128
Looks good armedequation! I hope the road trip goes well. Great way to get acquainted with the subi! Cheers Bennie
@GeneralDisorder - is there a particular process in doing this? I have three questions about doing this: - do you run the engine in park, neutral or drive to pump out all the fluid? - when the fluid is pumping out, do you have the other tube sucking fresh fluid or leave it open until the flow reduces from the outlet hose? - replace the filter at which point in the procedure? Cheers Bennie
EA-81 rebuild or replacement in the Northwest
el_freddo replied to HRBrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You’re right, I should’ve been more specific with the low compression and that it’s related to blow by and pushing oil mist into the intake system. @HRBrat - you’ll have to work out if you have hydro lifters or not. We only have solid over here. Also check for a bent push rod. Cheers Bennie -
Bad bearings certainly can have a whining noise to them! It’ll even change noise with bumps in the road. Cheers Bennie
Can’t happen at idle. Are your valve clearances correctly adjusted? Cheers Bennie -
Yep, start at the compression check. I’m still yet to do mine. Also check the shaft play on the throttle body of the carb. I reckon this can easily mean out the mixture by sucking in air after the Venturi, leading to predetonation. Cheers Bennie -
Not consider, DO! And not “should” either. Nike Cheers Bennie
I’m putting money on wheel bearings. The cv shafts shouldn’t be giving you any trouble since they’re generally ever used - if you don’t fit into this category, then they could be a possibility. Cheers Bennie
Diff ratio swap. 4.44 is the shortest you can get. Good luck fitting this to a PT4wd EA 5spd box, the pinion shaft in these gearboxes is part of the lower gearset. In the AWD EJ gearboxes the pinion shaft lives in a tube that the lower gearset is fitted to. Major mods needed. Match the rear diff to the front diff or just run in 3rd on the highway? Cheers Bennie
Over here the go to tube to use is called “bunny tube”. It’s the standard for fixed lines. Since we don’t have snow and salt on our roads, copper brake lines are illegal due to the ability of the copper tube expanding the blowing out. For the flexible lines braided is the way to go. Our ADRs dictate that braided lines must be covered in a plastic like liner, basically a tube laminate. That’s what I got when I asked for braided lines. Any good brake shop will point you in the right direction for what you need. Cheers Bennie
Got nothing on Melbourne/Victorian weather - winter in the morning, spring by mid morning, summer in the arvo and autumn coming into the evening. The last week we literally had all seasons in one day that also included hail. The day after it snowed down to 700m - a pretty rare event for winter let alone near the end of spring. Going back to the ignition switch - I agree with Numbchux - the starter switch is designed NOT to have power to accessories when in the start position. Thus without a power connection in the start position, there can never be power to accessories unless something went massively wrong, in which case you’d have larger issues at hand too. You could test the wiring and the inhibitor switch by putting 12v to the starter wire, try in park and neutral. If both work, the issue points at the ignition switch. Cheers Bennie
Heater core location issues...
el_freddo replied to GoudaWagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
From memory it was $AU220. It was up there with a main radiator replacement but after doing three dash pulls to install second hand units (that all blew in a short amount of time), it was a good investment and it continues to be. Cheers Bennie -
Take your old unit to a radiator specialist and have them make one up. Years ago I lashed out on a new all copper/brass unit and haven’t looked back. The rad shop was able to order one in. No idea on part number though I’m sorry. Cheers Bennie -
Like any engine conversion - wiring conversion, dash out... it’s been done before so nothing new there. Aftermarket engine management is another option - then there’s the cost of tuning etc. Not for the faint of heart! And as GD said above, it’s costly if you’re not doing a DIY job (and know what you’re doing). There are two H6 conversions getting around Oz that I know of. Both used to be in our off-roading group, the first was a Gen2 Liberty, the other is a SG Foz (from memory). The Liberty was sold on, no idea where it is now. The forester is still owned by my mate, but he now lives interstate. Cheers Bennie
- 26 replies
If you have issues with your cam or crank sensors, you’ll usually experience engine cut out or loss of power. It would not be nice to drive if you could get it out of the driveway. If the code is actually the O2 sensor, you need to check this out. It’s located near the RHS driver shaft’s inner joint, but in the exhaust in front of the cat. You’ll see what looks like a probe with wires coming from it. That’ll be the O2 sensor. As for the timing belt. A visual inspection would be good. If you’re really worried just do it. Cheers Bennie
