128
Seat Covers and carpet for 80 brat?
el_freddo replied to douglasbruno's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Carpet is available on eBay. Dunno if you can get it in the states. It’s about $AU200 delivered here now. It’s a nice update to the interior as we only got vinyl floors in ours. Dunno about seat covers. You should track down an interior upholsterer and see what they can do Cheers Bennie -
Dead ignition module in the dizzy. Replace this AND the coil. If a coil dies it takes out the expensive ignition module. You wont have spark. No spark, no fuel pump operation due to the fuel cut relay doing its job. Cheers Bennie
EA-81 rebuild or replacement in the Northwest
el_freddo replied to HRBrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do a cold start and see if you can hear any knocking. I would say there isn’t any. What I think you might be hearing is actually pre-detonation. This can be due to lowered compression, poor timing, worn plugs, oil mist (from blow by pressurising the crank case), worn rings. If you do hear constant knocking at cold start up, even after oil pressure is built up, you’ve got rod knock. Unlikely in these engines unless constantly over-revved, and/or starved of oil. Cheers Bennie -
Clutch bolt size and thread pitch?
el_freddo replied to wagons's topic in Old Gen.: 80's GL/DL/XT/Loyales...
By clutch cover do you mean the clutch pressure plate? Cheers Bennie -
What Numchux said - more components. But these will be built to keep your CV angles as they are now if you keep the same strut and spring combo. Going higher will allow taller tyres, which will give you more lift again but will also make your gearing taller and raise the centre of gravity. Driving style will need to change, otherwise you could ruin your forester, yourself or someone else. Cheers Bennie
Hey bigboy, seems like a suitable name! You need to work out how much lift those struts got since you swapped to the outback units. Springs will play a part too. If you want strut lift, I’d recommend a “subframe” drop too. This with the strut lift is essentially a full body lift. By today’s standards of lifting Subaru’s, it’s quite involved. Cheers Bennie
While the engine is cranking, or running poorly, gently tap each injector repeatedly. This can free up stuck injectors. You can also use a length of dowel, or a long screw driver to listen to the injector pulse. It’ll create a light chattering like sound. Cheers Bennie
I’ve got a ‘93 RS turbo Liberty (2L with WAIC) waiting for me to get an engine together for it. It’ll then go on club rego and be enjoyed Cheers Bennie
Motor swap
el_freddo replied to Zoltan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
In which case (about the overheating), I’d be using the heads from the pick and pull engine. Cheers Bennie -
Ah so you have a povo spec RS water to air intercoolerd 2L turbo, and no WRX. I can see where you’re coming from with that angle. The early WRXs are the best ones. Not many around these days since many, many of them were crashed, modified (hugely molested) they parted out. Cheers Bennie
Motor swap
You could pull down that engine to see what the issue is. Removing the cam on the bank with the dead compression cylinder will allow you to see if there’s a broken valve spring or missing valve spring washer retainer clips (little half moon crescent pieces that hold the washer in place that sits on top of the spring). But the engine from that fender bender unit at the wreckers would be a good option for drop in and go - if the coolant system wasn’t damaged in the crash, or it’s not an insurance job... Cheers Bennie -
1984 Subaru GL Wagon FWD w/ 5 spd & 255,000 miles
el_freddo replied to amarine1's topic in Members Rides
Sooo clean, even with that bit of door rust! The rust looks easily treatable. Cheers Bennie -
Really? Like what? We missed out on turbo brats (brumby), wagon’s and coupes. We didn’t get the hatch as I’ve mentioned and we also didn’t get the huge variety of wagon trim options like you guys did the the states! With the L series we missed out on the coupe (I’d have an RXII coupe if they weren’t a special import, I can’t afford that!) and the XT6, not to mention the various turbo wagons etc. We did the the RX turbo sedan. This was the only turbo model readily available, the other was the expensive of the time XT4 (Vortex). Other than a dual range EJ AWD manual gearbox, I don’t see much cooler stuff in our line up! Cheers Bennie
Motor swap
If you’re confident, methodical and good at cleaning mating surfaces, there’s no reason why you couldn’t do a HG job with the right tools. A mate who knows how to do these things is always helpful to have on hand too. All the best with it, sounds like a neat project! Cheers Bennie -
Here’s your ignition relay 1 and 2 part: https://partsouq.com/en/search/search?q=82501AG040&qty=11 From here: https://partsouq.com/en/catalog/genuine/unit?c=Subaru&ssd=%24*KwGrn46q_K7wycDH59atofPnx8Der6CtrL6otdmg3uDs2OS_puzou6Csq7u0ve3i9PCprL3j5-7f5uKn8KO61diry9eki4XmoN-vrKutpq7i4vD8uqWmrKmzv7ns6LvZveMAAAAACVjUhA%24&vid=0&cid=315&uid=10059&q=JF2SH9KK49G022593 I too can’t seem to see a main relay reference other than that of the diesel option, which is the same relay as the ignition relay 2, from here: https://partsouq.com/en/catalog/genuine/unit?c=Subaru&ssd=%24*KwHL_-7KnM6QqaCnh7bNwZOHp6C-z8DNzN7I1bnIvICMuITfxoyI28jGyNvU3Y2ClJDJyd2Dh46_hoLHkMPatbjLq7fE6-WGwL_PzMvNxs6CgpCc2sXGzMnT39mMiNu53YMAAAAA6bicUw%24&vid=0&cid=304&uid=9643&q=JF2SH9KK49G022593 This is the part number: 25232AA100 from here: https://partsouq.com/en/search/search?q=25232AA100&qty=2 Hope this helps. Regards Bennie
When you check for power, do you have someone hold the ignition key in the start position? If not, the circuit has not been correctly tested. You could also try a contiuality test between the back of the switch to the starter solenoid. Have you tried running a wire from the starter soleiod pin to the positive on the battery to test the starter? Also another thing to check is the auto start cut switch - the one that only allows cranking in park or neutral. Cheers Bennie
