125
Waaaa-hhhaaaatttt??? That’s crazy!
Airbox to the side or airbox centred on top of the engine? If centred on top of the engine, it’s a carb. If on the RHS of the vehicle it’s EFI. Single port or multi port it doesn’t really matter. Cheers Bennie
Congrats mate! Now drive like an oldie with five car spaces between you and the car in front Cheers Bennie
Now you have adjustable cam timing! Cheers Bennie
87 BRAT with mysterious wobble
el_freddo replied to HRBrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Uni joint on the tail shaft. Check them for play. Also inspect you engine/gearbox mounts. Cheers Bennie -
If the cam wheels are metal there’s no need to replace them. Check to ensure the oil leak isn’t from the head gaskets. I’m not sure that this is an EJ25D issue, just an EJ251 issue. Welcome to the forum! Cheers Bennie
Just a flesh wound, she’ll be right! (The legacy). Glad to see the coupe coming along. Looks like a top job done on the repair work. Cheers Bennie
Sounds painful mate! Cheers Bennie
If unsure of diff ratio (there’s usually a sticker on the back of the rear diff on these older Subaru’s), swap in the rear diff from the donor car. It will bolt in no worries. Drive shafts - use the MY units front and rear. I thought you’d have more EJ conversion questions than what you didn’t have there Cheers Bennie
Is an 85 Brat similar to a 84 Gen 2 wagon?
el_freddo replied to mkoch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Front doors backwards is different. Centre console swaps over too. Great for parts. PS and AC will swap in. Cheers Bennie -
Bubbling in coolant reservoir
el_freddo replied to MTNjohnny's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1) replace head gaskets and have the heads shaved - before you toast that engine good and proper 2) drop an EJ conversion in 3) drive till it pops good a proper. Junk it and buy a newer Subaru. I vote option 2. Cheers Bennie -
Broke and mods don’t go in the same sentence! What you can do is basic maintenance things - quality spark plugs and leads. Suspension handling is an area you could look into. There are parts out there second hand that will improve the handling of the vehicle. Suspension bush replacement could be a good option too. But really, how long are you looking at keeping the vehicle for? If you’re moving it on in a few years just save your coin for the next vehicle and get what you want in a factory package Cheers Bennie
- 12 replies
- 2
Epic BRZ drift car build in Oz
el_freddo replied to el_freddo's topic in BRZ and its Sister the Scion FRS/Toyota GT86
Was it DIY’d in a dude’s shed or built by a shop? Is the suspension mount points lifted into the body of the vehicle to lower it but keep good suspension geometry for best performance and low centre of gravity? I reckon this build will be one of a kind for the above reasons. That’s what makes it epic - DIY built and will meet required class specs/scrutineering. Not everything epic has to be about money and power numbers - where’s the personal skill in that build? Cheers Bennie -
Rear diff plug looks to be normal. If there were chunks of metal instead of fine particles, then I’d be concerned! Cheers Bennie
1987 gl wagon headlight issues
el_freddo replied to cornbreadfed's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Clean the switch contacts in the cluster switch. Steering wheel will need to be removed for this. Also check all solder joints on the main wires to the switch cluster. Renew/repair if looking dry/cracked/dodgy. I had the main power wire for the lights break off mine one night on a 2hr drive home. It shorted out so I had low beams. Not great but I was greatful for having some sort of lights I could drive home with. The symptoms you describe are the same as what I had in the lead up to this issue - except for the lights randomly turning off when in use. Mine only did it between switching from Lo to high and vice versa. I ended up replacing the combination switch from a ‘91 L series and haven’t had an issue since. It was a much tighter unit too. My old one had 400,000ish km on it with a lot of night driving during my ownership (which continues). Cheers Bennie -
EJ swap question with start up
el_freddo replied to bratboy1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also make sure your crank and cam sensors are bolted in place correctly and are plugged in. Any codes on the ECU? Cheers Bennie -
Freeze plug replacement walk thrpugh
el_freddo replied to 4loyales's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks mate, not instincts - experience after buying a brumby “that just stopped onthe way to work”. Popped Welch plug filled the content of the cooling system into the engine. We got 20L of water oil and sludge out of the little EA81. This is what we found once the heads were removed: One welch plug dropped out. Cheers Bennie -
If the fuel pump is turning on and off the ECU is still in check codes mode. You need to disconnect the black connectors above the driver’s feet. It’ll be a single black wire with black connectors you’re looking for. Also make sure the green connectors in the same area are disconnected. That may influence the injector voltage - might not. You’ll have to investigate. Cheers Bennie
Greetings from the desert
el_freddo replied to bbf1887's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the forum bbf. Thow up some details and a pic of your 80’s Subaru Cheers Bennie -
That’s awesome! We didn’t get anything like that over here AFAIK. Cheers Bennie
EA81 Dashboard Removal Help
el_freddo replied to Scoby4wd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
G’day Scoby4wd, As you’ve said, under the defrost vents are three bolts. Under the dashboard left and right are two bolts on the lower A pillar. Remove the centre console. Remove any panels from above foot area. On either side of the heater box is some moulded ducting. Remove this, it clips in top and bottom. Can be a tight fit in there. Again, either side of the heater box are the cables for vent and temps. There is also one for the outside air vent high up under the dashboard. Disconnect these. Disconnect the main wiring plugs near the fuse panel. You might need to drop the fuse panel to access them properly. There will be other fiddly wiring clips to undo here and there. Take note of these for reassembly. I believe there is one wiring plug that goes to a relay or some box on the firewall. Keep an eye out for this sucker. Remove the steering wheel and drop the steering column - or remove the whole steering column (leaving the steering wheel in place). Pull the speedo cable from the back of the instrument cluster. Hold the dashboard and jiggle it gentle to loosen it’s sitting position. Feel for any resistance as this could indicate a missed mounting bolt/nut. Carefully lift the dashboard avoiding the windscreen (can easily crack the windscreen). Again check for any resistance while removing, it’s usually easiest to go out the passenger door, but really it doesn’t matter and will be more about what has better shed access (if indoors). It’s easier to do if you’ve got the windscreen removed! Those bolts under the demister vents are vertical and are a PITA to get at with the windscreen in place. Still doable though. The replacement dashboard should drop straight in place of the old one. Install is the reverse of removal, or close enough to it. Pull the cracked one first! Learn, clean the firewall etc. Then pull the good dashboard out. Now is a good time to add AC if you don’t have it but have access to a full kit. I think that’s about it. It’s been a few months since I did this last so I may have missed some finer details. Cheers Bennie
