el_freddo
    128
  1. Next step is obviously to read the codes. Record the codes, then systematically check/clean (if appropriate) each sensor. What was the main relay part number in the end? Cheers Bennie
  2. Carpet is available on eBay. Dunno if you can get it in the states. It’s about $AU200 delivered here now. It’s a nice update to the interior as we only got vinyl floors in ours. Dunno about seat covers. You should track down an interior upholsterer and see what they can do Cheers Bennie
  3. I’ve had that happen on my L series too. I replaced the tailshaft/prop shaft with a unit from the wreckers (got lucky with that!) when interstate. Fitted it and drove 800km home from interstate Cheers Bennie
  4. Dead ignition module in the dizzy. Replace this AND the coil. If a coil dies it takes out the expensive ignition module. You wont have spark. No spark, no fuel pump operation due to the fuel cut relay doing its job. Cheers Bennie
  5. Do a cold start and see if you can hear any knocking. I would say there isn’t any. What I think you might be hearing is actually pre-detonation. This can be due to lowered compression, poor timing, worn plugs, oil mist (from blow by pressurising the crank case), worn rings. If you do hear constant knocking at cold start up, even after oil pressure is built up, you’ve got rod knock. Unlikely in these engines unless constantly over-revved, and/or starved of oil. Cheers Bennie
  6. By clutch cover do you mean the clutch pressure plate? Cheers Bennie
  7. What Numchux said - more components. But these will be built to keep your CV angles as they are now if you keep the same strut and spring combo. Going higher will allow taller tyres, which will give you more lift again but will also make your gearing taller and raise the centre of gravity. Driving style will need to change, otherwise you could ruin your forester, yourself or someone else. Cheers Bennie
  8. Hey bigboy, seems like a suitable name! You need to work out how much lift those struts got since you swapped to the outback units. Springs will play a part too. If you want strut lift, I’d recommend a “subframe” drop too. This with the strut lift is essentially a full body lift. By today’s standards of lifting Subaru’s, it’s quite involved. Cheers Bennie
  9. I was going to say the same thing - paint those guards! Is POR15 UV stable? Cheers Bennie
  10. While the engine is cranking, or running poorly, gently tap each injector repeatedly. This can free up stuck injectors. You can also use a length of dowel, or a long screw driver to listen to the injector pulse. It’ll create a light chattering like sound. Cheers Bennie
  11. Have you sussed out whether or not you need to swap heater boxes, or are the actuators easily retro fitted/the system uses what’s already there? Cheers Bennie
  12. I’ve got a ‘93 RS turbo Liberty (2L with WAIC) waiting for me to get an engine together for it. It’ll then go on club rego and be enjoyed Cheers Bennie
  13. In which case (about the overheating), I’d be using the heads from the pick and pull engine. Cheers Bennie
  14. I’d use the headbolts with the head they were last used with. Reuse if no overheating and first time reused. That’s the advice I was given and what I worked with. Cheers Bennie
  15. Ah so you have a povo spec RS water to air intercoolerd 2L turbo, and no WRX. I can see where you’re coming from with that angle. The early WRXs are the best ones. Not many around these days since many, many of them were crashed, modified (hugely molested) they parted out. Cheers Bennie
  16. You could pull down that engine to see what the issue is. Removing the cam on the bank with the dead compression cylinder will allow you to see if there’s a broken valve spring or missing valve spring washer retainer clips (little half moon crescent pieces that hold the washer in place that sits on top of the spring). But the engine from that fender bender unit at the wreckers would be a good option for drop in and go - if the coolant system wasn’t damaged in the crash, or it’s not an insurance job... Cheers Bennie
  17. Sooo clean, even with that bit of door rust! The rust looks easily treatable. Cheers Bennie
  18. Really? Like what? We missed out on turbo brats (brumby), wagon’s and coupes. We didn’t get the hatch as I’ve mentioned and we also didn’t get the huge variety of wagon trim options like you guys did the the states! With the L series we missed out on the coupe (I’d have an RXII coupe if they weren’t a special import, I can’t afford that!) and the XT6, not to mention the various turbo wagons etc. We did the the RX turbo sedan. This was the only turbo model readily available, the other was the expensive of the time XT4 (Vortex). Other than a dual range EJ AWD manual gearbox, I don’t see much cooler stuff in our line up! Cheers Bennie
  19. If you’re confident, methodical and good at cleaning mating surfaces, there’s no reason why you couldn’t do a HG job with the right tools. A mate who knows how to do these things is always helpful to have on hand too. All the best with it, sounds like a neat project! Cheers Bennie
  20. Here’s your ignition relay 1 and 2 part: https://partsouq.com/en/search/search?q=82501AG040&qty=11 From here: https://partsouq.com/en/catalog/genuine/unit?c=Subaru&ssd=%24*KwGrn46q_K7wycDH59atofPnx8Der6CtrL6otdmg3uDs2OS_puzou6Csq7u0ve3i9PCprL3j5-7f5uKn8KO61diry9eki4XmoN-vrKutpq7i4vD8uqWmrKmzv7ns6LvZveMAAAAACVjUhA%24&vid=0&cid=315&uid=10059&q=JF2SH9KK49G022593 I too can’t seem to see a main relay reference other than that of the diesel option, which is the same relay as the ignition relay 2, from here: https://partsouq.com/en/catalog/genuine/unit?c=Subaru&ssd=%24*KwHL_-7KnM6QqaCnh7bNwZOHp6C-z8DNzN7I1bnIvICMuITfxoyI28jGyNvU3Y2ClJDJyd2Dh46_hoLHkMPatbjLq7fE6-WGwL_PzMvNxs6CgpCc2sXGzMnT39mMiNu53YMAAAAA6bicUw%24&vid=0&cid=304&uid=9643&q=JF2SH9KK49G022593 This is the part number: 25232AA100 from here: https://partsouq.com/en/search/search?q=25232AA100&qty=2 Hope this helps. Regards Bennie
  21. It could be a sticky IACV. Also a good time to check for any stored codes, this might give a clue as to what could be part of the issue. Cheers Bennie
  22. When you check for power, do you have someone hold the ignition key in the start position? If not, the circuit has not been correctly tested. You could also try a contiuality test between the back of the switch to the starter solenoid. Have you tried running a wire from the starter soleiod pin to the positive on the battery to test the starter? Also another thing to check is the auto start cut switch - the one that only allows cranking in park or neutral. Cheers Bennie
  23. I thought I was starting to see double! Made me check where I’d scrolled to more than once! Cheers Bennie
  24. Another trick is to fab up a 17mm bolt with two nuts locked on to it and welded for good measure. Then use your regular 17mm socket to do the job with your hex key adaptor. Cheers Bennie
  25. You’d have some difficulty damaging that shaft - it’s a solid lump of hardened steel. Your money, buy away, but I think you’re wasting your money. Cheers Bennie
