128
rebuild 1990 Subaru Loyale EA82 SPFI
el_freddo replied to Eric1111's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The EA82 will only give you headaches finding parts unless you’re patient (and possibly lynhave deep pockets). As @wagons said, the EJ conversion can be done for about the same amount as a DIY engine rebuild, more if you pay someone to do the work for you. Pick a series of engine that you like and get a donor vehicle that has it fitted. The EJ22 is well tried and tested. I’ve had mine for ten years and counting. Done head gaskets once and cambelt twice (it’s due again now). I would like more from it but compared to the EA82 it’s night and day! Cheers Bennie -
Dipstick broken off in tranny
el_freddo replied to Espey16's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Use a magnetic tool retriever that fits down the tube to lift the remains of the dipstick out. If it’s full length that’s broken off you shouldn’t have any issues. If it’s only a part of it, you’ll probably have trouble getting it out. If this is the case it could be worth draining the oil and trying to fish the broken off section out through the drain plug. Cheers Bennie -
If the engine moved rearward there maybe internal damage to the rear output shaft in the gearbox/transmission. This will be hard to work out without either driving it (and finding a problem) or removing the tailshaft and physically inspecting the outputshaft for any significant play. Bummer about all that work and then the prang. I too like Imdew’s suggestion of finding another vehicle that needs an engine, then make one good one from the two. Cheers Bennie
@FerGloyale - are you saying the US delivered Brats have a check engine light AND a reed switching speed sensor built into the instrument cluster?? If true, you guys are lucky! We didn’t get any of those! Cheers Bennie
You’ve listened to the wrong ppl. My AC works when it has gas in it. I needed to make some custom AC pipes to fit the EJ compressor to the EA AC system; and I needed to reference the compressor clutch wire (from memory) to the EJ ECU wire that is used to idle up when the AC is in operation. It wouldn’t be much different to the Link system too I reckon. Cheers Bennie
New member with overland build decision
el_freddo replied to NWlifer's topic in Meet n' Greet. Your USMB Welcome Center
Welcome NW, My question is what are you wanting from your mild off-roader? - carry gear, sleep in it etc. The outback will have more room than the Impreza. Since a dual range is hard to find state side, an auto will have the advantage over the manual when off-road. Cheers Bennie -
Not on an ‘83. They’re replaceable. At least they are in Oz right up to the last brumby run in ‘91. L series, totally staked. Machining required to convert to replaceable uni joint yokes. Cheers Bennie
4wd will probably be a hand brake kind of effect if the diffs aren’t matched. I believe series 1 4wd touring wagons got the 3.9 diff and the DL 3.7 (could be wrong, they could all be 3.9 in the series 1). Series 2 I’ve only ever seen 3.7s across the board for the 4wd models. Cheers Bennie
How do you determine the ratio by just looking at a box @FerGloyale? Quite a skill! In all seriousness, “easiest” way to work it out is to engage 4wd, mark the rear output shaft, rotate the diff once, counting how many times the rear output shaft rotates. You may have to work out what .7 of a rotation looks like to decipher between 3.7 and 3.9 (which will be closest to 4 rotations). Cheers Bennie
Recycled member returns
el_freddo replied to LPGforester's topic in Meet n' Greet. Your USMB Welcome Center
Welcome back! That wouldn’t happened to be the Wonder Brumby II that your old username refers to would it? From Tassie? Cheers Bennie -
I saw that earlier today. Best H6 note I reckon I’ve ever heard! What a beast. Cheers Bennie
- 26 replies
It’s been done many times here in Australia with the Brumby (Brat). The best person I know that could answer this is @Steptoe Cheers Bennie
Yeah I see what you’re talking about with the triangle trim piece. And I’ve never seen side mirrors like that. I’m sure our ‘84 side mirrors are different - alabit trashed since the car was stolen and driven through a cyclone fence (years ago now!) nope, they’re the same style. LHS mirror is gone. Cheers Bennie
1991 XT6 won’t idle, runs rough
el_freddo replied to toomanynooks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This has caught out several new members too. Don’t go asking about your 1992 loyale in that forum, they’re EJ series and beyond. As GD mentioned, read the forum description - or the fine print of you like... Cheers Bennie -
The parts car that has the piece on it is an hour’s drive away at my parent’s farm. Earliest at this stage would be next weekend. If your mum gets suss - use some BS magic that a forum member is curious about the 85 model door setup with the mirror. Be sure to then take some exterior pics too Cheers Bennie
Very unusual for the belt and crank pulley to align like that for a cam belt change! You should go buy a lotto ticket And I’ve done the drink bottle cut down burping method many times! Cheers Bennie
