d call the police. Cheers Bennie
  17. Year and model doesn’t really matter. A timing belt is either SOHC or DOHC on a subaru. The process is the same for any SOHC. The arrow on the LHS bank indicates which cylinder is at TDC. When lining up the cam shaft it should be at about the 1:30 mark from memory. Cheers Bennie
  18. Awesome @Ausumm! I reckon you’ll like the Outback. Throw up some pics when you get the chance! Cheers Bennie
  19. Rear timing covers = the black covers behind the cam wheels Cheers Bennie
  20. Welcome to the forum. My advice: don’t. You’re putting a quite rare engine into your van. Parts will be hard to get! Reliability - I can’t say much about that with no experience with these engines, but if they leak oil like the EA82 that they’re based from, expect oil marks left after you park up everytime. I’d recommend dropping an EJ22 in place. Or go a H6 for more power (and fuel use). The EJ series engine is well supported and it’s a solid engine that’s Uber reliable. At the end of the day it’s your call. The EJ is done and dusted time and time again - a proven conversion. Cheers Bennie
